Question about Holmes Products HAOF950RC-UC Table Fan
Have a defective part in fan ckt board
The part is lgu824k,250mer
  • 25 Answers
Call the manufacturer, if they don't have part you're out of luck.
Posted on Jan 15, 2009
What does flashing red LF mean on freezer
Kenmore Refrigerator Error Code = Er 1F
Error Condition = The fan for the ice compartment failed
Repair or Check = Icing fan blocked - ice fan motor is defective - wiring in the circuit is defective - control board has failed
Parts Needed = Ice fan motor - Wiring harness - Power control board
Kenmore Refrigerator Error Code = Er IF
Jul 05, 2017 | Washing Machines
What does LF flashing red mean
1999 Dodge Neon Issues (HELP)
Here's a link to the P0340 code,and P1491.Powertrain Diagnostics Manual P-1491 Radiator Fan control relay circuit
Set condition: An open or shorted condition is detected in the radiator fan relay control circuit.
Possibilities:
Fan relay ground circuit open
Fused B+ circuit open
Rad fan control relay defective
RF relay output circuit volt cycles over to batt voltage
RF relay control circuit open
RF relay ctrl rly ckt wir harness observable or intermittant defect
RF relay ctrl ckt short to ground
Defective PCM
Get out your Multimeter.
Mar 22, 2013 | 1999 Dodge Neon
The menu lights will not work.
Sorry to read about your problem, I hope this helps you out.
check ckt breaker for power, if ok you have defective control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | KitchenAid Dishwashers
My aerus 9000 series vaccum has no power at all... all wiring is good, I believe there is a bad circut board where there is a relay on it.. any suggestions
no ckt board.. bad power switch or defective motor
Dec 23, 2010 | Vacuums
Asko 1385 wont run after power outage, is there a reset ?
You may want to re-flip the ckt breaker..their is no reset on the unit..if that does not work, the control board has become defective
Dec 22, 2010 | Asko 1385 Dishwasher
The green led begins to blink very fast. The screen is dark and the monitor is cold.
that only standby mode, not yet power on. you need to check first power ckt are going to main ckt. trace parts by parts for possible defective or change value parts.
Apr 04, 2010 | Dell P1110 21" CRT Monitor
I've got this 42" DLP TV and the word LAMP in the front was flahing, but the TV won't come on.I got this same problem before while it's still on warranty and the tech replaced at least three ckt. board....
This could be the DMD board or the ballast board or both if the lamp is good. Also it could be a stuck clor wheel. Sometimes the DMD board will light the lamp indicator when there are other issues like a stuck fan or color wheel
Mar 04, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Red screen
it is due to problem in red cathode section in your tv. you can check 1 vlotage on red video ckt. 2 loose or print cut in red ckt 3 crt base loose 4 problem in red signal processor line. 5 signal processor ic defective 6 connector loose. good luck
Sep 26, 2007 | Televison & Video
Holmes Products HAOF950RC-UC Table Fan Logo
85 people viewed this question
Top Holmes Products Dryers Experts
Jay Finke
Jay Finke
James Coghill
ray gallant
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
