Question about Amana Radarange Microwave Oven
Amana Radarange: Can't Open Door (Broken Linkage)
The wire linkage between the door and the safety interlock on our Amana Radarange Touchmatic RS-40 (mfg. 1988) broke with the door closed, so now we can't get it to open.
After removing the sheet metal cover, I can see an access hole in the interlock, presumably to open the door manually. But I can't figure out how to make it work. Push something in? Insert something and move up and down or side to side? Insert and rotate a special tool?
I don't have and haven't been able to find a service manual. Can you help - how do you open the door with no linkage to the interlock?
Thanks, Mark
MicrowaveSvc
  • 9098 Answers
SOURCE: Instruction manual for 1986 Amana Radarange microwave
I think it will use a standard generic probe for the Accu-Temp. Sorry I couldn't help. Take care.
Posted on Jan 28, 2008
SOURCE: Amana Radarange Touchmatic Model RS55
That part is called a rotating ring. It is whirlpool part number R0131264 or R9900400. Good luck finding one, I'm looking for one too!
Posted on Jan 15, 2009
SOURCE: help setting clock on amana radarange microwave made in 1987
press Reset, then enter in the time of day (e.g. 0807 for 8:07 am or pm doesn't matter), then press Clock button twice. hope this helps.
Posted on Apr 11, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Amana Microwave stays on when I shut the door.
It'll be a bad door switch or a loose door switch mount.
See :
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
William E. Miller
prototech@usa.net
Posted on Sep 11, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: Is there any better resource for a door handle
The Amana / Whirlpool / Maytag part number is R0713642 and you can get it for far less at one of the places listed here.
Posted on Nov 25, 2009
Door release buton does not open the door
You can disassemble the microwave oven and check out the release mechanism. You'll find several hooks that hold the door closed and a linkage mechanism to the door opening button. There may be a broken piece of plastic or maybe just a loose or missing screw that holds linkage together. In the case of a broken plastic part, you can fix it with a 2-part epoxy adhesive, but you'll need to permanently splint across the break with a piece of metal or strong plastic that you've scavenged from somewhere. Before epoxying the splint in place, rough up all plastic surfaces where you want the epoxy to stick well.
Good luck.
Mar 16, 2015 | Panasonic Microwave Ovens
Interlock door switch
Bad secondary interlock door switch or switch mounting problem.
Nov 12, 2013 | Amana Radarange Microwave Oven
Door handle on Amana Radarange Model MVH100E1 came dissconnected at the bottom of handle. How do I reconnect it since it appears to have been riveted to the door?
I would use epoxy glue allow it to dry 24 hours for maxium bonding, clamp it in place for best results, otherwise the door would probably need to be replaced.
May 02, 2012 | Amana Radarange Microwave Oven
My radarange touchmatic 11 rr-10 has stopped working i have checked the fuse and renewed it but still has no power
2 things... the little microswitch can be open...
there should be three one is open Your door latches go into/betweem them.
.on the print it would be called the monitor..
replace that should work !
OR ...
yuo could have a open thermal cut out... them are located on the magnetron and on the oven cavity, they will look like 10_17_2011_2_31_08_am.jpgthese are microswitchs
just hook the new wire to same pins the one in the mico may ony have 2 use those same two on the new switck forget about the extra pin in.... you will see
a diagram on the side just do the new the same way N.O. or N.C...take your time .... please and pull the plug 1st
Sep 21, 2011 | Amana Radarange Microwave Oven
See :
William E. Miller
prototech@usa.net
Sep 09, 2009 | Amana Radarange Microwave Oven
Amana Radarange Touchmatic Model RS55 display 4444 and want go away.
Oct 24, 2008 | Microwave Ovens
Jan 14, 2008 | Microwave Ovens
Amana Radarange Microwave Oven Logo
164 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
