Do I need a converter box for a panasonic mnf. 2003
I do not have a cable box.Do I need a converter box for that model? I have lost some channels.
    Sergeant:
  • 233 Answers
Your set does not come equipped with a digital tuner..if you do not have cable, and you use a set top or roof top antena, you will HAVE to get a converter box. You are losing channels because some broadcasters have decided to switch to digital, or "test" their digital BEFORE the febuaray switchover date.
Posted on Jan 14, 2009
Hooked up a HD converter box. Lost TV
The issue should not be with your TV, I would be with the digital converter box or more than likely with your cable feed from your antenna. If you purchased a cable with connectors already on the wire, maybe the wire is okay. If you installed your own connectors on the cable, if they are twist on connections, you need to be sure that the outer braid makes contact with your connector. Double check your connections to and from the converter box as well to be certain you have not confused the antenna in and the TV out. I hope these tips help.
Oct 11, 2017 | Panasonic CT-27E13 27" TV
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Tv only goes to channel 135
In order to get channel 514, you will need to get the digital box/converter from the service privider. LCD's or plasmas are not capable of decoding those channels.
Jan 29, 2012 | Panasonic Viera TH-50PZ80U Plasma TV
Can my Analog reciver Panasonic DMR-EH 75 v be converted to a digital reciever
I bought a set-top converter box from Dish Network, which will operate with the DMR-EH75V through the remote control cable that was provided with the recorder. It tunes in all the available digital channels and uses the RCA A/V cables to connect to IN1 on the back of the recorder. TVGOS is now provided through channel 2.1 (CBS) in our area and it also provides the time signal that keeps the recorder's clock updated. NOTE: ONLY the Dish Network boxes work with these functions. I've had occasional issues with the box after some period - a few weeks - it needs to be rebooted or reset to manual and then back to automatic (which causes it to reboot anyway.) Model no is DTV PAL PLUS.
Jan 06, 2011 | Panasonic Diga DMR-EH75V DVD...
How do I scan the channels on a Panasonic 1080i HDTV? This is for the conveter box hooked up to the DVD/VCR to the Panasonic 1080i HDTV'
The cable to the antenna and another cable from the TV needed to be hooked up and THEN follow the directions that came along with the converter box.
Channel 3/4 and scan., be sure the antenna is strong enough.
There was no need to touch the DVD/VCR box.
Jun 12, 2009 | Panasonic PT-53WX53 53" Rear Projection...
I have lost some cable channels. I have a 2003 model panasonic tv with surround sound.Do I need a converter box?
kevin,
Try to access the "menu" of your TV screen and select " tuning mode" and click "auto program" and see if you can gain the channels that your looking for.
Jan 14, 2009 | Televison & Video
Can't tell if we need converter box for a Panasonic TV CT 27SC14J
this tv does not have a digital tuner. so, if you used an antenna to get off air channels, you would need a converter box. however, if you have cable or a satellite dish you will not need anything.
Oct 15, 2008 | Panasonic CT-27SC14 27" TV
Do I need Converter Box???
if it was purchased back in 2003 chances are that it is not digital TV ready and you would need to purchase a converter box.
Jan 02, 2008 | Orion STV2763 27" TV
Televison & Video Logo
47 people viewed this question
Top Televison & Video Experts
Electro Med Services...
