Question about OfficeMax Office Equipment & Supplies
Paper does not pull through.
Husband took it apart and a bushing is broken.
Decided to buy a new shredder. Recycling the old. You have to know when to fold. Thank you.
Posted on Jan 15, 2009
I have rethreaded my machine and now the left needle thread isn't catching
Hai, Some times broken some small parts, wacher inside. So please check the left needle inside parts.
Apr 05, 2014 | Brother 929D Mechanical Sewing Machine
Replace shift linkage bushing on 2002 trailblazer
All that was wrong with my 2002 Trailblazer was a 6.00 part my husband bought at PepBoys! It's the plastic grommet/bushing that broke that holds the shifter cable to the linkage...took him 10 min to fix!
Mar 01, 2012 | 2002 Chevrolet Trailblazer Ext
Copy machine keeps wrinkling paper. No more jams says ready to copy and then when the paper comes out it is all wrinkled up. I have taken it apart and took air can and find a tiny piece of paper, took that...
The problem seem to be the fuser roller unit. If you know how to disassemble it ( it may be hot - take care), examine the pressure roller to see if it has the balance required of it and the 2 bearings holding the top teflon roller in place.Lubricate the 2 bearings and the collar or bushing holding the rollers in place.
Also check the tension springs on each end for even balance.
Feb 22, 2011 | Sharp Office Equipment & Supplies
How to take apart the toy after it has been put together
The instructions say it can't be disassembled but it can! First you need to find a small hole on the neck just below the head. I used a paper clip to push a button inside the hole while my husband pulled up on the head and it popped off. Then unscrew the screw on the neck. Then take the paper clip and push on the button inside the little hole by the emblem below the neck while someone pulls on the neck. It will pop off. Next my husband took two keys to push on the buttons on the feet while I pulled the feet off. We had to do one side at a time. Then just take the seat off like you are adjusting it and that is all. We couldn't find a way to take the peddles off but it was broken down enough for us to pack:)
Dec 25, 2010 | Vtech Ride and Learn Giraffe Bike
1999 Saturn SL2 manual transmission stuck in gear, shifter moves freely. Where could the problem location be...under car or do I need to take out the console to locate problem
The problem is the bushing that attaches the cable to the shifter has failed. This is a plastic bushing and can be reattached if the tabs are not broken. You need to remove the console to access the cable end, the bushing goes through the plastic cable end and snaps on the ball attached to the shifter. There is a stainless replacement part available on line for $29.00 check satarnshifterbushing.blogspot.com
Jul 25, 2010 | 1999 Saturn SL
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bizhub 200 Error Code C0202
I fix the error thanks to Patrillica on my BIZHUB 350!
The paper stock in tray 1 or to be exact above the tray 1, when you open it, you can hardly see it. After you remove the paper you should unplug your machine and then lug it back.
Thanks again to Patrillica.
Mar 29, 2008 | Minolta bizhub 200 All-In-One Printer
60 people viewed this question
Top OfficeMax Office Equipment & Supplies Experts
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Randy Schumann
Randy Schumann
Are you an OfficeMax Office Equipment and Supply Expert? Answer questions, earn points and help others
