Question about Whirlpool Duet GHW9150P Front Load Washer
Dryer will not start
Whirlpool Duet Front Load Gas Dryer Model GGW9200LL1:
The Dryer will not star when the start button is pressed. The control panel seems to be working and the dryer beeps twice when the start button is pushed. The problem accurred after there was an electrical flas as the dryer dorr was being opened.
Any idea what might have happened?
    Genius:
  • 3,422 Answers
If your dryer doesn't work at all, it could be because of problems with:
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Posted on Jan 14, 2009
  • 716 Answers
Check The Relays Inside The Unit. If The Relays Are Bad The Control Panel Will Not Have Any Connection To The Motor.
Control locked light is on on my whirlpool duet front load dryer and it won't do anything
This advice is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Frigidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your specific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks
Nov 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The control locked button is on. I do not know how to turn it off to start my next load of laundry.
Thanks for using FixYa!!
Dec 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet front load washer, the control lockk is on, how do I turn it off? Thank you!
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^%$
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer stuck on control lock mode
Jun 27, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Duet GHW9150P Front Load Washer: The control lock light is lit on my whirlpool duet...
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Front load whirlpool duet washing machine controle locked light is on how to reset it?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&###%%
May 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Problem for Whirlpool Duet GHW9150P Front Load Washer The control lock is on. How do I turn it off?
Mar 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet red light keeps blinking and wont start. it is not locked.I tried unplugging it and nothing works.
Nov 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet gas dryer has CONTROL light lit with malfunction.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.#$#$#$
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Ghw9150pw1 would not start
Aug 21, 2008 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
