Question about Trendware TEW-450APB (TEW450APB) 802.11b/g Wireless Access Point
Trednet Access Point keeps dropping Network connection
I have a trednet access point which keeps dropping from the network often. I thought it was an issue of the access point connecting via a hub and moved it to connect via a switch but it is still giving the same problem.
  • 32 Answers
Trednets are know to do this if you have another wireless component close or next to the device. Do you have any 2.4ghz phones? Cell phones? Other wireless devices? If you have not tried yet, Try switching the channel on the access point. If its not a channel issue, try getting new firmware and test the signal strenth with a wireless sniffer such as Net Stumbler
Posted on Jun 18, 2007
Check connections
The connection of the USB cable
Verify that the USB cable is connected between your Brother machine and your PC.
The connection of the LAN cable (if applicable)
Verify that the network cable is connected between your Brother machine and access point and the machine is powered on.
1.Access point/router
2.Wired Network machine (your machine)
3.Wireless capable computer connected to the access point/router
4.Wired computer connected to the access point/router
The connection of the Wireless network
2.Wireless Network machine (your machine)
Still having Problem Then follow Us For
Brother Printer Support
Feb 20, 2014 | Brother MFC 7840W Printer
Cisco access point
How to configure wireless access point using a laptop
Wireless technology makes connecting to the Internet possible from anywhere within the range of the network. Unfortunately, not all Internet-capable devices have wireless technology, and many still require an Ethernet port connection. If you have a laptop with a wireless card and an Internet connection, you can make the laptop a wireless access point and share that connection with other devices, whether your laptop runs a Windows or OSX operating system. Windows computers allow other devices to access the wireless network via a physical connection to the laptop, while OSX computers allow AirPort equipped devices to connect as well, creating a second wireless bubble for the network.
Instruction:
WINDOWS
1 Turn on the laptop and the device with which you will share the connection. Ensure the laptop's wireless card is turned on and you have an Internet connection.
2 Connect an Ethernet cord to the port on the laptop, and the other end to the receiving device. You need to make the connection first, or you will not be able to access the sharing options for the connection.
3 Open the list of network connections on the computer. In Windows 7 and Vista, access this list by typing "Network Connections" into the Start menu search bar and pressing "Enter." In Windows XP, click on "Network Connections" in the Network and Sharing Center section of the Control Panel.
4 Right click on the wireless connection and select "Properties," then navigate to the Sharing tab. This tab will not appear unless both devices are connected.
5 Check the box marked "Allow other network users to connect through this computer's Internet connection." Click "OK" to save the changes.
OSX
1 Click on the Apple menu and select "System Preferences." Click the "Sharing" option, then choose "Internet Sharing."
2 Select the Airport and wireless network in the "Share your connection from:" drop-down menu.
Select an output format for the connection in the "To computers using:" drop-down menu. Choose "Ethernet" for a physical connection or "AirPort" for wireless broadcasting.
Turn on the device you wish to receive the connection. Connect the devices with an Ethernet cable, or turn on the receiving device's AirPort card and connect wirelessly.
Dec 12, 2011 | Computers & Internet
Can't get better than 54 mbps in datat rate with this device
guilty1178,
The Access Point, or whatever you are connecting to, must also support "N" wireless (~300Mbps); otherwise, the connection speed will be the "lowest common" connection speed, which in this case is "G" (54Mvps).
Note that if a "B" device, such as an older laptop, connects to the Access Point, the Access Point will drop down to 12Mbps for all connections! (Yes, twelve megabits per second).
You will have to replace the Access Point, or connect to an "N" Access Point if you are on a network with several AP's.
-Gort.
Oct 24, 2010 | ASUS USBN13 IEEE 80211bgn USB 20 Wireless...
My phone keeps saying there is aproblem connecting to gprs service in your registered home network
All phones need APN setting to make them work for gprs or data functions.
You can find the settings from your network operator and then you can follow this video guide on how to enter APN settings in any HTC phone.
This is a tutorial on how to add APN settings to HTC phones for your network providers. Example phone used is a HTC Hero but process is same for all HTC models.
APN and Data Settings Change for HTC Phones
  1. Go to settings -> wireless controls
  2. Go to Mobile Networks -> Access Point Names
  3. Click Menu and select New APN
  4. All you need to add for most networks is just the APN setting which can be obtained from your simcards network provider
  5. Press Menu and Save
  6. You are ready and have configured data connection settings.
Enjoy your HTC phones unlocked for Voice and Data for any network. see video below
May 14, 2010 | HTC HD2 Smartphone
Hi!i have a problem with my trednet tew-423pi card. the installation went fine, found the network (open network of the building), connected to it (even if it took a while to aquire IP) worked for a bit and...
There is a channel range in ur router..default it will be 6..this frequency might collide wit ur codless phone frequency & etc.. so change channel to 11..it will work good..
Sep 06, 2009 | Trendware TRENDNET TEW-423PI Wireless...
(Work this one out) My access point works but I have never been able to set security settings on interrogate it.
try typing 192.168.1.1 in your internet browser..the login and password are usually admin  and admin respectively.you can then configure further settings without using any cd etc.hope it helps!
Oct 22, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
Psp
The following items are generally required to set up to connect to a network.
  • A WLAN access point or a wireless broadband router
  • Settings for the access point (SSID, WEP key, WPA key, etc. as specified when the access point was configured)
  • A network device, such as an ADSL/DSL modem or a cable modem.
  • An account with an Internet service provider
Hints
  • An access point is a device used to connect wirelessly to a network.
  • A router is necessary if a PC and the PSP™ system will be connected to the Internet at the same time. A router is a device that enables multiple devices to be connected to one Internet line.
  • SSID, WEP and WPA keys are types of wireless network information. This information may be required when connecting to an access point or a router.
  • User is responsible for Internet service fees.
Example of a network configuration Network equipment connection and setup methods vary depending on the equipment used.
require001.gif Common settings hr1.gif You can create network settings for use in connecting to the Internet through an access point and save them on the PSP™ system. You can save up to 10 connections.
Setting methods may vary depending on usage conditions. The following is an example of commonly used settings.
1.
Check that the settings for the access point have been completed.
Check that there is an access point connected to a network with Internet service near the PSP™ system. Settings for the access point are typically set using a PC. For details, contact the person who set up or maintains the access point.
2.
Select in_networkset.gif (Network Settings) under in_setting.gif (Settings).
3.
Select [Infrastructure Mode].
4.
Select [New Connection].
5.
Select [Scan].
The system searches for nearby access points.
Depending on the model of PSP™ system in use, you may have the option [Automatic]. Select [Automatic] when using an access point that supports automatic setup. If you follow the on-screen instructions, the necessary settings will be completed automatically. For information on access points that support automatic setup, contact your local retailer.
standard001.jpg 6.
Select the access point that you want to use.
SSID is an identifier assigned to an access point. If you do not know the SSID or the SSID is not displayed, contact the person who set up or maintains the access point.
standard002.jpg 7.
Select the type of security that you will use.
The type of security settings required vary depending on the access point. For details on what type to use, contact the person who set up or maintains the access point.
standard003.jpg 8.
Enter the encryption key for the security settings.
The encryption key field displays eight asterisks no matter how many characters you enter as the key. For information on the encryption key, contact the person who set up or maintains the access point.
standard004.jpg 9.
Select [Easy].
Basic settings are set automatically.
standard005.jpg 10.
Enter a name for the connection.
You can choose any name for the connection.
11.
Check the list of settings.
standard006.jpg 12.
Save the settings.
13.
Test the connection.
If you select [Test Connection], the system will connect to the selected access point.
14.
Confirm the connection test results.
If the connection is successful, information about the network connection is displayed.
Hints
  • If the connection test fails, follow the on-screen instructions to check the settings. Network settings for the connection can be changed from the options menu. For additional information, refer to the instructions supplied with the network device and by your Internet service provider.
  • Depending on the access point settings, you may need to enter the system's MAC address to connect to the network. The system's MAC address can be checked under in_setting.gif (Settings) > in_pspset.gif (System Settings) > [System Information].
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Need help setting up an syslink G access point?
You could install the dd-wrt firmware, which gives you the option of being a repeating station. See www.dd-wrt.com for all the details.
With factory firmware, you must use a cable.
Jun 20, 2008 | Linksys Wireless-G WAP54G 802.11g/b...
NETGEAR WG111T 108 MBPS WIRELESS USB 2.0 ADAPTER stopped working
What are you trying to connect your USB wireless device to?
Is it to a wireless hot spot?
or to a Wireless Access Point/Router?
When you find a connection, what is the signal strength?
I assume you have configured your Access Point correctly as well as making it secure. You should connect a computer to the Access Point using a network 10BaseT cable to check the Access Point configuration, especially the wireless configuration.
If you are trying to connect to a wireless Access Point and you have a weak signal, move your computer closer to the Access Point or move the Access Point to a better and higher location to give you a better wireless coverage. Note, walls can affect the wireless signals between the Access Point and the wireless network card and wireless USB device, especially reinforced concrete walls.
Jun 01, 2008 | Computers & Internet
I can't get a connection
Try this WII setup guide:
http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Feb 01, 2008 | Trendware TEW-452BRP Wireless Router...
Trendware TEW-450APB (TEW450APB) 802.11b/g Wireless Access Point Logo
478 people viewed this question
Top Trendware Computers & Internet Experts
Prashant M
Prashant M
shaun taylor
alex metro
alex metro
Are you a Trendware Computer and Internet Expert? Answer questions, earn points and help others
