Question about HP LaserJet CM1015 All-In-One Printer
Printer does not print or copy the full page
CM 1015 MCP when I copy or print it misses out the top of the page. The rest of the page is fine.
Hi pls set paper size & type setting set for a4
Posted on Jun 14, 2007
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
My Artisan 800 only prints the top inch of the page - the rest of the page is blank. This is true regardless of the function: print or copy or fax, so I don't think it's related to the computer. Ink...
My Artisan 800 was doing this and I realized it was because I was using three hole punched paper. I think the printer sees the top hole and thinks the paper has run out and cancels the rest of the page. Big engineering goof Epson.
Dec 17, 2010 | Epson Artisan 800 All-In-One InkJet...
Aficio 1015 Ricoh copier;page margins changed without instructio
Check the print/copying area to see if those controls have been handled or not. Also remove the wire mesh through which the toner passes through. Clean it well but very gently using a painting brush and a blower. Rest it and try a copy....................sodeep
May 04, 2009 | Office Equipment & Supplies
Print page problem
exists special function in driver of the printer which quantifies pages of the document on one signet sheet. Sounds like "Multiple printing"
Mar 06, 2009 | HP LaserJet 1015 Printer
How do i make double sided copies for my HP 2840
When you call up your printer (usually [Ctl][P]) tell it to print even numbered pages only, but in reverse order, This means the last page to be printed will be page 2, and it will be face down on the top of the pile (blank side showing) Take the printed sheets and rotate them so the top (head) of the sheet is feeding back into the machine, with the blank sides up. Now call your print up again and tell it to print the odd pages only. The first sheet to be printed will be page 1 which will print on the blank side of page 2, and all the rest will follow in sequence, with the correct sides up. Works every time. The print control is part of the Windows system, so your application should provide the full functionality.
Dec 18, 2008 | HP LaserJet 2840 All-In-One Printer
A940 printing issue
hmm..now..that sounds more like a software issue, than a hardware issue. Can you check on all version updates for the software from MSoft, and ensure that the drivers for your printer, by application, are up to date. From what I'm seeing, this MAY not be a printer issue.
and, if you want, we do this sort of service call remotely. see my link here for more on that.
http://www.inbusiness4good.net
There's a profile link on top right, that may be of some value, if this becomes unsolvable from your end.
Aug 20, 2008 | Dell A940 All-In-One InkJet Printer
Problem printing after replacing toner cartridge
We replaced the cartridge and it is still copying in bad quality.
Printing is fine but it is the copying that is the problem.
Aug 07, 2008 | Samsung SCX-4216F All-In-One Laser Printer
Printer prints top 1" of page, then just spits out blank pages
If the printer works ok on another PC, it seems quite clear that the problem is definately software (Driver) related. If you haven't done so already, I recommend adding the printer through the Printer\Faxes Add Printer Wizard and pointing it to take the drivers off the install CD (if you have one) rather than installing the printer from the CD Autorun. Just make sure that you've deleted the printer completely from Printers\Faxes and rebooted before each install attempt.
I hope this helps!
Cheers,
Matt Coyote
Feb 24, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Printing Alignment
Is the paper cassette set to the correct paper size and/or the printer driver printing to the correct paper size? Sometimes this can cause the image to be offset.
Sep 12, 2007 | Canon IMAGERUNNER 3530 Copier
HP LaserJet CM1015 All-In-One Printer Logo
197 people viewed this question
Clive
Clive
