Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Washer does not fill with water
If i fill the machine manually with water it works well until the water is pumped out, it then refuses to re-fill with water, if i then fill machine manually it works through untill the wash ends and displays the end light on display panel
I checked the inlet solenoid valve to make sure it was receiving power, it was. I removed the left hand side panel of the machine. The labyrinth was blocked with crud as was the float switch assy,
Cleaned them out,with boiling hot water, it now works.
Posted on Mar 21, 2009
  • cley123 Mar 21, 2009
    P. S
    If your your wife used dishwasher cleaner for the first time it sometimes causes this to happen as it sends down lumps of crud on older machines
    CLEY123
Washer fills and washes clothes but water doesnt drain and go into spin it just sounds like its still pumping out and no error code
Quite possibly there may be something stuck between the pump and the drum which is preventing the water from draining down into the pump. The pump is still working but there is no water to pump out, and the machine can't advance until the water is gone and the pressure on the pressure switch is relieved.
You will have to manually empty the machine and then remove the offending article from the tub to pump hose.
Feb 19, 2014 | Frigidaire Affinity ATF7000E Front Load...
Hotpoint wmud962
bidatw . com the cheapest software you can get!!!!!!!
Jan 17, 2014 | Washing Machines
My 5 year old zanussi 1449 E washing machine is not taking in water on any programme. water feed is ok
Water pump has quit. You can fill manually until you can replace pump or washer
Aug 04, 2013 | Zanussi Washing Machines
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Mixed Water Fill Causes Issues with Water Pressure
You will have to be specific about what problem the pump is having. It seems to pump ok for everything else. Could the hot solenoid be shorting and sending electricity down the water to bother the pump? Solenoids are not real expensive, try a new one.
Apr 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 700 series, almost new
i would start by taking the pump off the motor and starting the washer if your washer agiates something is probably in the pump if the washer still does not work with the pump unattached to the motor you could have a bad motor
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washer refuses to move to next cycle
Can you still open door when it has filled?If so it is intermittant door lock .If no new progame card required.
Nov 05, 2008 | Hotpoint Aquarius WD63 Front Load...
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
405 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
