Question about Acer Aspire 5600 Series 5630-6951 Laptop
Laptop wont boot.
Battery light on, power light on fan starts 5 secs thats it. cannot get in to bios,
no power on dvd drive
  • 36 Answers
Do you get any video on the screen at all? in either case, it might be a motherboard problem, but try taking out your battery and unplugging power. wait a few minutes, then put them back in and try to boot. if you're still getting lights but no video or functionality, it's probably a motherboard problem and you're looking at having to get a new computer, or a very very very expensive repair.
Posted on Jan 16, 2009
I force removd keyboard witht shutting down the PC n the laptop shutdown. Since then screen only shows a milli-seconds deem light. DVD rom light blinking. Fan not turning, only a blinkin green light.
This is a very common problem with windows laptops. This may or may not help but here goes. unplug power. then unplug battery from laptop. Now plug only power cord into laptop. Now turn on and start tapping the F2 fuction key. Once it goes into bios make sure that your boot order is cdrom first. Then save it and reboot with the bootable cd in the drive.
Also if now of this works unplugged Hard drive and see if it will boot up at all and into the bios setting. If you are not able to boot into the cmos make sure also that no cd is in the cdrom drive.
Take your time. Good Luck.
Aug 26, 2015 | Computers & Internet
HP Pavilion dv4-2145dx stop working
while its off try holding down the function key and the microsoft key and the B button and press the power button and hold all of them down for 5 secs that will get u into the bios look around in there be careful set it for default settings maybe even test battery in bios thats just 1 thing the next step would require a couple small purchases to eliminate the easy things let me know if you want also take out you cd drive gently while laptop is off all the way off not hibernate let me knowl
Jan 14, 2013 | HP Pavilion dv4000 Notebook
My hp dv 7-1134 us will not turn on. When it start the boot up process the fan will suddenly stop and the dvd drive will make a noise as if its trying to start but wont. The screen stays black and wont...
ran for 2 days on AC pack only?
battery out, be clear there... it must run on ac alone .
the BIOS is next
is the screen with text?" or really is 100% black all the time.
remove the hdd if it makes abnormal noise, and check that BIOS screens work , even take out the DVD drive.
battery is already out. they short. get it out .
then push the bios keys, ESC?
this PC laptop has CCFL lamps that go dead.
so do the flash light trick first. while calling up BIOS.
http://www.pcdied.com/monitors.html#flashlighttest
Aug 27, 2017 | HP Pavilion Computers & Internet
Cant operate bios after reformatting the unit
If you cannot operate the BIOS, the best way is to reset the CMOS battery which require a very good technician to tear down the unit. Here are the steps:
Turn off laptop
remove cables and battery
Press and hold power button for 5 secs.
Remove screws in the edges of the laptop
Remove Hard drive, Optical Drive and Power supply fan
Press the CMOS battery (circle shaped silver coating) upwards so that it would disengage and put it back in...
Put back the Hard drive, Optical Drive and Power supply fan
Put back screws in the edges of the laptop
Put in cables and battery
Turn on laptop and the BIOS will be reset successfully...
Jan 09, 2011 | ASUS A8HE-4P017C (90NNVA4115384CAL301) PC...
About an hour ago, done a Toshiba Tempro BIOS upda...
Oh dear that's the worst thing that can happen during a bios update. the bios chip is probably now useless rendering the laptop useless. You will need a new motherboard I am afraid to say.
Jul 25, 2017 | Toshiba Satellite Pro L300D-EZ1002X...
Toshiba M305D S4830 laptop wont start
"I have M305D S4830 laptop. I put it to sleep in the night. In the morning when i tried to turn it on, it wouldnt start. The light on the switch turns on and it charges the battery fine, but no HDD activity(but it does spin up and stay), no screen, nothing. The fan turns on and then turns off in 1 sec and then just the power indicator lights stay on... i also checked cmos battery, removed it and put it back.its voltage is also fine..."
Hello PPL! Maybe this WILL HELP you! I HAD absolutely the same problem >> 3 months of god **** stress, didn't find any solution, till one day i found on my Recovery CDs one note!! >> It sounds like:
"BEFORE pressing power button, HOLD 'C' button and while Holding 'C' button push POWER Button ONCE!! to start Laptop, KEEP Holding 'C' button!!! untill appears TOSHIBA screen!" then release 'C'. After that, it will appear "Operating System not Found">>then just do a restart by pushing Power Button and Start again! For me, It Worked!! and i'm god **** happy now)...let me know if it Helped you, Good Luck!
Feb 04, 2010 | Toshiba Satellite Laptop with AMD Turion...
Satellite a135-s2356 aill not boot up
a friend had same issue , i dissembled laptop and found a burnt diode chip beneath where power button sits on top cover panel there are two clips under power button , one of the clips shorted the diode , only orange power button would lit up on front edge of lower case
Apr 25, 2009 | Toshiba Satellite A135-S2356 Notebook
Acer Aspire 5610 that wont boot up
Take battery out, press and hold power button for 10 secs, reinsert battery and try again?
Aug 15, 2008 | Acer Aspire 5610 Notebook
Wont start or boot up
I had the same problem and found that disconnecting the power lead and repositioning the ribbon cable from the on switch did the job after about 5 attempts
Aug 13, 2008 | Toshiba Satellite M30X Notebook
Problem with the power switch /motherboard
Remove the battery, plug it in and and try to turn it on. If it turns on without the battery, the most probable cause is battery worn out.
Oct 30, 2007 | HP Compaq nx5000 Notebook
Acer Aspire 5600 Series 5630-6951 Laptop Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
