Question about Euro-Pro Cordless Bagless Upright Sweeper - Blue/Gray
V1917n shark vacuum won't run
Vaccum power button lights up green, but the 3 selection lights flash red. Sweeper will not power up.
Mine did the same thing, actually both of them did. I had ordered two at the same time. I love these vacuums. They are so convenient to use and do a terrific job, at least until they acted up and did not want to run.
The first one would power up for a second or two and then quit and the three lights would flash. I tried everything to get it to work. I switched batteries and the charger cord with the new one, but still it did the same thing. So, I opened my second new one up and began using it. I worked for several months and then just here a couple of days ago it too began acting just like the first one did.
I took the corner brush off and then the rotator brush off and removed all the hair, strings, and etc., from around the brushes and also all the areas of the vacuum where any could be at. I put it all back together and it turned for several seconds and then the three lightw would flash again.
I had given up on them working again and was going to be boxing then both up and send back for replacements and was looking at buying another brand of cordless rechargeable sweeper. I had found one to buy, but still I knew that I would miss the Shark vacuums.
Well, tonight I took the second one apart again and looked at areas where I might have missed any hair or strings that might have wound around anything that might keep the brush from turning. I found some wound around the rotator brush end piece that is on the side opposite to the belt. At first I thought that a rubber gasket was worn that fit over the little metal rod that is at the end of the rotator brush, but when it still would not run, then I was thinking that the belt needed to be changed.
I have read somewhere, where someone said that it was hard to change the belts. Well, with the Shark that I have, which has three speeds and the handle that drops down in the middle so that you can vacuum under beds and etc, it is easy to change. There is a tab that you have to push that is next to the wheel on the belt side of the underside of the vacuum, and it opens to reveal the belt.
Well, when I opened it----------there was a tremendous lot of fibers and hair wrapped around the belt wheel and in the chamber leading up to the wheel that the belt attaches to the rotator brush. After taking the belt off the bottom wheel and cleaning all the hair and fibers off it and removing all the rest in the chamber, I put everything back together and it powered up and ran just like it did when I first got it.
I also got the first one working also. I don't have to send them back and have to wait a long time for replacements. Just a word of advice------------keep the rotator brush clean and the area around the belt at the bottom and anywhere else where hair and strings can wrap around. Keep a check on it weekly and it might keep them running.
Posted on May 18, 2009
  • 3 Answers
I just had a similar problem. I opened battery compartment, pulled battery wires out until the white connector was visible, disconnected/reconnected and voila it the motor starts. But the battery was discharged even though I just pulled it off the charger. But, it was flashing red while on the charger previously, and now it the green light is on while charging. So, it appears it wasn't charging while flashing red, or my battery needs replacing? time will tell.
Posted on Mar 21, 2009
The green light on my shark rocket goes off after a few seconds. What is the problem?
Some filter are clogged.Usually, there are 2 or 3 filters on vaccum. Or bag is full.
https://www.youtube.com/watch?v=4SlbhcjniR0
Dec 02, 2017 | Shark Vacuums
I need shark battery for sweeper xbn1917
Contact Shark Vacuum Shortest Wait Best Support
http://gethuman.com/contact/Shark-Vacuum/
Shark Vacuum Customer Phone Number Shortest Wait Best Support
http://gethuman.com/chat/Shark-Vacuum/
1-800-798-7398
press 4. then 5
1-800-798-7395
press 2 for customer service
Also take the battery to a Radio Shack store and they maybe able to order it for you or even have it in stock.
Nov 16, 2014 | Shark 10" Cordless All-Surface Power...
Blue light flashing on shark steam and spray mop
Read manual under trouble shooting.
1. If you have already plugged in the power cord, unplug and re-plug into another electrical wall
outlet. This may reset the Standby mode.
2. Add water to the water tank and press the On/Standby button to select a steam setting.
3. If your unit still does not work, call Customer Service at 1-800-798-7398.
May 27, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
After turning on power , brush roller freezes and indicator light turns red
try turning the roller by hand UNPLUG VACUUM FIRST
it should turn very easy, otherwise it is binding
all uprights have this problem eventually
hair and fibers get in roller bushing and seize
luckily disassembling is relatively easy, same procedure as replacing the small belt that drives the roller. Take the extra step and take out the roller slip off bushings and clean everything
have fun
alex
Feb 06, 2012 | Euro-Pro NV22 Shark Navigator Bagless...
The sweeper attachement went "dead." What could be
more than likely the overload or reset button has been tripped within the powerhead.
Press the red button or the square button on the left side top of the unit, more than likely it is the red one, and it should start up for you again.
Good luck,
Mark
Nov 09, 2010 | Kenmore Whispertone 23312 Bagged Canister...
My shark v1917 jammed on a throw rug, won't start.
These machines do break VERY easy, however i would wait a couple of hours and try restarting it. If this does not work then i am sorry to say yes it is scrap.
Apr 15, 2009 | Euro-Pro Cordless Bagless Upright Sweeper...
Can I buy replacement batteries for Shark Cordless Sweeper
I need a replacement battery for my Shark Stick sweeper model V1911 N. Can't find it on their web site. I guess it is old. Murnieruth
Nov 25, 2008 | Euro-Pro Shark Professional Upright Vacuum...
Euro-Pro Cordless Bagless Upright Sweeper - Blue/Gray Logo
4,147 people viewed this question
Top Euro-Pro Vacuums Experts
Dennis Key
Dennis Key
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
