Question about Epson Stylus CX3200 All-In-One InkJet Printer
PRINTER ERROR COMES UP - SAYS SEE DOCUMENTATION & CALL SERVICE IF
WHEN I TURN THE MACHINE ON IT MAKE A LOUD MOTOR LIKE NOICE AND THE PRINTER ERROR COMES UP!! I DO NOT HAVE THE DOCUMENTATION THAT COMES WITH THE PRINTER SINCE IT WAS GIVEN TO ME USED.
The ribbons to my printerhead Kodak 3250 have become detached, has anyone any idea how to reattch them?
Posted on Aug 19, 2011
    Problem Solver:
  • 7 Answers
E pson are very naughty when it comes to printers as when the have done 60-70,000 prints something tells you that you need to take it to engineer to fix the problem. All they do is connect it to programme of theres and it resets the counter to zero.Most people just throw the printer in te bin and buy a new one.This could be what is happening to your printer.This means that people will go out and buy one of theirs.I have had the same problem.
Posted on Jan 23, 2009
  • Epson Master
  • 419 Answers
This is a "General Error" issue, not a service required one.
It's likely that either a sensor in the printer is damaged (possibly a ribbon cable has come detached)... or more likely there is some foreign body or printer part that's come loose and is blocking the printhead carriage path.
A common one I've seen with the C86 and similar is for the head cleaning part become detached from the parking pad (all based far right)... When it does this it springs up into the printheads path and stops it from reaching the parking position.
It requires patience to fix (and some rubber gloves to avoid ink mess) but if notice a part doing an impression of a jack in the box then you can usually gently push the part down and then careful maneuver it over to the right into a connection with the parking pad part.
It's hard to describe without pictures but it gives you an idea of what to look for.
Posted on Jan 22, 2009
I was using my sewing machine when there was a loud cracking noise-the needle had broken and I replaced it but now the machine won't work. When I press the pedal I can hear the motor whirring but the...
Have you pulled apart the bobbin race area and checked for any bits of broken needle?
Is the clutch disengaged on the flywheel?
Otherwise, was the loud cracking noice coming from inside the machine case in which case it could be a gear internally that went and the needle breaking was just the result of this, in which case, time for a road trip to the service tech.
Mar 03, 2011 | Brother XL-3500
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Loud clicking during spin cycle = Maytag washer PAVT234AWW
Try these
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
pls rate my suggestion....
Jul 19, 2009 | Maytag Performa PAV2200
Copystar 1810 document feeder slips grinding noice
Sorry Mike,
No spare parts are available.
Jun 27, 2009 | Copystar CS-1810 Copier
Machine drum makes loud noice in the spin cycle. Makes the same sound that a top-loading machine makes when it goes out of balance. Help.
  • Hi,
  • Try these:
  1. Balance the load
please rate my suggestion...
May 20, 2009 | Kenmore Washing Machines
Red light error
OFF the printer.open the top cover whole scanner unit .then look at the black base where usually cartridge moves when the printer is ON when you give printouts..press that black base and it will move little bit down .that whole black base comes little bit up due to some reason and when the cartridge holder moves from left to right for its internal allignments/adjustments it clashes that part somewhere and make such noices.and gives the service error..just press that whole 7- 8 inches base where the cartridge moves slowly ,carefully and firmly.then ON the printer and check.do it again if it does not becomes ok after first time.
rate the solution if it helps
thanks.
Nov 04, 2008 | Epson Stylus Photo RX500 Printer
Need help
either its the error in your circuit board so call the epson service center.
or try this
OFF the printer.open the top cover whole scanner unit .then look at the black base where usually cartridge moves when the printer is ON when you give printouts..press that black base and it will move little bit down .that whole black base comes little bit up due to some reason and when the cartridge holder moves from left to right for its internal allignments/adjustments it clashes that part somewhere and make such noices.and gives the service error..just press that whole 7- 8 inches base where the cartridge moves slowly ,carefully and firmly.then ON the printer and check.do it again if it does not becomes ok after first time. hope this helps........
thanks.
Sep 25, 2008 | Epson Stylus Photo RX500 Printer
Epson Stylus CX3200 ( loud noise like paper is jammed) error message comes up.
By pulling the paper out backwards your sister may have caused a gear to jump. You could try pulling a piece of paper out in the other direction and maybe the gear will jump back into place. Otherwise you will probably have to have the printer serviced.
May 09, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
179 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
