Question about HP Pavilion Dv8380us Notebook
Screen flashes as desktop initilizes very slow
Hp dv8380us with intel, xp media, 2g ram, nvidia graphics. if i uninstall the graphics card the computer will boot and work find just in low resolution. when i reinstall the vga driver the symptoms return. during boot (without the driver installed) i get a screen with lines and then a screen with dollar signs just before the windows splash screen.
The hp dv8380us has an issue with the nvidia 7600 go graphics chip when the manufactured this laptop they didn't use the proper heat sink and heat sink compound so it causes the graphics chip to over heat. and when it over heats it causes errors as you explained. i also have a hp dv8380us  and have the same issues and haven't found a fix. mine also shows the picture 4 times as big as the lcd so i can only see 1 fourth of the picture i can see it fine if i hook it up through the vga port though. hope this explains your problem.
Posted on Apr 13, 2009
GEForce series AGP 5500 256MB when connected using Windows xp OS there is no display in the monitor intel pentium dual core 2g ram
If you're having trouble on display in your monitor,please check the following;
1. Check your CPU if its responding,booting or the power light indicator is running.
2. Check the video card slot pin if its align and clean,as well as the serial/com cable connected ion both ends.
3. Try to replace another video card, might the current attached is damage.
4. Check all cords and see if there's some intermittent lines neither need to replace new cord.
good luck,
Jun 29, 2011 | Nvidia GeForce FX 5500 Video Card Graphic...
I have dell inspiron 1545 intel media graphics accelerator 4 series chip set family. i cant play good games like crysis, mass effect, assasins creed etc. what should i do to play it. anyone please help me?
Minimum System Requirements
OS – Windows XP or Windows Vista
Processor – 2.8 GHz or faster (XP) or 3.2 GHz or faster* (Vista)
Memory – 1.0 GB RAM (XP) or 1.5 GB RAM (Vista)
Video Card –256 MB**
Hard Drive – 12GB
Sound Card – DirectX 9.0c compatible
* Supported Processors: Intel Pentium 4 2.8 GHz (3.2 GHz for Vista) or faster, Intel Core 2.0 GHz (2.2 GHz for Vista) or faster, AMD Athlon 2800+ (3200+ for Vista) or faster.
** Supported chipsets: NVIDIA GeForce 6800 GT or greater; ATI Radeon 9800 Pro (Radeon X800 Pro for Vista) or greater. Laptop versions of these chipsets may work but are not supported. Integrated chipsets are not supported. Updates to your video and sound card drivers may be required.
Recommended System Requirements
OS – Windows XP / Vista
Processor – Intel Core 2 DUO @ 2.2GHz or AMD Athlon 64 X2 4400+
Memory – 2.0 GB RAM
GPU – NVIDIA GeForce 8800 GTS/640 or similar
Apr 01, 2010 | Dell Inspiron 1545 Notebook
Dell Precision 450 new Graphics Card problem
drivers vga.dll version 5.01.2600.000(english)date 2/28/06 04;00:00 whql logo'd:yes mini vdd:vga sys vdd:n/a ddl version:unknown directx feture directdraw acceleration:not available direct 3d acceleration: not available agp texture acceleration :not available teste draw test direct3d the system is using the generic video driver please install video driver probided by the wardware manufacture. directdraw test result:all test result: all tests were successfull: direct 3d funtionality not available.you should veryfi that the driver is final ;from the harware manu facture. ram 512 mb storage capacity 160gb raid no graphics card:intel graphic media accelerator 900 gm primary optical driver dual-layer dvd+/-rw
Dec 03, 2009 | 3Dlabs AGP Video Cards: Wildcat VP560 64MB...
I just bout a evga geforce 9400gt 512mb pci I install the card into the pci slot.Turn on the computer and everthing works ok untill i install the drivers First of all when i install the drivers in regular...
The two biggest problems in XP is audio drivers and graphics drivers. From a long experience dealing with all kinds of graphics cards and drivers I would say that the driver you are installing is not correct for OS and your card. Not sure what you are using that makes you think it is but I believe it is not. If you are using a driver scanner software then beware. Your best bet is go to here..
http://www.nvidia.com/Download/index.aspx?lang=en-us
..this will give correct driver. This will probably fix BUT keep in mind that the pc beeping means hardware issue, so0o0oo not having the correct driver will also cause this, but usually not with a graphics card or it's driver. Usually this is mobo, ram, hd, etc.
Oct 23, 2009 | Computers & Internet
Problem with my geforce4 mx
Sounds to me like either the card is bad or you have a corrupt driver. If you remove the card will it start? then it is a bad card. If you uninstall driver either through safe mode (hold F8 at powerup before windows starts) or restore to last known working config (also F8). I suggest you go to nvidia website to download your drivers. let me know if you are still stuck, we'll work it out.
seth
Jun 27, 2009 | Nvidia GeForce4 MX440SE 128 MB AGP Graphic...
I have a HP Pavillion Desktop a1600n,XP media, No video on screen
Since you have another vga card, is it pci, if it is install it to see if if works, if it does them problem solved, if not let me know then can help ya further.
Mark
Apr 03, 2009 | HP Pavilion a1600n (882780776265) PC...
I want to know of a graphics card that supports vista graphics can play fallout 3. this card needs to be for agp x8 and under $50 can you help???
Minimum requirements
  • Windows XP/Vista
  • 512MB System RAM (XP)/ 2GB System RAM (Vista)
  • 2.4 Ghz Intel Pentium 4 or equivalent processor
  • Direct X 9.0c compliant video card with 256MB RAM (NVIDIA 6600 or better/ATI X850 or better)
Jan 20, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Cost of game hardware in india
2GB RAM should be about $100, the same for installation. Your current graphics card meets the specs you provided. An upgraded video card will be about $200 for one that will work, $300 for one that will work well.
Jan 19, 2009 | Computers & Internet
Pc games hang in the middle of the game
1st on the list drivers
2nd ram
3rd faulty video card
do a fresh intall on another hard disk and then install driver and game see if it works if it does drivers if not ram.
Dec 30, 2008 | XFX NVIDIA GeForce 8500 Graphic Card
HP Pavilion Dv8380us Notebook Logo
79 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
