Laptop hard drive crashed last year, I have some docs I would like to remove from it, however, using a hard drive enclosure with usb connection keeps giving a warning "e" not accessable parameters incorrect?
  • 827 Answers
Hi Sandfun,
This tutorial describes the procedure to recover one volume when
  • the volume was accidentally formatted
  • Windows reports the volume is "raw filesystem", or "not formatted"
  • An external drive failed, either flash (so called "thumb drive") or an hard disk connected using USB or FireWire enclosure.
  • MFT is corrupt on the NTFS volume, rendering filesystem partially or completely unreadable
The recovery is done in seven steps, requiring about eleven (11) mouse clicks.
Note: The older than current versions of ZAR might have been used to create the screenshots in this tutorial. We did not update the screenshots if there is no significant difference between older and current versions. If you see some option in the program which is not described in the tutorial, just leave it at its default setting.
Download and install ZAR just like you do with any regular program.
When you run it, ZAR displays the window like the one below:
Hope this helps
Chris (ziraffa)
Posted on Jan 14, 2009
My HP DT2000i external hard drive won't fire up and, when the power is connected, the blue light simply blinks constantly. Before, it would only blink when the computer was reading it. It's not a...
There may be trouble with the drive controller hardware in the enclosure. If the drive is no longer in warranty, you may be able to recover the data on the drive by removing the drive from the enclosure and installing it into a docking station or directly into a desktop PC. I am attaching a YouTube link on how to disassemble the enclosure.
Disassembling HP SimpleSave External Hard Drive
Jan 20, 2015 | HP Computers & Internet
I want to download all info from my desktop and motherboard into mylaptop
Hi Eva!
If your desktop is crashed, then you will need to verify if its internal hard drive is still working, and then conect it using an USB/SATA/IDE adapter to your Laptop. This is one: http://www.sataadapter.com/SATA-IDE-ATA-66-ATA-100-ATA-133-COMBO-ADAPTER/sata-ide-adapter-usb-hard-drive-sata-drive.html
If the problem with your desktop is with its hard drive, then... you need to take your computer to its manufacturer technnical service center.
Sep 27, 2012 | Sony VAIO PCV-W600G PC Desktop
My HD was having problems staying conected through the USB. I would have to force upward to get a connection that would last on my computer. After a while the whole USB connection on the HD disconnected!...
I am assuming a few things here, so keep that in mind.
I suggest that you go purchase a hard drive external enclosure for your drive type. They are relatively inexpensive, say, 20 to 60 dollars. You can get them from Amazon, NewEgg, and many other online retailers. Go with a site that you trust and has a good return policy. You could also just drive down to your local Walmart or BestBuy and pick one up too (you will pay a little more).
Most external USB drives are simply an enclosure with a "normal" SATA hard drive inside, some hard drives are 2.5", some are 3.5" in size. You should also consider the speed of your computer's USB ports (2.0 or 3.0) when purchasing your new external enclosure.
Once you purchase that, you will need to remove your hard drive from the broken enclosure. Usually, there are just a few screws holding it together. Be aware that sometimes they cover the screw holes with stickers. Remove the hard drive and install that into your new enclosure. Your data should all be intact. Try this using the same computer or the same operating system to verify your data.
I hope this helps. :)
Richard
Nov 16, 2017 | Iomega Prestige 500 GB USB 20 Hard Drive
My Metal Gear Box external hard drive has a flashing blue light, and my computer does not detect the external hard drive, what is the problem?
the weird cheap power supply they used has failed. I will never buy another galaxy product. This whole time I thought the hard drive crashed, but it was the enclosure all along that died at about a year.
Nov 14, 2010 | Galaxy External Enclosure - Metal Gear Box...
Dead processor. good hard drive
get external hard drive shell, place the hard drive in it, the connect via firewire or usb all your info should be intact except if its a crash
Mar 23, 2010 | IBM ThinkCentre A50 PC Desktop
My computer crash and I need to transfer my desktop hard drive info to my laptop hard drive
install the HDD to other desktop and grab the files or if you can buy USB interface to your hard drive like hard drive enclosure. then you can connect the hard drive to your laptop
Mar 13, 2009 | Dell OptiPlex GX270 PC Desktop
IRQL_NOT_LESS_OR_EQUAL
1. purchase a 2.5" usb enclosure.
2. remove your hard drive and install in the enclosure.
3. plug the enclosure into a working computer and copy or move your important files onto working computer.
4a. reinstall the laptop hard drive and try a repair installation by booting from the XP cd. (if you are running xp)
4b. reinstall the laptop hard drive and try booting to Last Known Good Configuration. Press either the F5 or F8 key while rebooting to get to the menu.
4c. purchase a new hard drive and reinstall the OS using the reinstallation cd's
Dec 09, 2008 | Dell Inspiron 1501 Notebook
External hard drive will not turn on
Try a new enclosure, the case is just that. A hard drive cannot actually repaired. You cant open it and fix it. It's either reliable and functioning or not. Purchase a new enclosure and test the old drive. Data recovery should be the last option..most places charge a down payment on a car, and most of the time ( in my 12 years ) its the cheap enclosure.
Keep me posted.
Oct 08, 2007 | Acomdata (HD250UE5-72) (HD250UE572) 250 GB...
Computers & Internet Logo
121 people viewed this question
David Payne
David Payne
