Question about IBM 4610 TG4 Thermal Label Printer
Replaced 4610 printer and settings are incorrect.
Trying to change printer spacing settings in 4610. Can this be changed with IBM laptop configuration install or utility or do i need a surepos system. Im not on site with client but do have access to IBM laptop T23 which http://www-01.ibm.com/support/docview.wss?uid=pos1R4000111 states can work. Has anyone tried this?
  • Durisimo Jan 18, 2009
    thanks for viewing my issue. I have seen that pdf before but dont have the diskettes since those diskettes are for IBM POS system OS 4910 i believe. I could not find a download for these utility so figure my only alternative was the link i posted.
  • Durisimo Jan 22, 2009
    According to the ariticle i have to run these commandss from the diskette utilites which only work for 49XX operating system. He doesn't have this operating system. Only a free POS system running from a windows machine. I would be willing to install another POS system for testing if i can configure the printer.
    Brigadier General:
  • 8,619 Answers
Hi!
You can see this if you want default settings fot 4610
4610 DBCS Installation Utility Diskette
This utility is for both RS-232 and RS-485 operation. It includes:
v The latest level of firmware for the printer
v A README file that describes how to use the utility program.
v A utility program that performs the following functions:
– Update printer firmware
– Configure the printer model
– Create, edit, and download SBCS user-defined character font, logo image,
and messages
– Edit and download DBCS code pages and DBCS user-defined character font
– Convert fonts and logo files from impact to thermal
v Sample files for the utility program:
– An SBCS user-defined character file
– A message file
– A logo file
v Utility program to enable/disable Model 4 Printer emulation (SBCS mode only)
v Utility program to change the printer mode between DBCS and SBCS
Posted on Jan 18, 2009
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 18, 2009
    DBCS Code Page Download
    SureMark models TI5, TG5, TF7, and TM7 can receive a DBCS code page from an
    attached host system connected by an RS-485 cable (cable 7), an RS-232 cable, or
    a USB cable.
    The following mediums can be used to download a DBCS code page:
    v 4610 DBCS Installation Utility Diskette code page download (RS-485 or RS-232
    connection)
    v POSS for Windows DBCS code page download (RS-485 or USB connection)
    v 4690 OS V2R4 font download, when available
    After downloading the latest level software from the Retail Store Solutions Web site
    (see “Resources on the Internet” on page 43), use the appropriate procedure that
    follows to download a DBCS code page.
    4610 DBCS Installation Utility Diskette Code Page Download
    Use the 4610 DBCS Installation Utility Diskette to download a DBCS code page to
    a SureMark that is connected to a system unit by either an RS-232 or RS-485
    cable.
    To download a diskette font, perform the following steps:
    1. Download the fonts diskette from the Retail Store Solutions Web site (see
    “Resources on the Internet” on page 43).
    2. Download the latest level of the 4610 DBCS Installation Utility Diskette from
    the Retail Store Solutions Web site (see “Resources on the Internet” on
    page 43). Place the file that you download, which is 4610dbcs.exe, in a
    temporary directory. Run 4610dbcs.exe in a DOS window to create the
    diskette. If you are using Windows NT, you might need to use FORCEDOS.
    3. Insert the 4610 DBCS Installation Utility Diskette in drive A.
    4. Power on the system unit to which the SureMark is connected.
    5. Select Run Printer Utility for the RS-232 or RS-485 connection.
    6. Follow the displayed instructions to complete the font download.
    updated March 18, 2002
    Chapter 3. SureMark Installation, Service, and Utility Software 31
    a. Press Enter (OK) at the logo screen.
    b. Select the connection type (RS-485 or RS-232).
    For the RS-232 connection, also select the following:
    v Communications port (COM1, COM2, COM3, COM4)
    v Baud rate (9600 or 19 200)
    v Control flow (DTR/DSR or XON/XOFF)
    v IRQ test
  • Rylee Smith
    Refer to the communication mode selection switches located at the bottom
    rear of the SureMark printer when making the above selection.
    c. Press Enter (OK).
    d. Select the printer model, then select Enter (OK).
    e. Select F10 (Menu).
    f. Select O (Operations).
    g. Select F (Download Fonts).
    h. If you want to selectively download code pages, go to Step 6j. Otherwise,
    select one of the font sets from the font set menu, then select D
    (Download). Use this option with POSS for Windows, OPOS, or JavaPOS
    drivers.
    The following DBCS font files are downloaded to the printer when you
    select Yes (you can change the list of files in a:\utility\fontset.dat before
    selecting Yes):
    v DBCS for thermal printhead
    v DBCS for impact printhead
    v SBCS for user-defined thermal code page 1
    v SBCS for user-defined impact code page 1
    v DBCS user-defined character for thermal printhead
    v DBCS user-defined character for impact printhead
    i. When prompted, insert the appropriate DBCS Font Diskette in drive A (see
    “Resources on the Internet” on page 43 for information about downloading
    the diskette), then select OK.
    Go to Step 7.
    j. Select S (Selective Download).
    Note:
    If you are using the 4610 DBCS Installation Utility Diskette with a
    printer that will be used with POSS for Windows, OPOS, or
    JavaPOS drivers, then do not use the selective download. If you
    use the selective download with those drivers, the drivers will not
    recognize what DBCS code page has been downloaded.
    k. Select E (Erase EPROM).
    l. Select the code set (SBCS or DBCS), code page, station (Thermal or
    Impact), and characters (Normal or User-Defined).
    m. Select B (Browse) and specify the font file, if required.
    n. Select D (Download).
    o. Select Yes. When prompted, insert the appropriate DBCS Font Diskette in
    drive A (see “Resources on the Internet” on page 43 for information about
    downloading the diskette), then select OK.
    p. Go to Step 7.
    7. After the font download has completed,
    32
    SureMark DBCS User’s Guide
    a. Press Done for confirmation if Download (Step 6h on page 32) was used.
    Press OK for confirmation if Selective Download (Step 6j on page 32) was
    used.
    b. Press C (Close) to close the dialog.
    c. Press Alt-X (Exit) to exit the menu.
    d. Press Enter to exit the utility.
    8. When prompted, reinsert the 4610 DBCS Installation Utility Diskette, then
    press Enter.
    9. Remove the diskette from drive A.
    10. Press Ctrl-Alt-Delete to reboot the system.
  • Rylee Smith
    And download the diagnostic package from the link---
    http://www2.clearlake.ibm.com/store/supp...
    President:
  • 1,952 Answers
Www.qvssoftware.com/doc/QVSTSUserGuideV3.doc -try this link
  • mohammed marika thambi
    mohammed marika thambi Jan 18, 2009
    listserver.themacintoshguy.com/pipermail/X4U/2007-August.txt - 543k -
    www.redbooks.ibm.com/redbooks/pdfs/sg246261.pdf -DOWNLOADTHIS LINK
    www.faqs.org/faqs/pc-hardware-faq/laptops/compaq-aero/ - 442k
  • 565 Answers
Try this link to fix your problem - http://www.sisnet.co.kr/support/down/blk2mst.pdf
  • Teet Bergmann Jan 18, 2009
    What diskettes u ned then for your 4610??
Lenovo thinkpad R51e ,when i power on the laptop it show error271
This error message is generated when the BIOS Date and Time is incorrect. Go into the BIOS configuration to change the Date and Time. When you reboot and still get the same error message then the BIOS battery is flat and needs to be replaced and the Date and Time setting needs to be change to the current Date and Time after replacing the battery.
If you cannot get into the BIOS configuration (press F1 on bootup) or you get a lock icon in the top LH corner of the screen, this is a Power on Password symbol, enter the passsword to bootup the laptop and then press F1 to get into the BIOS configuration.
Aug 10, 2009 | Lenovo ThinkPad R51e Notebook
Suremark 4610 on Sure POS system/ Laptop T23
We specialize in these products.
Capital Computer Group
2425 Enterprise Dr.
#200
Mendota Heights MN, 55120
Wethernb@capcom-ncr.com
651-405-8293
We Buy, Sell, Repair, and Refurbish both new and used POS Systems, NCR, IBM... We also offer structured cabling as well as Video Surveillance Equipment.
Give us a call and we can trouble shoot it with you!
Jan 14, 2009 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 TG4 offline.
if it printing trash more than likely you have a driver problem, where are you getting the driver for your printer?
try to look for another driver and test by going to ibm's website:
http://www.ibm.com/products/finder/us/finders?Ne=5000000&tmpl=%2Fproducts%2Ffinder%2Fus%2Fen%2Ffinders&finderN=1000188&pg=ddfinder&lc=en&cm_re=other-_-suprcn-_-download&collectionN=0&sid=304421691223506248263&cc=us&C1=5001220
good luck!
Oct 08, 2008 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 suremark receipt printer
Hello all,
had the same problem and my solution was to install the latest driver available at the IBM service/driver website. Then unistall it with another IBM driver cleaning tool, then repeat both processes a couple of times, until the printer responded. There is some bug on these latest drivers an older Windows versions, so only after some installations and repairs on the first install, windows gets it right. VERY STRANGE but it worked in 2 machines, both IBM terminal and 4610-tf6 IBM printer.
By the way; RS232 ibm cable...I believe its a null modem 9 pin...not a regular serial cable.
Dip pin config: my printers have 4 so; 1ON 2ON 3OFF 4OFF which means
1 size of paper you are using 80mm
2 if you use an IBM software or other:other
3 if xon/off or DTR/DSR:hardware
4 com speed: 9600baud or 19200baud, 9600
That's what I igured out. If you need any more info: mail
fit.frederico@gmail.com
FredP
Sep 28, 2008 | IBM SureMark Printer TF6 Thermal Label
IBM 4610 TG4 Printer configurations from windows
Hi
you onli need send commands by excel is ASCII CODE its easy
Apr 10, 2008 | IBM 4610 TG4 Thermal Label Printer
Setting on the control panel
Have you gone to the " Save Configuration" option in the menu ? Try saving to ALL configuration locations.
Aido
Dec 19, 2007 | IBM Infoprint 6500 Matrix Printer
IBM 4610 TG4
Jacsmar,
The 4610 has several common routines. One of these common routines is CR.BUFFER.GUILOTINE This routine buffers the guillotine cuts written to the receipt station.  I believe you need to be sure that this routine is inserted in the printing program in order for the guilllotine mechanism to cut.
The routine should have the following defination:
SUB CR.BUFFER.GUILLOTINE PUBLIC  The other routine is:
DO.GUILLOTINE.CUT
Also simply listen to hear if the knife mechanism is trying to activate after printing a receipt.
Hope this helps,
G. Kiely
Sep 10, 2007 | IBM 4610 TG4 Thermal Label Printer
IBM 4610 TG4 Thermal Label Printer Logo
454 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
