Question about Cobra 29 LTD CB Radio
Cobra 25 LTD - building causing a shadow area
We have just bought a Cobra 25 LTD for our guard shack at work to replace a base-station (can't remember the name of the base) it seems to work fine except when our truckers go behind the building to our loading docks they can't hear us we can barely hear them. It is connected to a huge antenna(approx 10-15ft tall). above the guard shack The specs on the Cobra says it's 4W is that enough power for the huge antenna ??
I'm thinking that we should have purchased another base station, or a booster for the CB, either way it looks like we purchased a cheaper solution that works 50% of the time. (Wasn't my decision but I get tasked to 'make it right')
We put in a wireless alarm beacon about a year ago that is UHF I think it was 900MHZ, with a small antenna it is 2W transmit power, it worked through one half of the building but had to have a repeater in the middle to get to the other side.
Another piece of the puzzle, the guard claimed that if the truckers keyed up while right near the guard shack it would pop the fuse on the Cobra ?? That's something the old base station didn't do.
I don't have a peak meter to see if we're getting the full 4W, any help you guys can give will be greatly appreciated. I haven't fooled around with CB in years, I think I had a Cobra several years ago and it seemed like it would transmit for MILES no problem, the building does pose a lot of EMF and noise, not to mention the concrete and steel so it doesn't really suprise if 4W isn't enough.
    New Friend:
  • 3 Answers
One thing to remember is any structure can block or reduce signal strength and reception. If you had reception before and now you don't or it is greatly diminished, start with the basics. Check antenna and the antenna wire (coaxial) for damage and be sure the connectors are still good. Check the SWR's, and finally you may want to have the new radio peaked N tuned. This will increase the receivers sensitivity and boost the output a little more. The radio out of the box is not adjusted to peak performance. After you've done these things and you still cannot be heard on the far side of the building, check the area around the antenna for anything that may be blocking or deflecting your signal. (flag poles, phone lines, etc). And finally, go on the other side and see if there are new structures or maybe the company installed a new alarms system which sometimes can dampen RF signals. I hope this helps!
Posted on Mar 27, 2013
    Problem Solver:
  • 9 Answers
The older base station was probably peaked and tuned by a CB shop, basically giving it a lot more power. Stock radios very rarely have a full 4watts of power, to tell you the truth. Mine now does 5 1/2 watts and swings to around 20 when I talk. Might be a good investment. Oh, the antenna can't be too big for any wattage. Might want to recheck the antenna's tuning, though...
The truckers wont pop the fuse at all, but I might recommend backing your RF gain down some when they are that close so they dont burn up your receive.
Posted on Jan 15, 2009
I have cobra 25 ltd and i,m picking up signals from hundreds of miles away can i tune it down to pick up more locally
Try turning down the RF gain. It is the 2nd knob to the left of the channel selector. This will limit skip stations and receive only local higher signal stations to come through. Do not turn it too low or you won't hear much of anything. Hope it helps.
Tom
Oct 01, 2012 | Cobra 25 LTD 40-Channels Base CB Radio
Need the power cord Corbra 25 LTD
Hi, my name is John. Welcome to FixYa. You can get it at any Radio Shack or your local road side CB shack for about $4.00. Thanks for choosing FixYa, cheers...John
Nov 13, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 25 only transmit and recieve on ch 1
Hi, my name is John. Take the cover off the unit, and check for broken trace or loose solder joints around this area, ...hope this was helpful..Rate this solution on the four thumbs-up.....John
Jul 12, 2010 | Cobra 25 LTD 40-Channels Base CB Radio
COBRA 25 LTD spikes without keying mike
buy a different cobra 25 4 pin mic and try that . If that doesn't work than you inherited a piece of junk .
Jul 29, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
I Cant Pick Up Any Signals On my Cobra 25 LTD 40-Channels Base CB Radio all i hear is nothing. no truckers saying stuff. i just get white noise i do have an antenna. it is a tv antenna w/ bunny ears :) i...
Your problem is probably the rabbit ears. They are for tv in the 54+
Mhz and CB is 27 Mhz. For simplicity, go to Radio Shack and get a back of the radio indoor antenna. They run under $20. If you want to get more; try a roof antenna or a 1/2 wave cb marine antenna outside.
Hope it helps.3
Tom
Jul 19, 2009 | Cobra 25 LTD 40-Channels Base CB Radio
What Voltage Does The cobra 25 ltd classic use?
12 volts, around 15 amps. For a base station, try an Antron-99 groundplane antenna.
I have a cobra 25 ltd can i turn up the power without bringing it to someone
so what your asking then if you can increase the signal strength so I goes farther? If so then you can go to any radio shack and buy a signal booster that hooks up through the anntena line.
Dec 19, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
Older Cobra 25 ltd
did the gauge stop working or the radio. the gauges on older radios fail quite often . you can order replacements
Aug 11, 2008 | Cobra 25 LTD 40-Channels Base CB Radio
No sound
The Cobra 25 requires the mic to be working for any sound to come out. My suggestion is that you first try a new mic. If this doesn't work, look real close at the board on the soldered side ( around the if section, thats the area that right under the waxed area on the component side of the board ) for cold solder joints ( broken lead solder) You may need a magnifing glass. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 17, 2007 | Cobra 25 LTD 40-Channels Base CB Radio
Cobra 29 LTD CB Radio Logo
162 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
