Question about Tablets & eReaders
C:\resycled\ is not a valid win 32 application.
I can not open my any drive.
  • 1 more comment
  • Anonymous Jan 16, 2009
    I have the same problem with Windows XP (running on my Sony laptop)!!
    Anyone now how an easy way to solve this big prob?
  • Anonymous Jan 17, 2009
  • Anonymous Jan 19, 2009
I just had this problem and went to a few forums for answers.
Update your anti-virus program and restart your PC in safe mode by repeatedly pressing the "F8" key upon restarting.
When in safe mode, use your anti-virus program to scan your computer. When the scan is done it should tell you if it found anything that could be bad for your system.
When scan is finished, go to My Computer - Tools - Folder Options - View
When in "View" click on the button that says "show hidden files and folders". Select the "apply" button, then "OK".
Now, go to your infected drive (the one you cannot access) and "right-click" the drive followed by "open".
You should see the hidden folder "Recycler - resycled - Autorun.ini"
Select the files and then press and hold the "shift" and "delete" keys at the same time, then press the "enter" key. Restart your computer, and you're done. You should now be able to access the drive that had a problem.
If you do not see these files then chances are your anti-virus may have already taken care of the virus affecting your computer.
hope this helps
Posted on Jan 20, 2009
How do I fix this: Apps were downloaded but Icons don't show and I can't open them?
Pull a downward one finger swipe on the springboard to initiate spotlight. Type the application name to see if the global prefs log has recorded that you have the application installed with a valid owner code signature.
if applications were installed with another appleID and require an update to execute but you are signed into the AppStore with a different appleID, the situation you are describing can occur.
Aug 04, 2014 | Apple iPad Tablets & eReaders
Restore win 7 from system image on toshiba portage m200
This should apply to other brands and models...
the original problem: bad hard disk, need to restore from win 7 image disks however The portage m200 lacks an optical drive and cannot be booted from usb (only options are to boot from LAN or from a specially created SD card).
you will need a second pc that can boot from an on board or peripheral optical drive. Swap the second pc's hard drive for the one that you are restoring. Now boot the second pc from the restore disk and follow the onscreen instructions. Once completed the pc will try to reboot and you will get an error about how windows couldn't repair start-up. Now power down and swap the hard drive back to the portage. You should now be up and running, much easier than trying to create a boot-able sd image or boot from a PXE server.
on Oct 10, 2010 | Toshiba Portege M200 Tablet PC
Apps not showiing
MPF REGISTRATION Due to a high volume of traffic, we are currently experiencing problems with the Mobile Parental Filter server. Please follow these steps in an effort to resolve the issue. 1. From the homepage, go to Settings > Applications > Running > All. Select The Mobile Parental Filter app and tap the Clear Cache button. Press the power button and reboot the tablet. Once the tablet reboots, try to register the tablet again. 2. From the homepage, Web Browser Menu [on the right, three vertical dots] > Settings > Privacy and security [left] > COOKIES [right] > Clear all cookie data. Press the power button and reboot the tablet. Once the tablet reboots, try to register the tablet again. If these steps do not work and you continue to experience Mobile Parental Filter issues, we sincerely apologize. Please be patient and try registering the Parental Filter at a later time. PRELOADED APPS MISSING To re-install the Default Applications to your unit please do the following: 1.) Download the file called to your computer from the following website: 2.) Extract the .zip that you downloaded to your computer. You will need to use an extraction program such as Winzip (, Winrar (, or 7zip ( to do this. 3.) Once extracted you should now have a folder called RecoverApps that if opened has a bunch of APK files in it. If you open it and find another RecoverApps folder in it open the second one, that will have the APK Files. 4.) Connect your unit to your computer and open the drive on your computer so you can see all the folders in it. Copy the RecoverApps folder that actually contains the APK Files into the folder on the unit called System. 5.) Once the copy is finished disconnect the unit from the computer and on the unit go to Settings -> About Tablet -> Start Wizard. Confirm you wish to run the Start Wizard. Then turn the unit off and then back on and you will be taken through the Start Wizard. Once completed the Default Applications will be re-installed to the unit.
Dec 27, 2013 | Toys R Us Tabeo
How can I install win 7 on m1400
You can but I do not recommend it without upgrading your RAM to 1 gb. But you should be able to move the Win7 install files over to a flash drive and boot to it if you do not have a cd drive.
Mar 14, 2011 | Motion Computing M1400 CENTRINO 1.1G 512...
My windowista does not open or says enter validate pass words
before windows boots, its a bios password thats needed.
Google bios password bypass
If its after windows has booted
google windows password bypass
Jul 18, 2010 | Intel Tablets & eReaders
I have installed linux umbutu and it removed my win xp. I have an older win xp-cd but now it doesn't find my harddisk. what should I do?
you will need to live boot off the ubuntu cd and do a low level format of your hard drive. you can use gpart to do it
Nov 18, 2009 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Install new os on motion le 1600
You can use an external USB drive, either CD or DVD dependent on your OS media.
I used a Phillips drive, with external power supply, to restore to factory settings using their restore CDs. I also installed Windows Vista Ultimate from DVD, without issues :)
Mar 30, 2009 | Motion Computing M1400 CENTRINO 1.1G 512...
Booting from a USB Stick
Here you go:
Download the Ubuntu Live ISO (if you dont have it already) and burn it to CD
Restart your computer (booting from the Ubuntu Live CD)
Insert a 1GB or larger USB flash drive
Open a terminal window and type sudo su
Now type fdisk -l to list available drives/partitions (note which device is your flash drive Example: /dev/sdb). Throughout this tutorial, replace all instances of x with your flash drive letter. For example, if your flash drive is sdb, replace x with b.
Type umount /dev/sdx1
Type fdisk /dev/sdx
type p to show the existing partition and d to delete it
type p again to show any remaining partitions (if partitions exist, repeat the previous step)
type n to make a new partition
type p for primary partition
type 1 to make this the first partition
hit enter to use the default 1st cylinder
type +750M to set the partition size
type a to make this partition active
type 1 to select partition 1
type t to change the partition filesystem
type 6 to select the fat16 file system
type n to make another new partition
type 2 to make this the second partition
hit enter to use the default cylinder
hit enter again to use the default last cylinder
type w to write the new partition table
Type umount /dev/sdx1 to unmount the partition
Type mkfs.vfat -F 16 -n usb /dev/sdx1 to format the first partition
"Alternately you can try mkfs.vfat -F 32 -n usb /dev/sdx1 (doesn't always work)"
Type umount /dev/sdx2 to ensure the partition is unmounted
Type mkfs.ext2 -b 4096 -L casper-rw /dev/sdx2 to format the second partition
Remove and Re-insert your flash drive
Back at the terminal, type sudo apt-get install syslinux mtools
Type syslinux -sf /dev/sdx1
Restart your computer, remove the CD and boot back into Windows
Using Windows to prepare and move the files to the USB Stick:
Create a folder named USB on your computer
Download using this link -
Now, extract the files to the USB folder
Move the Ubuntu  ISO downloaded earlier to the USB folder
Click fixu.bat from the USB folder (follow on screen instructions)
Move all files from the ubuntu directory to your memory stick
Reboot your computer and set your system BIOS to boot from USB-HDD or USB-ZIP. Also set the "Hard Disk Boot Priority" if necessary.
You should now be booting into Ubuntu Linux from your USB drive!
Dec 28, 2008 | Toshiba Satellite R15-829 Tablet PC
Can't install xp - freezes
You need a CD/DVD USB drive.
Ask for one or use a HD 3,5" USB drive, open de HD USB disconect the HD and conect a CD drive, it will work like a CD USB drive.
Jan 10, 2008 | ViewSonic Tablet PC V1100
Tablets & eReaders Logo
325 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
