Question about Samsung Microwave Ovens
Samsung MW87L Microware Light broken
I've only had it for a couple of weeks and then the light blew. It appears though, that the light is located behind the metal casing on the inside of the oven and that it appears that I cannot replace it because there's no screws or a loose fitting over it that I can remove to get to it.
Do you have any advice?
Kind Regards,
Vernon
  • Samsung Master
  • 9,086 Answers
Since it's under a year old, it's fully under warranty.
You can find your nearest Samsung-authorized service center
here.
Posted on Jan 18, 2009
Microware trun table does trun
Try to turn the turntable coupling under the glass tray by hand it should be pretty hard. If not, you may have a broken coupling. Those are plastic with a D shaped hole in them. If it has cracked, or broken, the motor cannot turn it. So either a bad coupling or a bad motor.
Oct 09, 2017 | Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
The "start" area on front
Hello
Well there is not much one can do to fix that problem than replacing the touch pad, you can try to clean the underneath the pad if there is any build up of dust as such.
Thanks
Jun 07, 2011 | Microwave Ovens
Samsung mw87L microwave does`nt emit heat, light works, turn table works, controls work, but no heat. Had it just over a year.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhj
Apr 21, 2010 | Samsung MS1040BB Microwave Oven
One surface light bulb on GE Profile microwave keeps burning out
I have the same problem. The left one burns out within a couple of hours use, the other one lasts a couple of months and is then gone. This pattern has repeated over 8 years. I replace them every now and then and then just go without until I get the urge again to fix it. Maybe smaller lower wattage lamps are worth trying...
Jun 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microware Kenmore mod. 721-67490790
I don´t know how but it turned on after a while and until now is working good. Maybe it turned off when I was using a lot the microware. Anyway thank you very much.
Liliana Martinez
Jun 14, 2008 | Kenmore 62622 Microwave Oven
The light inside the microware
1 take the front grill off. 2. you will see a cover with one screw around the area of the light. normally this is right in front.
May 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Oven runs but doesn't heat - Amana MVH220W
The Sears repair guy came over, $65 just to show. The parts I was told are not available. A Magnetron I guess. Buy a new one , like I will have to ...
Jan 13, 2008 | Microwave Ovens
Microwave Ovens Logo
98 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
