Question about Canon S400 InkJet Printer
Printer identity crisis
When I switch my canon S400, it now identifies as a BJ F360. This has happened after the waste ink full error code was reset. Apparently the F360 was the japanese version. Can anyone help me to solve my printer's identity crisis.
  • Terry Kokkeler Jun 16, 2007
    As I cannot locate a driver for a BJ F360,I cannot use the printer. If the model identifier can be accidentily changed from S400 to BJ F360, it hopefully can be changed back. Sarcasm solves nothing. Can anyone offer a solution. Thanks in advance.
  • Terry Kokkeler Jun 19, 2007
    Problem solved. Had to uninstal printer, roll back driver, disconnect printer, manually instal driver for S400, then reconnect printer. This sequence only, worked. Why?, Who knows, who cares, it worked. Thank you.
    Genius:
  • 2,985 Answers
Does it matter? It does not turn your prose into pictgrams does it or images into picures of Fuji in the spring?
Posted on Jun 14, 2007
  • john ash
    john ash Jun 16, 2007
    You said 'Sarcasm solves nothing'
    I am not being sarcastic
    The driver should be common
    If you have printer software installed- uninstall it.
    Go to/Start printers/faxes- where you see the installed printer- delete it[right click delete.]
    Leaving the printer attached- new hardware found should come up.
    Ignore the CD- to find on list
    Select make - Canon
    Select Model S400 [BJF360 may also be listed] make your selection and click install.
    The Canon Web site may be helpful
    Also www.fixyourownprinter.com
    may help
  • john ash
    john ash Jun 19, 2007
    The drivers installed in the O/S libary are the bare escape items - no frills
    As I mentioned these work.
My printer shows E 2 7. how can i fix it?
i believe on this model the error code means that the ink tank is full...
http://www.mediafire.com/?s2pa54m5z2wqwru
this is a link to my hosting site where you can download the software reset tool for a the MP models...
To reset waste ink counter at printers canon pixma MP150, MP160, MP170, MP180, MP450 and MP460 there any 2 choice, that is :
  • Start with printer on then run this software
  • Click Reset Main (main) to reset waste ink counter and then click Reset Platen button (additional)
Additional information error codes for the MP models...
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 – Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error – USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
Aug 07, 2010 | Canon PIXMA MP150 All-In-One InkJet...
My canon ip1980 appears error 5100 on my display i will replace my data strip but the problem still occurs. What should i do. Tnx
This problem is between waste ink absober full and ink cartridge.
Firstly your need to reset waste ink absober full.
Follow this step to reset waste ink absober full.
1> download iptool to reset waste ink absober full
Download here ----> Service tool 1
Service tool 2
After ypur download finish
> turn off your printer power switch
> open your printer cartridge door
> press and hold on/off button (never release)
> turn on printer power switch
> push your printer cartridge door switch with pen or anything can press that door swith.
> then release on/off button
> close open door
> then press on/off button 1 more
now your printer is in normal mode( no orange led blinking)
Then you can use ip service tool to permanent reset waste ink absober full.
IF after reset your waste ink absober full, problems still apppear error5100
> change your ink cartridge with the working cartridge
usually error e5100 due tow problems above
Hope this guide can help fix your problems
Extra download
Fixwasteinkabsoberflow
Jun 23, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Receive message 345 and alarm which prevents operation.
Other Canon models "may" be repaired with these instructions also, for example MP370, MP390, etc. Try with your own risk.
Symptoms:
-Grinding noise (very loud)
-Flashes error code ##345
Error code ##345 = "BJ cartridge head cleaning error" -reasons for this are:
-Foreign material or dried ink in head cleaning unit (also known as "purge unit") , or waste ink pump jammed up. Make sure waste ink pump rotates freely, after cleaning. Clean the waste pump-hose too! Waste ink pump is located under head cleaning system.
Short solution:
1.Take apart and wash the ink clogged mechanical parts. Use hot water.
2. Reset waste ink counter
purge unit: HM1-0723-000
see more parts: http://www.e-parts.fr/pictures/uploaded/files/MP_360_370.pdf
I hope this is useful
Sep 25, 2009 | Canon MultiPASS MP390 All-In-One InkJet...
My printer needs to have the waste ink reset how do I do this
You can try this....
  1. Turn off Canon S300, S400, S9000 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon S300, S400, S9000 Printers should respond as normal.
But this happens because the waste tank is full. You need to locate it and use a paper towel to absorb the waste ink. Whenever the printer cleans itself ( when a new cartridge is installed, for example) some ink is cycled into this chamber. So if you reset and it is full, overflow may occur.....
Jul 23, 2009 | Canon BJC S300 InkJet Printer
Error code E-5
Found this, it may help you Procedure to reset Printer canon MP145 and Canon MP160 with Error Code Message for Printer Canon MP145 and Canon MP160, you can find error code message the end of this post:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding the Stop/ Reset button.
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a service mode. (Waiting for menu selection)
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset
5) Unplug cable power. (for MP145 / MP150)
6) Turn Off Power. (for MP160)
Error Code :
E3-3 = Paper jam
E4 = No ink
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E29 = EEPROM error
E35 15 = USB Host VBUD overcurrent error - USB
May 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
E8 Waste ink absorber full, or platen waste ink absorber full
Apr 24, 2008 | Canon MP140 PHOTO AIO All-In-One InkJet...
Canon mp160 E2; printer won't re-set
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
button pressing
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Feb 16, 2008 | Canon PIXMA MP150 All-In-One InkJet...
This is a Canon PIXMA MP 780!!! Waste Ink Full Problem
You can try to read these articles on how to reset the waste ink full error on canon printer. http://www.fastrepairguide.com/waste-ink-full-error/how-to-repair-canon-ip1000-waste-ink-full.html http://www.fastrepairguide.com/waste-ink-full-error/canon-waste-ink-full-error.html They even provide the service tool program for reset the printer eeprom data(set as factory default).
Sep 10, 2007 | Canon I990 InkJet Photo Printer
Canon S400 InkJet Printer Logo
191 people viewed this question
old marine
old marine
