Question about iLO 2600 Television
To whom It mat concern I have ILO LCD comes on but no volume
No channel no menue just blue screen,whats wrong thank you.
I having the same problem I tried calling customer support but they said I would have to call another number that was on the manuel and I dont have a manuel.
Posted on Jan 15, 2009
The remote quit working and the only thing working manually is the off-on on the tv, no others on the tv, no sound, no channels etc.still have a picture and only low volume, will not adjust-NOTHING on the...
Can you get the menu to come up on the screen? If not it sounds like you have a bad av main board.
Open it up first to make sure all connections are good before though. If they are good check th epart number on it and google it to see how much another one is ...
Thanks,
michael
Apr 05, 2011 | iLO 3200 32 in. LCD Television
ILO LCD Color HDTV does not change channels / volumn...just turns on/off
The symptoms your TV is experiencing is due to a power supply that is not longer providing the 5 volts properly to the circuitry.
It seems to be a common failure on these TV sets.
Apr 29, 2008 | iLO 3200 32 in. LCD Television
Ilo tv shows no tv signal, I believe that the channels are deleted but don't know how to add the channels back
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Jan 08, 2010 | iLO IWT3206 TV
Turns on .encripted channel comes up. cant switch channels
threw the damn thing in the trash. will never buy another ilo tv. this is the replacement for the first set that quit working. thank you
Feb 18, 2009 | iLO 2600 Television
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Magnavox 37mf321d/37
The only way that I know of to eliminate this problem is to buy a new TV. My ILO TV has been repaired twice since May 08 and it went out again for the third time. The problem starts out as an intermittent problem.... You turn the TV on, the audio is fine but there's no picture, you will be unable to change the channel or volume whether you're using the remote control or the buttons on the TV.
This TV should have been recalled. Don't reward the manufacturer and retailer for their bad behavior, buy your next TV from a different retailer.
Sep 26, 2008 | iLO 3200 32 in. LCD Television
Matsui mat 140mr
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Feb 08, 2008 | iLO (2 GB) MP3 Player
Cannot change channels
Hi! I have been through this situation on a 26" model of ILO LCD TV. I think the problem you have is the same, but could you clarify one thing for me? Is your model an ILO-3200, or is it an ILO-32HD? I suspect 32HD, because I know the problem exists on the 26HD models which are basically very similar in design and say manufactured by Initial Technologies on the back of the set. Does your unit list this manufacturer on the back? Let me know. Thanks!
Sep 30, 2007 | iLO 3200 32 in. LCD Television
Add me to the list also, this was the worst electronic purchase I've ever made. The 26' HTDV worked for 1-year.
Will not resond to change channel, volume, menu access.... neither from TV or remote. Just turns on and off. The channel it is set on work fine just can't adjust.
Aug 09, 2006 | iLO 3200 32 in. LCD Television
Televison & Video Logo
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
