Rca r52wh74 - no auto convergance
While watching tv - the colors went out of alignment with each other. What could be the issue? We have turned off and turned back on after 5 min
my rca 52 in has the same problem. but seems to not auto converge . and even when i manuel converge the screen is still looks like a 3 d movie.
i have tried every thing.. and its only a year old..
I have the exact same problem. Its showing 3 different color lines. Mine is only 2 years old. I bought it for $900 at Walmart but I kept my receipt. I called so that they could fix it but they said they dont make that model or the pieces for it I guess so Walmart issued me a check for a full refund 2 years later. On top of that, they said i could keep the 52" so now im trying to get it fixed somewhere else & get another tv. But if i get it fixed will i have the same problem again or another soon on these particular model tvs? Im trying to figure out would it be best for me to get it fixed or just spend the money on another tv?
  • fashowdoe Jan 14, 2009
    Ha, thanks for the tip but I dont even feel comfortable pumping gas in my car. If i were to get it fixed, can you give me an estimate as to how much I should expect to pay for this type of problem? And also do you think it would be better to get this fixed or get another brand tv? I just dont wanna have to go through this or another problem anytime soon. Thanks
    Im in San Diego & I've already $250-$350 estimate from one place. When I told him the problem & gave him the model number he researched it & told me i have a bad conversion board over the phone. That made me research it on my own & see if I could order the parts on my own & maybe just pay someone for the labor.
  • 4,234 Answers
The convergence circuit is the problem. If you can solder and are comfortable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself. First locate the convergence ICs which are large black ICs attached to a heatsink that will be marked STKxxx. Try resoldering the pins on these ICs first. If that fails to resolve the problem, replace the ICs. Please note that there could be additional small parts that require replacement as well. Start with the ICs and let me know the results.
Dan
Posted on Jan 14, 2009
  • ABRsvcs Jan 14, 2009
    While this is a bit unusual for a set only a year old, it is poossible. I would think that the connections are bad rather than the part being defective. The convergence ICs run around $20 or so each (there are 2). The problem is that the labor charge for a set this size will probably be over $200. Be careful that the service shop doesn't state up front that the convergence board is bad. If so, the parts cost will exceed $150. The board can be repaired at less cost than replacement. If the board is replaced a complete convergence procedure will be required which will add to the labor cost.
    Where are you located? Perhaps I can recommend a shop.
    Dan
I have a RCA Model R52WH74. It hs a double view to it liek the colors has seperated. It also has a wavy red line across the top. It looks like the projector bulbs are out of line. All three bulbs are...
The tv have a problems known as a convergence problems,it is dead.Tv have any colors lines R,G,B mis alignments,have any colors shadows pictures or 3D pictures look alike?Yes,than the tv convergence board it is dead,convergence board must require changes 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to fixed the tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 01, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA 52'' TV, model number R52WH74. I have replaced the FL231 fuse and re-soldered the flyback as well as some other places on the board who needed it. The picture looks fine, the only issue I...
Convergence should be showing on Menu. Hit menu then go to setup you should see it listed their.
Heres How to Enter Service Menu for alinement of
convergence BUT I MUST WARN YOU be very carefull of adjustments in wrong alinement. With TV turned off PRESS and HOLD Both CH- and VOL- release when set comes on Now you should be in Teachician Service Menu there you should be able to Do convergence alinement and set Auto convergence.
Oct 02, 2009 | Televison & Video
The model number of your TV probably falls under the ITC-222 chassis design. Do a search based on that criteria and it should point you in the right direction. If I remember right, you need to replace FL231 on the deflector board though. Good luck
Dave.
Jun 03, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
fl231 is solderd in and will have to be replaced along with DL231 and CL230
Apr 07, 2009 | RCA Televison & Video
Bow tie looking picture with 3d color mis-alignment
you have lost convergence. First thing to check is to see if you are missing the convergence option in the customer setup menu. if you do not have this option then i suggest reading the article in the tips and tricks section entiltled "the fl231 fuse problem" this is a common and sometime easy repair if you do have it then you might need a convergence power board
Mar 09, 2009 | RCA R52WH73 Projection Television
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
R52WH74 WONT CONVERGE
first question is the picture also bowed in on top and bottom. if so you may have the common fl231 fuse problem if you do consult the fl231 problem under the tips and tricks section. if you dont then you defently hav a convergence issue. the thing to look for is under setup do you have the autoconvegence option if you dont then you have that problem.
Jan 17, 2009 | RCA HD52W59 HDTV Projection Television
Could use more help
you will need the convergence power supply to repair the issue if its all three colors out of alignment. Leave these people a email with your model number and symptoms, they are RCA experts and will be able to help you get exactly what you need
http://servicemanuals.vstore.ca/
Sep 04, 2008 | Televison & Video
On this particular model when your convergence is out of alignment, and the auto convergence is suddenly missing from the TV's menu all together, there is a easy fix.
Diode on Main Power supply, Location dl321 and fuse at Location fl231.
This problem has a high failure rate.
Jan 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
you need to replace chemical type fuse marked FL231 part number 259213, it`s located next to the flyback transformer, theres 3 of them there but 231 is the only one I`ve seen cause your problem, replace it and you`ll be all set.Happy Holidays !
Nov 29, 2007 | Televison & Video
Televison & Video Logo
166 people viewed this question
Top Televison & Video Experts
