I need a eiring diagram showing the courtesy lights circuit I have a 0.78 amp current draw when everything is shut down and it is in this fused circuit. Need to see what components are in this circuit so I can troubleshoot.
SOURCE: car audio wiring diagram for 1998 volvo s-70
CLICK HERE for your vehicles full service manual. If you are cutting wires.
Be warned your vehicle has a factory amplifier installed, and needs to be bypassed to hear the speakers if you are just wiring behind the dash.
Metra makes a harness you install on the aftermarket radio, then simply plug into the vehicle's harness.
All the wires are labeled for easy installation.
70-9220 is the metra part number. Click on the number to see an eBay auction.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
you can go to your local library and find a repair manual
SOURCE: Wiring Diagram 1998 Chevy S-10 starter replacement
The starter has one large cable from the battery positive, and a wire that goes to the solenoid (Part of the starter) that becomes hot when the key ignition is turned to start. This also passes through the neutral safety switch. (So it wont start in gear) Not sure if this is what you need, a little vague.
SOURCE: need a wiring diagram for a chevy s10. brake
your power starts at the brake light fuse,check with a test light,then proceed to stop light switch on brake pedal under dash,one wire will be hot when when you check it with your test light, the other won't be until you press down the brake pedal then the power flows through to the second wire,if no power to second wire replace switch,if you have power remove tail light bulbs and check for power in side socket.
