Question about Mitsubishi WT-46807 46" Rear Projection Television
I looking same parts to WT-46807
PCB 2HDW 211A36501 GCMK-MIX catalogue number of manual diagram is 935C908001
Maybe anybody know where i can bay this board.
Please respond to this same post or mail kedziorno1@wp.pl
Thanks
  • 10,594 Answers
Required board is available in Part Store.
Posted on Jan 14, 2009
How do I replace the fuses on a WT-46807 that protect the convergence circuit?
There are no fuses going to the convergence board, the converegnce IC needs replaced.
Aug 08, 2011 | Mitsubishi WT-46807 46" Rear Projection...
My Mitsubishi WT-46807 rear projection TV worked fine last night but this morning though it "clicks" and the green light comes on, there is no picture or sound from the television. I have tried to unplug...
I have a 64' samsung tv , It did the same thing and it was the lamp inside it. I bought it online at parts store.com, it works fine now. We fixed it ourselves and didnt know the first thing about tvs. Good luck
Sep 29, 2010 | Mitsubishi WT-46807 46" Rear Projection...
I have an older 200x model Mitsubishi 1080i 46" rear projection TV that no longer turns on. When first powered up the power light on the front blinks in sequence to note that I have a bad power supply or...
Parts for older Mitsubishi are difficult to find. If you give me the complete model number I can check if the part is available online.
In the meanwhile please, try the two websites below.
Encompass Parts Distribution
PartStore.com
Feb 10, 2010 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 Bottom of picture cut off
YOU HAVE A VERTICAL DEFLECTION PROBLEM, THE RETURN CAP IS DRYING OUT AND MUST BE REPLACED
Dec 27, 2009 | Mitsubishi WT-46807 46" Rear Projection...
MITSUBISHI WT 46807
You have a power supply decaying; it will likely get worse. There may be board repair of this available so locate the power supply board - look at the assembly that seems closest to the AC cord, check the board number and search on it.
NOTE: There may be more than one number on the board since the bare board may have its own but it will be obviously a part of the board. The assembled board number will look much more temporary and may even be on a label.
If you locate a service company that claims the ability to service it, pick their brains a little since it may not be a main power supply failure but rather another, possibly separate board that produces the high voltage for the CRTs. If you do find a separate board that seems to be servicing the CRTs, note that board number too and ask them about both.
Sep 30, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807
MY FRIEND YOU HAVE A POWER SUPPLY PROBLEM AND MAYBE THE CONVERGENCE IC'S ARE BAD.THERE ARE A FEW TRANSISTOR IN THE POWER SUPPLY THAT HAVE TO BE REPLACED FIRST.
CAYPIANAN@YAHOO.COM
Sep 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Wt-46807
IN YOUR CASE YOU HAVE COLD SOLDER, JUST PULL THE POWER SUPPLY AND YOU'LL SEE THE CONVERGENCE IC'S THEY ARE EASE TO INDENTIFY. THE NUMER STARTS WITH STK.....
CAYPIANAN@YAHOO.COM
Jul 23, 2008 | Mitsubishi WT-46807 46" Rear Projection...
TV is Ghosting
if convergence problem color would be bowed and off. If it is the convergence replace ic stks there are 2 inside tv if you could solder and good at this stuff. parts cost is 30.00 . if you are going to get fixed cost is 300.00 . www.part store.com has parts just give them model number .They can tell you part number.I would pay someone to do this it is trickey.
I think ghosting is ground problem on cable connections check connections and replace cable wire.
thanks doctor video
May 18, 2008 | Mitsubishi WT-46807 46" Rear Projection...
Mitsubishi WT-46807 46" Rear Projection Television Logo
165 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
