Question about Amana NDG2335AW Gas Dryer
Amana dryer wont work
We have a Amana dryer(gas) NDG2335AWW. The timer dial wont turn and it wont heat. We get heat every so often but the dial still wont turn. We had a new timer put in and it still dont work. Maybe you could tell us whats wrong. Thanks so much.
  • Anonymous Feb 23, 2009
    I have the exact same problem. . . What is wrong?
  • evan0168 Feb 23, 2009
    I have the exact same problem - it always spins but most of the time it doesn't heat up. And the timer doesn't always work.
I'LL let you know after the Amana repair man comes out.
Mine is doing the same thing and I can't figure it out
Posted on Apr 15, 2011
  • bparrish29 Jun 08, 2012
    what did they say the problem was? I can't figure out what is wrong with mine....i replaced the timer but didn't help anything.
AMANA HEAVY DUTY DRYER model #NDG2335AWW
m ost likely one of the rear drum support rollers is bad. the part number is 37001042.
Mar 21, 2012 | Amana NDG7800AW Gas Dryer
Timer wont advance runs non stop will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 17, 2011 | Amana NED5200TQ Electric Dryer
Timer does not turn and no heat
heatman101
Jan 23, 2011 | Amana ALE443RAW Gas Dryer
Hello, I have Amana LG4309W heavy duty gas dryer.
sounds like one of the supply fuses at the house panel,these 240 volt dryers are wired so the timer is on one phase(120)volt and the motor is on the opposite phase(120)volt and the heating element is on both phases for a combined 240 volts,if you lose one phase you either wont get motor operation or timer operation,and for sure no heat and you have the timer so you have 120volts
Jan 08, 2011 | Amana Dryers
Amana dryer, no heat, drum turns, timer not advancing
heatman101
Dec 13, 2010 | Amana DLE330RAW Electric Dryer
Amana NDG2335AWW Gas dryer LP or Natural?
If there are no stickers indicating so, you will need to open up the dryer and measure the gas orifice. A propane orifice should be either a #54 or #58.
Jan 13, 2010 | Amana NDG7800AW Gas Dryer
Amana Gas CLothes Dryer Mod#NDG7800AWW dryer will heat and does dry some but when it moves to the less dry the dial does not move and the dryer does not heat
if your clothes are damp because you say it does dry some what then it sounds like it could be the gas coils,the coils will work for awhile but then they fail and the timer will not move if there is no heat on the more or less
Oct 30, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My amana gas dryer model # NDG2330AWW timer will not work. It only turns so far and then stops. The dryer is not getting hot and the will not turn off unless I manually turn the dial to off.
HI. this timer mechanism is the Principal initiator of the units entire cycle when in action. You will not receive any heat if the timer motor has failed. Have this timer module replaced asap. this will fix this issue.
Aug 26, 2009 | Dryers
Amana gas dryer ALG331RAW timer does not work and no heat
HI, the timer is defective. the heating process can be affected if the timer isn't functioning correctly. replace this failed timer asap. this will fix the issue.
Jun 19, 2009 | Amana ALG331RAW Gas Dryer
Amana dryer timer dial wiil not rotate/temperature stays hot
The elctrical contacts in the timer have welded themselves together or the notch wheel is broke in the timer; either way you need a new timer, and this also explains why it runs until you open the door.
Apr 10, 2009 | Amana NDG7800AW Gas Dryer
Amana NDG2335AW Gas Dryer Logo
217 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you an Amana Dryer Expert? Answer questions, earn points and help others
