Question about Microsoft Xbox 360 Console
I close the disk tray and immediately opens again and stays open
I can close the tray for 2 seconds then it opens no matter what i try i will always open again
    Problem Solver:
  • 14 Answers
Hello,Do you have the original face place on? Some after markets will cause the open tray button to stick. Next check the button to see if it moves freely, when doing this, also try feeling the button if it bottoms out, check for any debris behind the button, If these don't change the situtation, then there is a sensor on the tray to tell if it's opened or closed, the sensor is either malfunctioning or something could be stuck to the bottom side of the tray from preventing the disk to load, The last thing would be to look into is there a forgien object stuck in your tray area like a piece of papper or plastic, I hope this will help resolve your problem, we look forward to hearing back from you and please have a nice day, Thanks
Posted on Jan 14, 2009
When I turn on the power to the PS2, the disk tray immediately opens. I put in a disk and close it, after 2 seconds it opens again as if I hit the eject button. The tray won't stay shut.
i would check if your eject button is stuck if it is try to pull it out a little with small plyers or its the eject sensor or finally it might also have something in the way of the tray if you dropped it on accident or something it will keep opening if something is in the way. hope this helps.
Dec 23, 2009 | Sony PlayStation 2 (PS2) Console
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
Technics SC-CH515 CD Tray Does Not Stay Open
I DO NOT think that problem related with CD cleaner
3 possibility here
1 The loading belt was lose it can not open fully to reach the switch open when the time limited was out as program design from system control it automatic close
2 The loading gear system out of position 1 tooth
3 Dry joints on switch open and close or connector from CD tray to system control intermittent contact
In any case it require a qualifier Tech from Panasonic to reset the timimg gear or service
I hope that give you some ideas if you need further info or service manual I am willing to help you out
Cheers
Dec 08, 2008 | Technics Audio Players & Recorders
Tray will not stay closed
This fault usually happens if the disc being read is not compatible with the player's firmware.
If discs are burnt from a computer, or copies, this can happen.
Does it do this with all DVD's?
Are you using commercial retail DVD's?
Otherwise something else is telling the player 'No Disk'.
Try a disc-based lens cleaner as laser may be grubby.
Or the laser diode could be defective.
Nov 21, 2017 | GoVideo D645 DVD Player
Disk tray won't stay closed
i have same problem with mine, if i close the tray quickly by hand after it re-opens,it usually starts reading the disc
Jun 14, 2008 | Microsoft Xbox 360 Console
RCA DRC83200N DVD Recorder tray won't stay closed
hit the top of the player hard. really, it works.
Dec 15, 2007 | RCA DRC8300N DVD Recorder/VCR
Cannot Close Sony DVP-NC665P 5 disk tray
There is a possiblity that he may have shifted the unit while discs were in it causing the discs to slip off the tray and into the unit. You have to open the unit to check if there are loose discs.
Nov 12, 2007 | Sony DVP-NC665P/S Multi-disc DVD Player
Tray confused
I have an LG DVD player and recorder model # RC7423W and i have a similar problem, when i open up the disk tray it displays open and the tray opens for 2 seconds only and then closes. when i press the open/close button to open it again it opens and never closes back with a "Disc Error" on display until i close it manually by pushing it back inside.
I cleaned it from dust many times and tried to reset it but no reset button. i just tried to unplug the wire and plug it back.
let me know if there is a way that i can reset the hardware or a solution to my problem. my system is around one year old
Oct 22, 2007 | LG DR787T DVD Recorder
PS2 disk tray keeps opening
try holding the disk drive after it closes for a few seconds and see if it stays closed or one of the drives gears could be stuck,loose,or broken.you might need to open it up.
Jul 05, 2007 | Sony Playstation 3 (PS3) Console
Microsoft Xbox 360 Console Logo
98 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
