Question about Technics SL-1210 Turntable
Pop up inspection lamps blown
Can you please advise me on how to replace the pop up lamp on my tecnics 1210 deck,would you also know if the lamps are available in blue ? many thanks chris
    Scholar:
  • 56 Answers
Greetings!
The original equipment replacement part number for this lamp is SFDN122-01E and is in stock from www.encompass.com for around $7 plus freight. These are in white only, but you may be able to purchase small, rubberized covers (like a little lamp condom) from an accessory/parts distributor such as MAT electronics or MCM.
To access the lamp first UNPLUG THE TURNTABLE. Lock the tonearm in place. Invert the turntable. Remove the 4 audio insulators, remove the 17 screws with spacer and then remove the other 11 screws. Remove the bottom plate. Remove the 2 screws that hold the lamp circuit board in place. Then remove the lamp screw.
Hope this helps!
Rob
Posted on Jan 14, 2009
Watching the TV heard a loud pop picture went blank and smelled a little bit of smoke.
The first and most likely cause is that your lamp has blown. Simply remove it and inspect when they have blown its really easy to tell. Remove lamp door with a philips screw driver. The door is located I believe on the back of the set towards the right side. Once the lamp door is off there will be 1 maybe 2 screws holding the lamp assembly itself in place. Remove those then the housing should slide right out. The lamp number is 915B403001 for that model.. Good Luck!!!
Dec 02, 2010 | Mitsubishi WD-65735 Television
How do you get access to the rear turn signal lights in a 95 dodge intrepid
From autozone.com. Please let me know if you have any questions.
  1. Release the trunk latch and open the trunk lid.
  2. Remove the fasteners holding the trunk lining to the lower rear deck panel.
  3. Separate the trunk lining from the deck panel.
  4. Detach the lamp wiring from the wiring harness.
  5. Remove the nuts that retain the tail lamp to the lower deck and quarter panel.
  6. Remove the tail lamp from the vehicle.
  7. Remove the socket and pull the bulb out if replacement is needed.
To install:
  1. Push a new bulb into place if required, then insert the socket into the lamp.
  2. Insert the wire harness through the hole in the lower deck panel.
  3. Install the wiring harness grommet into the lower deck panel.
  4. Place the tail lamp into position on the vehicle.
  5. Install the nuts to hold the lamp to the lower deck and quarter panel.
  6. Attach the wire from the lamp to the body harness.
  7. Place the trunk lining into position on the lower deck panel.
  8. Install the fasteners that hold the trunk lining to the lower rear deck panel.
  9. Check the operation of the lamp.
Nov 05, 2010 | 1995 Dodge Intrepid
Hi', have a problem with my dell 17" monitor. 'tis a e173fpc. green light would come for a split second then off. opened up . saw nothing physically wrong. please advise.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Check the fuse, transistors, solder joints (use magnifier), caps. Or replace the board if the lamps are good after testing.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Oct 16, 2010 | Dell E173FP 17" LCD Monitor
I have a 50 " Sony Wega KDF50WE655
Front panel should unscrew with thumbscrews and pop off and there should be an access cover for the bulb in center.
Apr 13, 2010 | Sony KDF50E2010ATNS 50" HDTV-Ready LCD TV
I just heard a loud pop and my picture went to out
the service manual is available in the web site andrewselectronics for sell.
there is a chance to inspect the lamp and see if is damage (normal failure for this popping noise) consult you user's manual ...How to replace the lamp. as i said inspect it and replace it as needed, use original lamp. Toshiba
Feb 23, 2009 | Toshiba 62HM95 62" HDTV
Lamp replacement fears
No flying screws on the lamp (on this model anyway) you should have no problems!
Feb 13, 2009 | Technics SL-1210 Turntable
Sony WEGA KDF-55WF655
What you need is the owners manual my friend. In here it will show you where to get to the lamp and how to change the lamp. Go to http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDF55WF655&LOC=3
to get a free copy of the OWNERS manual. Page 16 tells you how to do this. Good Luck
Jan 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Frozen out the game.
Do the lamps ( 33/45, strobe, pitch at 0, pop up light ) light up when you turn them on. Was the storage climate controlled?
Keep me posted.
Nov 04, 2007 | Technics SL-1210 Turntable
Copier Not Initialising properly
Sounds like you have a fuser failure. Check the heater lamp, thermal fuse and thermistor. One is probably bad.
Jun 20, 2007 | Canon PC-950 Black and White Copier
Technics SL-1210 Turntable Logo
97 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
