Question about Panasonic Lumix DMC-FZ5 Digital Camera
Fuzzy pictures from my Panasonic DMC-FZ5
I'm pretty new to this camera but I'm trying to use other settings than the "simple" one. My problem is that I keep ending up with fuzzy pictures -- even when it's on the SIMPLE setting!!! Any suggestions for getting clearer shots with this camera? Thanks Suzie
    Genius:
  • 2,985 Answers
Fuzzie picture -meaning out of focus? Check that you have not got 1- macro setting on [setting symbol looks like a tiny plant] or that you have a low light setting which menas it is taking long exposures. Aslso the Auto foxus may not be function as it should - one possibility is that the way you hold the camera covers the 'window' make sure your fingers are aware from any of the front top panel 'windows' When you depress the shutter part way down- does the lens 'motor' to focus Or indeed are you doing part way or are snapping off shot and giving the camera time to focus? Lots of thing for you to check out, before we start getting worried. The difficult ones are if the camera has taken a knock and the lens mount has become dislodged But do all the check first and do consult the manual
Posted on Jun 14, 2007
First, check to make sure the lens is clean - dust, smears or fingerprints can cause this problem. Turn the camera on in any picture taking mode, press the "menu" button and scroll with the down or up arrow buttons until you reach "Cont. AF" which can be on or off, (on is better)and "AF Trigger" which should be set to the button position. Also note the "AF Mode" which lets you select the type of autofocus (see manual for details). Objects not in the autofocus zone may not be in focus. Next is to make sure the autofocus is working. Try taking a picture of a non-moving object, well lit, centered in the viewfinder, using the "time delay" function and the camera held steady on a tripod or table. If that comes in clear, then we know the autofocus is working. If not, then repair or replacement may be in order. With the camera off, try gently pressing the shutter button, it should go down a bit. That position activates the autofocus. Then press a bit harder and the button hits bottom to activate the shutter. Practice until you can reliably feel the autofocus and shutter positions on the button. If you jab down the button too quickly, the autofocus doesn't have time to work before the shutter goes off, and the pictures may be fuzzy. Thy to hold the camera steady while taking pictures. The image stabilizer can compensate for a little movement, but it has its limits - move too much and the image will be blurred.
Posted on Sep 06, 2007
With this camera I was also having a problem with pictures being out of focus (Most easily noticed on macro or telephoto shots). Fortunately the solution was as simple as making sure that the battery was nearer to a full charge. Apparently the focus does not respond as well when the battery is low. Good luck!
Posted on Aug 01, 2007
When half press the shutter button, the camera immedietly snaps a picture, it does not focus on the object or get the correct exposure.
Yeah,why did you half press the shutter?When you take a photo,you should press the shutter with force quickly.I think you didn't set your Panasonic Lumix DMC-FZ5 Camera at a proper mode for the scene,shot with a correct the next time.Wish helpful to you.
Nov 22, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
Got our Lumix DMC-FZ5 in 2006, and every picture we have ever taken inside is blurred, no matter what we do with shutter speed, aperature setting and flash. Also tried using the Party scene, as well as...
Are you pressing the shutter button half-way and allowing the camera to lock in the focus (it will beep) before pressing the rest of the way? Have you tried setting the camera on a firm surface or a tripod and fired off a few shots to see if they are better?
Oct 07, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
Replacement cable for Panasonic Lumix DMC-FZ5
Forget the cable. Do what the pros do...use a card reader.
Jan 23, 2010 | Panasonic Lumix DMC-FZ5 Digital Camera
Pictures duplicating
I have a Panasonic DMC-FZ7, and there is one setting that I know of which will cause two images to be recorded:
#1. Open both photos in the computer and check the ending of the file name. One of them will say ".jpg" or ".jpeg" and the other photo will say ".tif" or ".tiff".
#2. If this is the case and you want smaller, compressed pictures, turn off the TIFF setting in your camera. It should say how to do this in the user-manual.
Found my reply helpful? Please write a review on your Panasonic DMC-TZ5 here:
http://www.photographyreview.com/mfr/panasonic/8-10-megapixel/RVF_412070_6446crx.aspx
Aug 26, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic lumix dmc fz5
Just use a Cardreader for this purpose.
... or maybe try using a new cable.
Mar 24, 2008 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Problem
Possibly the shutter release (the "take a picture button") or the mechanism under it is getting stuck down and not coming back up to let you take a second shot.
Try cleaning under there with a can of compressed air. Be careful because the release button is super fragile - looks big but only held on underneath by a tiny stalk about the size of a pin (I know because mine broke off when the camera dropped). Panasonics are light but fragile, others, like Sony, heavier but much more solid.
Oct 22, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
169 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
