Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
Lenovo 3000 laptop won't burn DVD's
Using the Windows DVD maker, the process starts properly and runs for awhile. Then a notice comes up after about 98-99% completion and says "can't make a DVD". Any idea how I can fix that?
    Sergeant:
  • 367 Answers
I would right click the mouse on my computer select properties, select hardware and then select device manager. Select your dvd device from the list and right click on it select uninstall or remove. Then reboot the computer and it will reinstall itself.
2.) If the above solution doesn't work then try removing and reinstalling your burning software
3.) lastly turn off your Firewall and see if the problem persists. Belive it or not I have seen fire walls cause some weird issues.
Posted on Jan 14, 2009
DVD drive read/burn problem
From the description the new DVD driver is defective and should be returned if still under warranty. The only concern that I have is the replacement you got is identical to the original and that it is not a aftermarket product, because they don't have the same specifications as the original.
Apr 05, 2012 | Lenovo 3000 Y410 Laptop
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
NOT ABLE TO BURN THE C.D & D.V.D
Y510 uses the slot loading DVD, right? It's not software problem... that Matsushita DVD drive on Y510 and Y410 are faulty... they work only for a few months then always have trouble burning. I've seen many complaints on Lenovo support forum... I'm having the same problem with my Y410 too... I had to use USB to install Windows 7.
Oct 22, 2009 | Lenovo IdeaPad Y510 Notebook
Lenovo y410 MATSHITA DVD-RAM UJ-85JS driver free download
Hi
do you have a error message in the device manager or why do you need the drivers? all cd dvd drives work just by plugging them into the computer aslong as your windows is working properly they don't come with drivers.
please let me know if you are getting a error code and if the error code is 31, 32, 19, 39 or 41 then open up this page to get it sorted:
http://www.fixya.com/support/r548399-fix_non_working_cd_dvd_shows_in_device
May 21, 2009 | Lenovo 3000 Y410 Notebook
Lenovo DVD writer Creates sound
What kind of noise you hear?
Rising spinning noise is normal. When palying movie or music it gets to some level and continue with the same noise.
If it was not case before, then check the CD holder of your device for some dirt that might make your CDs not to be inserted proper.
Regards.
Mar 28, 2009 | Lenovo 3000 Y410 Notebook
Sound goes on & off on lenovo Y410 laptop
Next time it goes off, have a look to see if you have a service/process called Windows Audio running. Click Start & type "services.msc" in the search box (presuming you are using vista), then just press enter.
Look for "Windows Audio" & "Windows Audio Endpoint Builder".
Make sure they are running/started & set to automatic.
The problem could be a driver that did not install properly, a codec that did not install properly or a Windows update that did not install properly.
Feb 12, 2009 | Lenovo 3000 Y410 Notebook
Cd dvd writer not working
Try to reload the operating system using disk/Alt+F10 first and try to burn again.
If this is still not working. it probably your dvd rom is bad.
Jan 27, 2008 | Acer Aspire 3680 Laptop
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
46 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
