Dynacord powermate 1000 mk1
My power mate 1000 has the following fault(s) good strong signal from the master line o/p so front mixer panel is ok, how ever, the problem is weak o/p on 'A' channel power amp stage. I've also seen the limter led on front mixer panel is on all the time. I 've spoken to polar audio tech's regarding fault(s), but they say mmmm, not had that one before! Has any of you tech guy's had this fault before, and as a service tech myself there is always one that drives you nutt's and some time's it does'nt hurt to ask for a fresh take on things.
many thanks. wayne.
  • Franzoni May 19, 2009
    I have a similar problem with my powermate 1600 mk1... ii know it's a long shot but could the wiring of the mic inputs on the older dynacord stuff be reversed to todays standard...? from what i can find on the net there was some dispute over the the wiring in pins 2&3 between the USA and Europe so is it possible it's a phase/polarity issue....
  • 579 Answers
SOURCE: NO FRONT PANEL DISPLAY
If the display processor has failed, you are out of luck, but sometimes it is just the backlighting (bulb or LED) for the LCD display or if if nothing in that circuit has voltage, then you can usually track down the power regulator for it and fit that.
Hope Ya Fix It!
Posted on Feb 08, 2008
  • 3 Answers
SOURCE: front speaker channel cut off
always check the audio cables with another set before you do anything else.
Posted on Jul 12, 2008
  • 119 Answers
SOURCE: No surround sound from my Denon 3805
well as long as all signals are routed through the Denon your on the right track, now what else you have to do is connect all devices to the reciever do not loop one device through another. Also you have to try the different surround fields to hear the one you like the best for music I use 5Ch stereo for movies the surround field varies based on the type of movie
Posted on Feb 25, 2009
smarthome2
  • 1114 Answers
SOURCE: I have distortion coming out of my front right channel of my AVR
Yes, sounds like your DSP chip has an issue. Not an inexpensive repair if that's the culpret. Around 400-500 to replace the chip. It's an awesome receiver and worth 300-400 in repair, however, a 3800 or 1800 can be had for 600-800 depending where you look. If you need more help, post a comment and I can help you some more.
Posted on Aug 13, 2009
c1apton15
  • 3400 Answers
SOURCE: i have a lexicon mpx100
Footswitch is just an option for activating MPX. There are a couple ways to connect, but easiest is to run cables from AUX outputs to MPX then return cables from MPX to 2 open channels, using them to apply effects.
Posted on Apr 01, 2011
I have to turn the master switch all the way on to hear the music and then my microphones are too loud
Watch videos on YouTube about proper setup of a mixer/amplifier. Proper level setting at the different stages of the mixer is important to balance. You don't give us a clue as to what music you are talking about... if it is from a device plugged into the tape inputs for instance, the fault is your source is NOT providing adequate line-level to those jacks and you are trying to compensate with the master level. The master level should probably be around60% up in normal operation.
Oct 29, 2011 | Yamaha EMX512SC Powered Mixer 500 Watts...
Dynacord Powermate 1000 Mixer MK1 manual, where can i get one?
Do you mean teh Powermate 1000 powered mixing board? Dynacord has the manuals for some of their products on their site: http://www.dynacord.de/en/products/7/5/29_powermate.html . The direct link to the manual for the PowerMate 1000 is http://www.dynacord.com/downloads/PowerMate2_Manual_Vs02.pdf . Note the English documentation starts on page 31.
I hope this helps.
Oct 01, 2011 | Electrical Supplies
Cdj will not play through mixer in stereo, mono only. Cables have been swapped from good deck to bad deck and problem still exists ,and deck has been swapped to the other side of mixer master channel to...
is your mixer switched to line and not phono some mixer have a switch at the back for the phono chanels, I dont mean the ones on to for to select what input you want,
its usualy a small slider switch next to the rca's sockets at the back
Jan 11, 2010 | Pioneer CDJ-1000 CD Player
Not working
If it is brand new, it is likely "pilot error" as setting these up if you are unfamiliar with mixers can be frustrating.
There are several things that must be done to have a working system. Correct speaker cables are one and the setting of all the knobs are important...
DO NOT REPLACE FUSE. If any LED's are on, fuse is OK. If fuse blows, service the unit before replacing fuse to avoid further internal damage.
Make sure speaker cables are good.
Set the level control for the channel you are testing up AND you may need to press the "PAD" button to change the input gain. Turn up the master gain.
Depending on the source you are using, line or mic you may need to change the PAD button.
NOTE: This mixer does NOT have Phantom power and cannot be used with CONDENSER microphones requiring phantom power. You will get no audio from a condenser mic without phantom power. You must use dynamic mics with this mixer.
Jun 12, 2009 | Behringer Pmp3000 16 Channel Audio Mixer
No signal going into mixer.
Did you buy the gear new? If not, the issue might be with the meter. Also, sometimes the signal isn't loud enough to engage the meter, so try cranking up the Trim and Volume (Master & Line), of course, make sure the volume on your amp is down, so you don't blow anything.
Good luck.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Feb 04, 2009 | Technics SL-1210 Turntable
Generator doesn't excite with small power tools.
Somewhere on the Generator is an Idle Control switch, turning this to the off position will stop the generator idling down in the first place. You'll need to do this to use tools that don't draw enough current to trip the idle control system into revving the engine.
It may say just how much current you have to draw in the manual (hint, hint).
Nov 18, 2008 | Coleman Powermate Premium Plus 6250W...
Mackee PPM808M 1200 How to set the equalizer
Each channel strip has its own 3 band EQ with knobs that effect the hi, mid, and low.
The mid is centered at 2.5kHz and gives you 12dB of boost or cut in either direction, the high gives you 15dB of boost or cut from 12kHz and up, while the low gives you 15dB of boost or cut at 80kHz and below. At their mid positions these knobs are flat (no cut or boost).
The PPM808M also has two 9 band graphic EQs in the Master Output Section on the front panel, Monitor EQ and Main EQ. These two EQs are the last thing in the chain before the signal leaves the mixer on either of these line outs (monitor line out, or mixer line out).
The 'Monitor EQ' effects output to the monitor speakers on stage (and power amplifier if the 'Power Amp Routing' switch is pushed in).
The 'Main EQ' effects the signal to the main speakers (or the mixer line out).
Each of these 'Master Output' EQs has a Rumble Reduction button which when pressed in engages a low-cut filter which rolls off frequencies below 75Hz and is designed to prevent 'stage rumble' from things like footsteps on the stage being picked up by stage mics. These filters are separate from the graphic EQs and the Main Rumble Reduction switch effects only mono channels 1-6 (not stereo channels 7&8). It also has no effect on the EFX to MAIN or the TAPE IN. The Monitor Rumble Reduction switch however does effect the EFX to MON signal.
Dec 31, 2007 | Audio Players & Recorders
New to PA systems......
What brands are we talking about my friend?
Oct 09, 2007 | Audio Players & Recorders
987 people viewed this question
 Grubhead
Grubhead
