Question about Whirlpool Duet GHW9150P Front Load Washer
What does f mean? I lost my mannual...
I lost my maual, a load of clothes on the forty minute cycle stops 11 minutes befor it's done and the letter f apperears, What does that mean?
  • 903 Answers
I am not sure maybe to add fabric conditioner or it may be a hold button. Sorry not sure but I have found this link for you
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvyqahome001/cid/3/subcid/11
there is a contact option on there and you could request a manual for instructions on use or just ask them the question you posted here
Posted on Jan 14, 2009
My washer stops at a certain minute and won't proceed (i.e., it stops at 11 minutes for the low extract spin only cycle). Very frustrated! It worked fine for the service guy yesterday!
it may be in its pause cycle the washer pauses for about 2 minutes during certain cylce allow the cycle to continue some cycles go between agitation and soak
Jul 17, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The washing cycle takes much longer than the time listed on the panel.
Sounds like the pump may be clogged. If it doesn't get rid of all the water, it wont' spin. Remove bottom panel. Locate what looks like a big white screw. Remove counterclockwise. (It's tight). Have a bucket ready under neath, or a shop vac. Remove slowly to catch water as it comes out. When you pull the white part of the pump all the way out, there's probably things clogging the holes.
Apr 25, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
Feb 28, 2009 | Maytag MAH20PD Front Load Washer
LG WD-324RHD stops at 6 minutes left in drying
Your timer has gone bad and you need to replace the time. Best bet is to get a Technician out there but you can do it yoursel. It is behind the face plate where it counts down the time
Feb 09, 2009 | LG WD-3243RHD Front Load Washer / Dryer
Cycle will not complete
F H is a sign that the unit has a no incoming water issue, check your hose connections/water pressure,
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F-11 code error.
sound like a control problem
May 24, 2008 | Kenmore Elite 45986 Front Load Washer
Dead in the water
End of cycle? After the end of cycle you have to wait for 2 minutes minimum (or hear a click), only then you have to try the door; or your door won't open & if you force it you'll damage the door mechanism (not good). End of cycle means "your wash is done".
Pl rate if helped.
May 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washing machine
f-11 is a motor control unit error.
These codes and more details are printed on the service technician diagnostic manual that is affixed to the inside of the washer's front panel.
Unplug your washer, and unscrew the three 1/4" socket screws at the bottom of the washer. The manual should be taped to the back of the panel, and the code and some recommended procedures will be right inside.
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
