Question about Technics SL-1210MK5 Turntable
Help: Mk 5 Tone Arm
Hi, I have a set of MK5 turntables (Not MK5G's) and on of the tonearms has been bent in transit... I can buy a new one for about £40, but I have no idea how to go about changing it. Can anyone help with a guide or just explain the basics behind it. I would get it done properly but at £60 to have done, I would rather save the cash. Thanks in advance
  • mark standerline Jul 17, 2007
    Yeah thats what everyone says.
    Thing is it's £40 for the tonearm and then £60 for the fitting!
    Total of £100, which I don't have.
  • 515 Answers
Trust me when I tell you this... Get it professionally replaced. Spend the extra money. If you had to ask this question, then you do not posses the technical knowledge to repair this yourself. It's not an easy fix, and you will cause more damage than you already have. You will need to take apart the entire tonearm base, from the bottom of the turntable, and then remove 2 screws which hold down the tonearm. You will also need to unsolder 5 very thin wires. Unsoldering is easy, but soldering back on is harder for novices, and you could burn the PC Board - which is now discontinued.
You can purchase a replacement Technics Tonearm, and then bring it to your service technician for installation.
If you want to try and fix this yourself, you can check out the tutorial videos located here: http://djprolab.com
- OPTiC
The Technics Expert
Technics Repair
DJ Equipment
Posted on Dec 30, 2008
    Sergeant:
  • 274 Answers
Tonearms if not installed correctly can screw you your records over time. Personally, I'd pay the extra 20. Good Luck.
Posted on Jul 16, 2007
  • Jerry Hess Jul 18, 2007
    Here's the "manual" which you should already have but in case you don't here it is again.
    http://service.us.panasonic.com/OPERMANP...
    Each maker has their own design but the "tonearm" uses an universal "gimble" design. It's has a very sensitive balancing mechanism. It basicly stands by itself because it is balanced. Only a couple of small screws should hold it in place. Be careful of wiring. You will need an "alignment tool" to set the correct angle of the tonearm to the spindle initially. The alignment tool depending where you buy it or it's quality will cost anywhere from $20 $30 US. The rest is the easy part if you just follow the directions in your book which you should already be familiar with.
    Good Luck and I hope I helped solved your problem.
SOURCE:
Which are the best bearings for a technics mk-5, for the tone-arm
Hello Richard,
I'm sure your last name starts with a V. I doubt you will find bearing to fit this tonearm. Bearings the size of vertical or horizontal for a tonearm are going going to be long discontinued.Additional to that, you would need a bearing with a specific co-efficient of friction. As to putting them in, you would need a minipress, minivice, Panavice, or due to the size, you can probably use a drift and small hammer to set them. A pair of pliers would also probably work. Frankly, I've never seen one go bad, unless it was a Dual that someone really overtightened them. It just takes a fine touch, not a power drill. :-)
Aug 16, 2014 | Technics Audio Players & Recorders
Rewiring tone arm stanton st.150
Nice , i just received my tonearm wire for a technics. mk5
First question , Which tonearm are you try to put in and why, since if you want a better sound , sell the unit instead of useless replacements and do you use the phono or line out...
Feb 15, 2014 | Stanton Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Tone arm replacement
Any TV repair shop will be able to perform that repair for you as well as get any parts necessary. Steve Medley
Feb 07, 2009 | Technics SL-1210MK5 Turntable
Arm does not track properly but skips across records
Just guessing, but it sounds like you haven't counterbalanced your tone arm.  When a tone arm skips, it's usually because there's too much counter weight on the rear of the tone arm.  You want between 3-5 grams, but first you have to calibrate your tone arm (balance it so you know where zero is).  If you don't know how to do this, refer to the Ion directions called "Tonearm Setup" in the instructions.
Jan 03, 2009 | ION Audio iTTUSB Turntable
Difficulty balancing the tone arm on kd-1033 turntable.
A new stylus should not change the tone arm balance setting if it is the correct stylus.
Does your arm have a sliding balance weight at the rear of the arm? If so you can slide this slightly towards the cartridge to regain the correct playing weight.
I would suggest you get a repair shop to do this for you, or you could finish up damaging your records.
Jan 01, 2009 | Kenwood KD-291RC Turntable
1210 mk5g tone arm pin stuck
Hey raz, i've just taken apart and put back together my turn table trying to cure the same problem. I DIDN'T NEED TO!!!!
number 1) i think the tone arm is a sealed unit so far as i can gather so if the spring is broken you need a new tone arm. however. Get a cotton swab, soak in malt vinegar and use this to gently push the faulty contact in. The idea behind this is to get vinegar around the contact shaft. This should dislodge the dirt and release the contact.
Dec 18, 2007 | Technics SL-1210 Turntable
Tone Arm
It's very hard to get those screws aligned and tightened correctly. They are machine calibrated with the precise amount of torque. Once they become loose, it's very hard to get them back to original factory settings. Also, those screws are conical screws, which means they have a cone shaped tip on them. That cone shaped section sits on 4 very small ball bearings which balance the tonearm. There is a very thin piece of sheet metal which protects the ball bearings and keeps them aligned, if any of these parts are damaged, or bent in any way, your tonearm is damaged.
Unfortunately, if you can't get the balance correct, you will have to replace the tonearm. You can buy a new TONEARM HERE, however, replacing it, is a whole other process and not recommended if you have no soldering experience, as you could damage your unit even more.
Hope this helps.
- The 1200s Experts
Nov 17, 2007 | Technics SL-1200MK2 Turntable
Technic SL1200 M3D
1) This turntable either has bad RCA cables or a faulty tonearm - in either case, none are easy fixes. FYI, If you use Ortofon Concorde series, they are notorious for causing faulty connections with your tonearm, and eventually deteriorate your tonearm over time. So you might want to think about changing them if you get a new tonearm put on. If you use the Technics headshell, you are fine. 2) This turntable definitely needs to have the tonearm replaced. Once the arm comes loose from it's bearings, it's next to impossible to get it back to factory specs, and you will have skipping issues. Both will require professional servicing. Check out www.1200s.com if your in the NYC area.
Sep 07, 2007 | Technics SL-1200M3D Turntable
Technics SL-1210MK5 Turntable Logo
123 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
