Question about Toshiba 32HFX71 32" TV
32HFX71 Blinking Pwr Indicator Light
TV 5 yrs old, 32 inch normal size screen - working fine, then went out. Power Ind Light is blinking steady. What is wrong? Is it - convergence? vertical output circuit? power supply? Is it worth fixing or should I spring for a new wide-screen LCD?
  • 934 Answers
Not likely convergence because it's simply a direct view TV. Could be vertical, a common problem with that unit is the vertical output IC Q301 and poor solder connections of the link off R305. This could be enough to put the unit in shutdown. And it could also be SMPS, possibly regulator or horizontal output transistor - you would need to test these to be sure. The HOT, if shorted, will have continuity E to B or E to C.. If you're not sure you're up to this take it to a reputable shop. What I've described above isn't too serious and a good shop can having back to running good as new in a couple of hours. One tip I might add, take to the shop yourself it will save a few bucks. Good Luck Bill
Posted on Jun 14, 2007
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
While watching tv on saturday, my screen went black and their is absolutely no picture nor sound can you tell me if i can fix it as it is only 3 years old
Any indication of power? red light? blinking light? Sounds like the power supply failed if no indicators on. 3 yrs is an average lifespan for these new sets.... unless you are a tech, it's time for a repair shop. Get an estimate first, sometimes its not worth getting an old set fixed...
Mar 22, 2010 | Insignia IS-LCDTV32 32 in. Television
Panasonic PT-51HX41 51 inch
Can you post how many blinks the power indicator is blinking as that is an error code such as 3 blinks means Convergence circuits.
Mar 02, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Astar 30 inch model ltv-3001 will not turn on
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com
Jan 20, 2009 | Astar LTV-3201 32 in. LCD Television
PROTRON 26 TWO YEARS OLD
Jan 20, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Philips flat screen tv will not power up.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Dec 20, 2008 | Philips 32PFL3403D/27 32 in. LCD TV
PT-60LC13
there are fans inside tv need to make sure they are clean and free of dust
Nov 27, 2007 | Panasonic PT-50LC13 50" Rear Projection...
TV auto shut off-power indicator light blinking-won't turn back on
You could have gotten an electrical surge that put your set into a shutdown condition and unplugging the set and letting the Microprocessor reset will fix this problem if it dosent blow out the main power regulator as you still or might I say have a regulator IC problem. IF THIS PROBLEM HAPPENS AGAIN MORE THEN A FEW TIMES WITHIN A SMALL TIME FRAME I WOULD HAVE THE SET LOOKED AT BEFORE THE REGULAOR BLOWS SOMETHING OUT!!!!
Jan 11, 2006 | Toshiba 43H70 43" Rear Projection...
Toshiba 32HFX71 32" TV Logo
131 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
