Question about Toshiba 61H71 61" Rear Projection Television
Toshiba model 61h71 red light comes on /no picture or sound
To TV Genius,
I have a Toshiba model 61h71... Worked fine then pushed power and the red light would come on and blink but nothing after that no picture no sound...it's like it can't boot up?
Wife came down with breast cancer 2 yrs ago at 34 and 4 young daughters..very fixed income for the moment..need a cheap solution.
Thanks,
D.Phillips
  • 3 Answers
We had the same problem, open the panel on the back of the tv, the board on the left, not the one with the convergence chips. Inside the tv u will see a piece of paper with the fuse info. The board on the left unscrew it and flip it away from you, the fuses to test are at the bottom, on the circuit board it will say 125volt 5 amp, and the number starts with an f. they are small and rectangular and black. Check all but the 3 at the bottom are usually the culprits Hope this helps u
Posted on Mar 24, 2009
Red power button blinking but tv won't power on
chec your ic register diode and transistor.
aslo check poer supply waltage and earthing properly.
Oct 11, 2008 | Toshiba TZ50V61 50" Rear Projection...
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
The red power on light just blinks. Tried leaving it unplugged. Still didnt work
Ours was doing the same thing, we changed 3 little black fuses in it and it works. I do believe they are 5 amp but not positive, we found them through a tester. When I have the exact answer for u I will email u again sorry u have had no response till now probably does you no good now..It's been awhile since they were changed.
Nov 01, 2008 | Toshiba 61H71 61" Rear Projection...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
Red Shadow on Picture
convergence ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 14, 2008 | Toshiba 61H71 61" Rear Projection...
Picture problem Model Toshiba 61H71
Hi, convergence circuit has failed, IC`s and probably 1 or 2 precision resistors will have to be changed, not really something you can fix if your not an electronics tech, BMW Rider
Jan 09, 2008 | Toshiba 61H71 61" Rear Projection...
Blinking power light
Our 61H71 just did the same thing! I have found on another site where a fuse on the Convergence board was replaced as a fix for this issue...however, fuses are usually symptoms not causes...it is very difficult to find availabe information on this issue...it may be time to call a professional...Good Luck!
Nov 18, 2006 | Toshiba 61HX70 61" Rear Projection...
Toshiba 61H71 61" Rear Projection Television Logo
372 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
