Question about Sony PlayStation 2 (PS2) Console
FAT PS2 with Flip Top and Swap Magic 3.6 not loading backups
I just installed a Flip Top on my model 39001 (V7 I believe) fat PS2. It (more or less) loads up swap magic 3.6, yet after the disc stops spinning and I take it, and insert my backup (i've used shadow hearts, shadow hearts 2, god of war 2, silent hill 4), it shows that it's "Not a valid PS2 disc"
I am putting in the DVD, and they are DVD's, so this SHOULD work. When I hit x to load program, all i hear is intermittent single clicks from my ps2, then after a bit the clicks get loader, then it returns "Not a valid PS2 disc"
Any answers on this would be greatly appreciated. If need be I'll update this tonight with more information on what type of media, what burn speed, etc.
    Problem Solver:
  • 3 Answers
1. when you're burning your dvds, burn at the lowest speed possible, and use high quality media like sony
2. clean your lens
3. if that doesn't work, clean out the whole ps2
i use swap magic on the same model ps2, and occasionally get this message on lower quality media
Posted on Jan 30, 2009
I thought playstations are all formated to play any made of equal or lesser p.s. value such as p.s.3. should play p.s.2. games
I believe you're asking about backwards compatibility. While I agree a PS3 should be able to play PS2 games, it's sadly not always the case. While they all can play PS1 games, not every PS3 can play PS2 games. PS2 compatibility depends on the model.
Backwards compatibility with PS2 games has slowly been phased out. The original PS3's had hardware emulation (quite literally there is a PS2 inside of your PS3). The later revisions had software emulation only (PS3 processor pretends to be the PS2 processor), and then none at all. No slim PS3 has backwards compatibility.
Hardware emulation:
20 GB PS3 Fat/Original - Model CECHB01
60 GB PS3 Fat/Original - Model CECHA01
Software emulation:
80 GB PS3 Fat/Original - Model CECHE01
In my personal experience, there's no real difference between software and hardware emulation in terms of actual game play. Software emulation has a few hang-ups on some older games, but overall it works pretty well. And it's infinitely better than not having any ability to play PS2 games at all.
Links!
Wikipedia
Hardcoreware.net - Comparison Table
Sony - check compatibility of games with PS3
Hope that helps!
Sep 30, 2011 | Sony Playstation 3 (PS3) Console
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
How can i unlock my ps2 to play download
There are a few options that I know of, all of which include phsyically modding the console.
As far as I know, there's no softmod for any playstation product (other than the PSP). You'll have to either add a mod chip (which usually involves desoldering the original CPU and soldering the mod chip into place) or get a flip top (if it's a fat PS2). The flip top version is easier, as you're just replacing the top of the outer shell.
Jun 03, 2010 | Sony PS3 40GB Best Sellers Bundle Console
How can i modify my ps2 scph-30001
go to you tube and it shows u how to or go to e starland .com and buy magic 3 ps2 moder (its a dvd)
Mar 15, 2009 | Sony PlayStation 2 Slimline Console
Ps2 scph 77001 won't play backups on swap magic 3.6
This is a problem that has too many IF's in it lol. Let's take it from the top shall we?
When you said that you owned other PS2's were they the thick ones or the slim ones. Swap magic works best in the "thick older" models. In these new slimline ones it's got issues. That model number you posted belongs to a slimline model.
So since you're using a slimline model, I have to ask, Have you blocked the 2 sensors that you need to block in order to use swap magic. The slimline models are not like the older thick models. You need to block two sensors under the flip top so when you open the flip top the PS2 still thinks there is no swapping going on. If you have not blocked these sensors head over to youtube.com and start watchin vids with seach "how to block slim PS2 sensors" or "how to block slimline PS2 sensors" out of the three sensors you only really need to block two. If you have not done this at all, that is reason why it's not working. On older PS2 models you used a slidecard or some form of a flip top to swap out your disks. Nothing has changed on these slimline models. The PS2 still needs to be tricked out so it doesn't think you're swapping disks in and outa the system.
Hope that helps,
9x|
Oct 28, 2008 | Sony PlayStation 2 (PS2) Console
HELP! PS2 Fat
don't worry that one is easy
if you'll check the disc tray side you'll see a white slot where the ribbonwire should connect you'll also find some connectors colored pink green and white if you'll look thoroughly it is located beside those connectors
Jun 25, 2008 | Sony PlayStation 2 (PS2) Console
Swap Magic Problems
well .. i have changed my mind and thought i will help you.. can you tell me if the disc is spinning? If its not then try this..
The disk is not spinning because the flip top is not making contact with the sensors. Make sure the flip top is installed correctly. If the sensors are still not pushed down, boot up the swap magic disk and GENTLY put pressure on top of the flip top and see if the disk begins to be read. If it does, this means it is definitely the sensors. Like in my first post, open the ps2 and put a piece of thick tape over the rear sensor and a piece of tissue paper in the hole where the front cover opens. This will solve the problem.
Apr 25, 2008 | Sony PlayStation 2 Slimline Console
Swap Magic Problems
TOC disk error normaly occurs when tool 1 of the set that goes in the small square hole at the front left of the drive bay above the power switch is missing or installed wrong
have a look at this
http://www.mod-chip.com/Lite/Magic_Key_2_PS2_Install_Lite.pdf
Apr 24, 2008 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
795 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
