Question about Maytag MDE9316 Dryer
How do you get the top off a ge dryer - Maytag MDE9316 Dryer
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    And the model number would be ????
  • 979 Answers
Go into the back of the dryer and you should be able to see the screws in the top of the dryer. They are short sheet metal screws.
Posted on Feb 15, 2009
Clothes dryer is squealing when turned on. suspect drum bearing. looking for a diagram for dismantling can i take the top off without removing the back panel( GE 5 cycle dryer)
You dont need a bearing you need the DRYER DRUM SLIDE Part number AP2041815 which is under $6.50 a piece. Take the top of the dryer off and look on the front of the drum. Some GE dryers have 2 and some have 4.Go to Appliancepartspros.com it item 316 they also have a diaphram.
Oct 10, 2009 | GE Dryers
Tip
How it works: Late model Ge top loading washer
The late model top loading GE washer is much different than it's original models that were so much more dependable than these newer ones are. To access the innards you must forst remove the front panel. Older models had the top pop up first but these newer models have the top bolted down. To get the top up you must first remove the front panel by using downward force on the top between the tiop and the front panel. It is not easy even for eperienced techs but cuss it a minute and it will come off. Once it is off you will notice the washer has an elecetric pump. Strings and junk get into this pump. It is easy to take apart and cleanup. The tub is suspended on 4 rods and the lateral movement is kept in check by 4 rubber cord mounted to the top called bungies. The motor and tranny can easily be accessed by removing the tub from the washer. After disconecting the power cable and pump the tub lifts out. Not all GE washers use the same motor or the same transmission method. Some do not even have a tranny. I have some GE washer service manuals.
GE front access late model washer
on Dec 13, 2010 | Washing Machines
How do I open the case on a GE dryer?
Of corse there is some variation among different GE models, but in general there will be one of two methods. Disconnect from power, then: 1. Open door and look for screws from top area of front panel into the dryer top to allow top to open, which in turn allows front panel to be removed. 2. If no screws, then use a putty knife to push in on the two clips which secure the top to the front panel. (right in the seam, front panel to dryer top, a couple inches in from each side.)
Sep 22, 2009 | GE DBSR453EBWW Electric Dryer
GE Select clothes dryer model DSXR453EVOWW
Open the door and remove the screws holding down the top. Then raise the top and you can get to the screws holding the front on. Get the front out and then the drum can come out so you can clean that guy out and replace that belt. How about some repair PHOTOS?
Sep 12, 2009 | GE Dryers
GE gas dryer gets hot but doesn't dry clothes like it used to
rule number one take everything off of it and never store clothes or anything that can insulate the top it overheats them. It kind of fools all your sensors when you store stuff on top
Feb 27, 2009 | GE DBLR333EE Electric Dryer
Ge dryer
Jim; without the model number it is hard to give specific advise. (model number is usually on the frame just inside the door) To open top, try pushing a putty knife in the seam between the dryer front and the dryer top, a few inches in from each side.
Nov 06, 2008 | GE DBSR453EBWW Electric Dryer
Ge dryer
Hi Thanks for the question .Open the door,screws under top. remove screws. lift up top. 2 screws on the inside of front , remove. pull front away front bearings on the front support. . thanks the appliance doc. Please rate my answer thanks
Aug 27, 2008 | GE DCSR483EA Electric Dryer
GE Profile Performance Dryer
GE Easy care 4 prong Installation
Grn = Ground
White = Neutral ?
Black = ____ top or bottom?
Red = ____ top or bottom?
Please advise
Aug 19, 2008 | GE Profile Harmony DPGT750EC Electric...
Taking the back off a GE dryer
You typically don't remove the back of a GE dryer. The Top comes off with 2 screws located in the top of the door opening and then the front has 2 screws that are located on the inside wall. Remove those screws and pull the front of the dryer out towards you from the top to expose the door switch and wires, disconnect those, lift up on the front and you have access to the entire inside of the shell.
Mar 27, 2008 | Dryers
How to get to heating element on ge dryer
Most heating elements can be accessed by removing the back cover of the dryer. Please unplufg the dryer first before starting this project.
Oct 25, 2007 | GE DBXR463EBWW Electric Dryer
Dryers Logo
48 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
