Question about Southwestern Bell GH-5812 Cordless Phone
Turn off ringer
The ringer rings too loud and long.
    Novelist:
  • 201 Answers
No specific knowledge of your model but I have seen many people place tape over the housing holes for the ringer to cut down the volume level on phones where the ringer is too loud.
Posted on Jul 05, 2007
How do I change silent from on to off so phone rings when I get a call?
On the D1680, D1481, and similar phones,
the three levels of ringer loudness plus
"off " are set at the base using the same
[ - ] Volume [ + ] buttons used to adjust
the answering machine message volume.
Pushing the [ + ] and [ - ] keys will
set the ringer to be louder or softer. A
number in the "message counter display"
will report the relative loudness...pushing
[ - ] below level-1 loudness will show
"0" loudness and an announcement of
"Ringer off" will be spoken. From here,
a single push of [ + ] will turn the ringer
on to level-1 and play a ~10 second
sample of the ringer at that volume:
while it is playing the sample ring,
subsequent pushes of [ + ] or [ - ]
will toggle the loudness levels of
( off, 1, 2, 3 ).
Jan 05, 2016 | Uniden DECT 6.0 Cordless Phone ID
I have a NOKIA 2610b go phone, How do you turn up the volume on the ringer?
I've worked in the cell phone industry for many years. The big Nokia phones is that most of them never ring very loud. The have a history or blown speakers when they have loud ringers.
Try going under Profiles and changing the ring to outdoors. that will make it ring louder but probably still not loud enough
Oct 13, 2009 | Nokia 2610 Cellular Phone
How to adjust ringer volume
Yours is a little different from mine, but maybe this will help some, I hope. On the "talk" side, there is a button (2nd from right on mine) which says "loud" over the button, and "ringer" under the button. Pushing the button once gives you the soft ring. Pushing the button again will give you the loud ring. If you have gone to the loud ring, you will get the loud ring on the first time. Then you can push it again to get you back to the soft ring. I hope this helps.
Jan 23, 2009 | Panasonic 900 MHz Cordless Phone
Lowering ringer volume on handset v tech 5.8 digital phone
You didn't indicate exact model of your phone. However I have indicated the procedure used for common Vtech's 5.8Ghz phones
Ringer volume
• With the handset or base in idle (off) mode, press MENU then
press ▲ or ▼ until RINGER VOLUME is shown
• Press SEL. You will hear a sample of the ringer
• Press ▲,▼ or a digit (0 through 6) You will hear a sample of
the new ringer volume and the volume bar will be increased or
decreased each time the setting is adjusted At the lowest setting
the ringer will be turned off and the display will show:
- OR -
• With the handset or base in idle (off) mode, press or of the
volume control will directly go to ringer volume menu
• Press ▲ or ▼ to adjust the ringer volume
Good Luck
Nov 11, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Phone ringer is too loud
WHILE the phone is ringing, push the down arrow key.
Aug 27, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
I have a number of telephones (1927-1970) that work but do not ring and need instructions. Thank you.
If the phone has a dial tone, adjust the ringer loudness (this adjustment is on the bottom of some phones). Also check to see if there is a switch for turning off the ringer--and turn it on.
In some cases, you can't connect more than five phones to a given line or they won't ring properly. If this is your situation, you may have to disconnect one or more phones, or at least turn their ringers off.
Jul 26, 2008 | Lands Phones
Telephone ringer volume
make sure phone is off, then hit prog it will say directory arrow down with the volume key until it says ringer tone. it give 4 options for ringer tones then has off hit select and there you go
Jul 03, 2008 | Vtech 5.8GHz Analog Cordless Phone
Pebble ringer inop
1 try this go setting initial/setup/master clear
password 000000 (6time) or full up 0 .
Mar 03, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Loud key sounds
with your v3 press <<>> select <<>> select <<>> in <<>> you must choose a ring style exemple:<<>> then goto <<>> and move to <<>> and change 7,6,5,4,3,2,1. Normaly, i put number 3 it's loud enought.
Aug 22, 2007 | Motorola Mobility RAZR V3
Phone Doesn't Ring
If the phone has a dial tone, adjust the ringer loudness (this adjustment is on the bottom of some phones). Also check to see if there is a switch for turning off the ringer--and turn it on. In some cases, you can't connect more than five phones to a given line or they won't ring properly. If this is your situation, you may have to disconnect one or more phones, or at least turn their ringers off.
Jan 18, 2006 | AT&T 146 Corded Design Line Telephone
Southwestern Bell GH-5812 Cordless Phone Logo
150 people viewed this question
Top Southwestern Bell Lands Phones Experts
Hollyecho Montgomery
Andrew Taylor
Andrew Taylor
Are you a Southwestern Bell Lands Phone Expert? Answer questions, earn points and help others
