Question about Dell Precision M90 Notebook
Everything is too big
I let someone borrow my laptop and when I logged on the next time, everything was too big to fit on the screen, I tried everything I know and still I can't seem to get everything that should fit on the screen to fit, helpj, can anyone help
  • 3 Answers
Sounds like the screen resolution has been changed. Right click on the desktop goto Properties -> Settings and slide the Screen Resolution slider to 1024 x 768 then click on Apply. If that works you should see all your icons as you did before, The resolution can be adjusted higher if its more suitable for you. Most 17inch laptops work between 1024 x 768 and 1152 x 864. If that doesn't work let us know! :)
Posted on Jan 14, 2009
    New Friend:
  • 30 Answers
Visit dells support page and download the graphics driver.for your model laptop.its very easy to do then just install once it has downloaded.
Posted on Nov 29, 2014
Tip
Customise the log-on screen in windows 7
Changing the Windows log-on screen used to involve some complicated and potentially dangerous hacks, but not any more - Windows 7 makes it easy.
First, browse to HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Authentication\LogonUI\Background in REGEDIT, double-click the DWORD key called OEMBackground (not there? Create it) and set its value to 1.
Now find a background image you'd like to use. Make sure it's less than 256KB in size, and matches the aspect ratio of your screen as it'll be stretched to fit.
Next, copy that image into the %windir%\system32\oobe\info\backgrounds folder (create the info\backgrounds folders if they don't exist). Rename the image to backgroundDefault.jpg, reboot, and you should now have a custom log-on image.
Alternatively, use a free tweaking tool to handle everything for you. Logon Changer displays a preview so you can see how the log-on screen will look without rebooting, while the Logon Screen Rotator accepts multiple images and will display a different one every time you log on.
on Jan 10, 2010 | Computers & Internet
Grey screen but everything else works as normal Initially, on the windows startup (Bios) and the welcome screen, the colour is fine, everything is there. But after a few seconds logged in, everything turns...
That sounds like a problem with your GPU, this is very common with Nvidia graphics cards when built onto motherboards for mobile devices. First contact HP to see if you have any warranty with them, if not then you can either look for a company that specialises in board repair in your area or if you are brave try a DIY fix. Search 'motherboard DIY reflow' on google or youtube to see an example. Hope this helps,
www.PuterCare.com
Jul 21, 2010 | HP G60 Notebook
Dell xps 1530 will get to log on screen and go blank
try logging in safe mode first upon turning system on tap on F8 then select safe mode, once logged in safe mode to a system restore to the date before this issue happend if system restore gives an error it failes tr going back to system restore in safe mode the do a disc defragmentation click start, accessories, system tools, system restore then select restore my computer to an earlier time then select the date when everything was working fine
Jun 04, 2010 | Dell XPS M1530 Laptop
Can't make monitor screen larger
if your using a laptop set ur diplay setting to 1024 x 768 to fit the whole screen. If your using a desktop setup the display setting to 800 x 600 to make everything big enough to see..hope this helps..
Aug 31, 2009 | Computers & Internet
Screen resolution change = black border around small screen
RIGTH CLICK THEN DISCKTOP THEN PROPERTIES,DESPLAY AD SETTING, CHANGE INTO 1024 BY 768 PEXILS.... TO FIT THE SCREEN RESOLUTION 32BIT ONLY
Jun 04, 2009 | Dell Inspiron 8200 Notebook
Hello I have a HP laptop and wstwrday was everything OK. Today morning I turn it on and screen is black and laptop make it just sound.. PiiiP one long and two short ? what cain of problem is...
Sounds like a Power-On Self Test (POST) error.
Usually one long and three short beeps indicate a memory error.
Could anything have happened to dislodge the memory? You could try unpluging, taking out the battery, earthing yourself and then removing the cover on the memory enclosure (usually one screw at the bottom releases the cover). Check that the modules are pressed right home into their clips.
If there is more than one module, try removing one at a time to see if there is one failed one.
If the memory has failed, you are looking at new memory I'm afraid.
Sep 09, 2008 | HP Computers & Internet
I have a emachine420 and it will not start, got standby light and powerpack fan working but thats it
Try unpluging everything but the ram and the video card and booting and keep adding one piece back in at a time until it stops booting and then you'll know what the bad piece is. If you get nothing w/ everything but the video card and ram pluged in try to borrow someone elses ram or video card to test those as well.
Apr 19, 2008 | Computers & Internet
Laptop
Once you boot up press F-8, when the screen comes up, select last known good configuration, when the next screen comes up select the Operating System.
If this does not work, reboot ,press F8, select safe mode, select Administrator, no password, Log On. Let everything come up,
GOTO Start,Run,type in msconfig, click on OK, select start up tab,
select disable all, click apply, click ok, click restart.
Mar 26, 2008 | Computers & Internet
Connecting lap tops to monitors...
Try connecting a mouse and keyboard to the laptop and then start it with the top closed. Not sure if this will work on your model, but it works on a lot of laptops. This should force the PC to use your external monitor as the primary one.
Mar 19, 2008 | Dell Inspiron 6400 Notebook
Open Questions:
See all Dell Precision M90 Notebook Questions
Dell Precision M90 Notebook Logo
108 people viewed this question
Alun Cox
