Question about Samsung 206BW Monitor
Samsung 206bw Monitor Flashes/Flickers on and off
When we turn the monitor on, it just flickers on and off every second. You can not read the monitor at all. I hooked up the monitor to my laptop and had the same issue.
The monitor was fine until last night when I turned it off... This morning, after boot up, this problem occurred.
any ideas?
  • 2 more comments
  • StephanBotha Jan 28, 2009
    I think I have the same problem.
    i changed the outputs on my nvidia 8600GTS (I have 2 DVI outputs). Still the same error.
    I switch my computer on, and the screen is off. then it goes on for a second and off for 5 seconds. I have no clue what to do.
    If someone has an answer to this, please email me.
  • Anonymous Mar 09, 2009
    Same problem here my Monitor died to after i swiched it of some days ago now it wont turn on again
    if i get an answer from samsung i let u know
  • jamsignal Mar 24, 2009
    I have about a dozen all doing the same thing.
  • Anonymous Apr 04, 2009
    I'm the original poster: My monitor just happened to come back on after this happened a few months ago.. We didn't do anything to troubleshoot. Today, I uplugged the monitor and the same thing is happening again.
Set the Hrts to 60 in Display Properties in control panel
Posted on Nov 17, 2011
SYNCMASTER 206BW PROBLEMS I started having the same problem about 2 weeks ago. The screen flickers on and off for about 15 minutes. Although I can see windows is running in the background, the screen...
Common problem with just about 905 of failed LCD monitors; bad caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Sep 26, 2010 | Samsung 206BW Monitor
White screen on a Samsung 206BW after it fell onto the floor
Something is wrong inside the monitor. I would call samsung support and get an answer from them. You could probably trade your monitor in aswell if its still under warranty.
Apr 18, 2010 | Samsung 206BW Monitor
My samsung 206BW flickers and will not stay on
change your resoulotion settings by connecting your display with some other display device
Dec 15, 2009 | Samsung Computers & Internet
My flat screen Samsung monitor flickers on and off and goes to black for a few seconds before flickering on and off again. I tried taking out the cable connecting it to the computer and it still flickers...
Yes probably your monitor should be check by a technician. Try to see the warranty for you monitor if its still catch the warranty service for it, they may replace it. Bring it back to where you bought it.
Oct 31, 2009 | Samsung SyncMaster 713BM 17" LCD Monitor
Monitor flickers and turns off. samsung syncmaster 204B.
this is very frecuent in all monitors or tv's lcd .... turn on 3 seconds and off the capacitors need to be replaced y sugest a technician
Sep 16, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Samsung 226bw visible flickers just after it is turned on
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Samsung 206BW Monitor Logo
751 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
