Question about Dryers
My tumble dryer is spinning but no heat. I have tried holding in the start button for seven seconds as suggested in some places on the web with the cycle choice on delicate to reset but to no avail. Any ideas would be appreciated "Beko Sensor Drying 6kg" 6kg tumble drier
  • Anonymous Mar 16, 2014
    The switch on my Beko Condenser Drier is stuck in. Help please
    Genius:
  • 2,920 Answers
It sounds like either your heating element went out or your limit switches are bad
Posted on Jan 14, 2009
Hi. My tdvcw bush dryer is turning but not heating up. The temperature light is flashing. There is no reset button on back of dryer. I have a child and need clothes dried. Thanks in advance
My tumble dryer is not heating up! - 24'7 Home Rescue
https://www.247homerescue.co.uk/my-tumble-dryer-is-not-heating-up-2/
My dishwasher won't fill with water! ... My TV will not turn on! ... If your tumble dryerdrum is not heating up, but the drum is spinning normally, then you might be ...
Tumble dryer not heating - White Goods Help
Jan 25, 2016 | Dryers
Got heat just no tumble belt is on
Try holding the door switch and having someone start the dryer. If you spin the drum by hand with the door open and it takes off spinning, you have a bad/jammed motor. 300-400 dollar repair someone else would be better off doing. 4 hours to figure it out. 130 dollar part on the internet.
Nov 26, 2013 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Kenmore dryer just hums, wont tumble
Try this:
Open door. Hold door button. Have someone push start button. When they push start button, spin the drum wiht your hand. If it starts working, the problem is the start windings in the motor are not being energized. Could be capacitor but not all motors use them. Could be the syntrifugal switch in the motor or something else in the starting system. May want to think about getting another dryer from a place like Lowes. They are usually around $200 and up for a good one.
Good Luck
Dec 03, 2009 | Kenmore Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
GE Adora Dryer spins but no heat
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Aug 05, 2009 | GE WSXH208A Front Load Washer
I have a zwd12270w. Seven second after pressing
The problem is with the tumble drier heating element. If you remove the top of the machine (disconnect it from the electricity supply first!) you will find a big metal oblong "bar" that runs from the front to the rear of the machine. At the rear there are 4 white wires connected to the metal "bar". Make a note of where they go and remove them. You may need pliers to get a good grip of them. Once removed, the washing machine should work just fine but obviously the tumble drier will not. This is a well known fault and it may be worth contacting Zanussi as they MUST know about it!
Jun 28, 2009 | Zanussi ZWD12270 Front Load Washer / Dryer
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
New Dryer Belt
The switch on motor is sticking or broke. You can try cleaning lint from motor and around switch. (Box with wires going to it on motor.) If this doesn't work you probably need a motor.l
Nov 07, 2007 | Amana ALG331RAW Gas Dryer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Dryers Logo
1,232 people viewed this question
Top Dryers Experts
