Question about Nakajima AE-710 Typewriter
I am trying to type a letter but when I strike the letter g it types a $. None of the keys seem to be lined up with the correct letter on the wheel. How do you correct this problem?
    Scholar:
  • 75 Answers
There is a slide switch on the L.H. side of the key board that reads 10,12,15, PS
the switch needs to match the print wheel stile you have in your typewriter. most typ's have 10 or 12.
PS stands for proportional spacing a takes a spicule print wheel
Posted on Jan 24, 2009
How to write letter verifing address
Instructions
    • 1Before you begin, set your marginicon1.png 1 inch from the top, 1 inch from the bottom, and 1.25 inches on both sides.
    • 2If you're using letterhead, there's no need to type in your name and address. If you're using plain white paper, type in your name, address and phone number (phone number is optional), centering the text. Make the font in this portion of the letter slightly larger than the rest of the text. You should also type your name, address and phone number in boldicon1.png type.
    • Sponsored Links
    • 3About four lines down from your name and address, type the date in full after strikingicon1.png the "Tab" key seven times to bring you a little further than the middle of the page. The date should be typed in full like this:
      February 1, 2009.
    • 4Four or five lines down from the date, at the left hand margin, type the name and address of the person you're sending the letter to. This portion of the letter is called the inside address. If the person you're addressing the letter to has a title, type his or her name first, then type in a comma, space once and type in the title, such as:
      Jamie L. Mulligan, Manager
    • 5Two lines down from the inside address, strike the "Tab" key seven times and type in the subject line. The subject line tells the recipient what the letter is about. In this case, it should look like this:
      Re: Verification of address
    • 6Two lines down from the subject line, type in the salutation. The salutation could be Dear Sir, Dear Ms. Mulligan, Gentlemen, or To Whom It May Concern (if you don't know the name of the contact person). The salutation should look like this:
      Dear Ms. Mulligan:
    • 7Two lines down from the salutation start the body of your letter five spaces in from left margin. The body of your letter should start out saying something such as:
      I am writing you this letter to verify that 101 Washington Street, Lynbrook, New York 11593 is the address I should ship your order to.
    • 8Two lines down from the body of your letter, after striking the "Tab" key seven times, type in a complimentary closing such as:
      Very truly yours, or
      Sincerely
    • 9Four lines down from the complimentary closing and in line with the complimentary closing, type your full name in, like this:
      Jamie L. Mulligan
    • 10Sign your name in the space between the complimentary closing and your typed name.
Read more: How to Write an Address Verification Letter ' eHow.com http://www.ehow.com/how_4745362_write-address-verification-letter.html#ixzz2DRXhelUj
Nov 27, 2012 | Computers & Internet
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
Letters and numbers not printing correctly
It sounds like you have a damaged printwheel. Get a new one and try it.
DickyO
Apr 28, 2009 | Lexmark Wheelwriter 15 Series II...
Printwheel out of line
will not type letters dark enough
Mar 20, 2009 | Nakajima AE-710 Typewriter
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
When I type a letter it appears as two vertical lines but no letter
The hammer has two vertical pieces at the front, meant to strike the print wheel.
Do you have a font wheel in it?
Jul 14, 2008 | Smith Corona Wordsmith 200 Typewriter
Not typing correct letters
Send it back for repairs if under warranty. This is not an office machine it is designed for very light home use.
Mar 09, 2008 | Brother ML-100 Typewriter
Cannot get daisy wheel to type correct letters
Turn oFF the typewriter, take the ribbon out.....use the lever on top to release and remove the print wheel cartridge. Lightly rotate it to see if it will move and reinsert the cartridge. snap it back into place.
Turn on the machine, the typewriter should move the carrier to the left and reset the printwheel....if it is snapped back properly.
Jan 14, 2008 | Brother GX-6750 Typewriter
Types random letters
If you cleaned the printwheel home sensor and found no obstructions, I would first try a different wheel before going any further, sometimes they become damaged.
Mar 22, 2007 | Brother SX-4000 Typewriter
Nakajima AE-710 Typewriter Logo
167 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Daniel Thibodeau
Level 1 Expert
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
