Question about Canon imageCLASS D880 All-In-One Laser Printer
Feeding sticks on top tray
When you insert originals in the automatic feed they stop after one inch. This is a D761 not an D880.
  • 72 Answers
It sounds like you need an adf roller assembly
Posted on Jan 16, 2009
HP LaserJet 1012: The paper has stopped feeding. I hear the feeding mechanism rolling, but the paper does not feed.
Check the adjustment of the guides in the paper tray. There should be about an 1/8 inch of play from front to back so that the sheets of paper so they can be lifted from the tray. If the stack of paper is snug, move the rear guide back a little bit.
Feb 27, 2011 | HP LaserJet 1012 Printer
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
Paper not feeding properly
Follow these steps to reload paper:
  1. Remove the paper and make sure it's not curled or wrinkled.
  2. Fan the stack to make sure the sheets are separated.
  3. Open the paper support and pull up the extension.
  4. Extend the output tray.
  5. Flip the feeder guard forward. Squeeze the edge guide and slide it left.
  6. Insert paper, printable side up and short edge first, against the right side and beneath the tab.
    You can load up to 100 sheets of 20 lb plain paper or up to 20 sheets of photo paper.
  7. Slide the edge guide to the edge of the paper, but not too tightly.
    Follow these guidelines when loading paper:
    • Do not load paper above the arrow on the edge guide.
    • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
    • If you're printing on both sides of the paper, try loading fewer sheets.
    • If it's wrinkled when it ejects, the paper may be damp or too thin.
    • Do not load paper with holes punched in it for insertion in a binder.
    • Load the printable side face-up. It's often brighter or whiter than the other side.
    • Load letterhead or preprinted paper top edge first.
    • If you experience paper feeding problems, try loading fewer sheets.
    • If you're using special paper, check the package for special loading instructions.
Follow these steps to reload paper in the Automatic Document Feeder:
  2. Tap the originals on a flat surface to even the edges.
  3. Move the edge guides outward.
  4. Insert the originals face-up. You can load up to 30 letter-size sheets at a time. If you load legal-size sheets, insert only 10 sheets at a time. Make sure the originals are not creased or folded and do not have tape, staples, or other materials that could obstruct the feeder.
  5. Slide the edge guides against the originals.
Feb 27, 2010 | Epson Stylus CX9400 Photo Printer
It stopped faxing through the feeder and said feeder errror. its a HP j4680 all in one office jet
Hello, Brittany.
Give this a try (from HP Support):
Complete the following steps to check the condition of the paper, reload the original, and then open and close the Automatic Document Feeder cover.
The main reason for this issue is that the ADF rollers that pick up the papers might not grip the paper because dirt sticks to the rollers.
Step One: Check the paper and reload the original
The condition of the paper, or the amount of paper, might prevent the ADF from picking it up and feeding it through the product.
1. Make sure that the ADF tray contains fewer than 25 sheets of paper.
2. Make sure that the ADF tray contains no photo paper or carbon paper.
3. Make sure the paper in the ADF tray meets the following criteria:
* No curls, folds, creases, or tears
* No staples or clips attached
NOTE: Folded paper, torn paper, or paper with rough edges might not feed correctly. If your original is folded or damaged, either reprint the original or try to smooth out the damaged portions.
4. Reload your original, with the print side up, into the ADF tray. Place the pages so that the top edge of the document goes in first. Slide the paper into the ADF tray until you hear a beep or see a message on the display indicating that the loaded pages are detected.
* If still a problem, go to the next step.
Step Two: Open and close the ADF cover
NOTE: Remove all originals from the ADF tray before you open the ADF cover.
1. Open the ADF cover, and then close it again.
2. Press the OK button.
Follow these steps to turn the product off and then on again.
1. Press the Power button to turn off the product.
2. Wait 15 seconds.
3. Press the Power button to turn on the product.
Hope this helps.
Feb 26, 2010 | HP Office Equipment & Supplies
Why the paper get stuck while copying, and the machine make a loud noise
it may be feeding from the wrong tray. i was trying to copy short paper and it was feeding from the long paper section. this caused it to stick ever time. make sure the machine is feeding from the right tray.
Jan 23, 2010 | Sharp AL-1655CS Copier
Whats the scan platform
Scan platform in english is Were you shove the stuff to send ;) ie dirty feed roller, paper detect switch stuck or fragments of paper in original feeding paper path area or feeding stuff too thick or stiff, or if multi document issue it is the pad or roller that sits under the main feed roller...al this is nothiong to do with paper tray full of blanks it is the original feeler area on top..
Same error should occur doing local copy, check feed section/roller
Cheers hope that helps
Nov 19, 2009 | Canon FAX-L1000 Plain Paper Laser
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
Copy of documents misaligned vertically on Canon Imagerunner 3045
Hello sir; When you feed originals in portrait, the paper tray have to set by portrait direction too.
Mar 30, 2009 | Canon Office Equipment & Supplies
I have a brother copier model dcp 7025 and am experiencing a vertical line on copies where the original is fed through the top feeder tray but the copies are fine when the original is placed directly onto...
Depends which way is vertical but I think the feed rollers on the upper tray are slipping perhaps dirty. (The paper momentarily stops feeding past the scan sensor)
Jul 14, 2008 | Brother Office Equipment & Supplies
HP Office Jet 7310
chances are the feeder isnt feeding the paper at all, thats why you cant scan a single paper, try opening up the ADF and clean the feed rollers first, turn off the machine and gently rub the rollers again and again until you have a clean shot or surface, try this from thop to bottom rollers, please make sure though to insert uncreased paper and paper without eardogs on its leading edge, this could cause some delay upon feeding process
sometimes because it is exposed to dust, there is a tendency for the rolllers to slip, or you could be having a broken part that drives the feed rollers from your ADF.
Jun 30, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Canon imageCLASS D880 All-In-One Laser Printer Logo
69 people viewed this question
old marine
old marine
