Question about Radio Shack Pro-2052 Scanner
Unable to adjust squelch on Realistic PRO-2020
I purchased this new a long time ago. It has been in storage
for the last few years. I replaced the battery and reprogramed it,
but can't adjust the squelch. I am guesing it is a resistor or diode
sort of repair. I am not sure if it would be safe for me to attempt this
repair.
I am trying to determine if it is worth repairing, and where to start.
Thank you for your time.
Greg
    Problem Solver:
  • 23 Answers
It may be that the switch is dusty due to it been left in storage try some WD40 on the back of the switch ..failing that there is a variable resistor inside that looks like a silver halfmoon or horse shoe shape that will alter the squelch but there may be a few so you could really do with curcuit diagram to see which one it is will try to find info for you .....
Posted on Jan 14, 2009
Why won't my Realistic Pro 2020 stop scanning
You might have the squelch turned up too high so the broadcast cannot break the squelch open. Here's an instruction manual (with how-to) for your scanner. Seems easy. Also make sure you have a good antenna so you can pick up signals.
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Radio%20Shack_PRO-2020%20VHF-UHF%20Scanner-Reciever_Short%20Manual.pdf
Sep 08, 2015 | Radio Communications
I need to download a manual for a realistic pro 2020 scanner
Here ya go:
Jul 01, 2011 | Office Equipment & Supplies
Is the Realistic Pro 20-20 Scanner obsolete? I can only program three digits on each side of the decimal.... Most channels today are in the xxx.xxxxx format.
Your PRO-2020, circa 1982, is old and tired, but not quite obsolete. The receiving bandwidth of this oldie is wide enough that you can just ignore the fourth digit. In some cases this may result in interference from an adjacent frequency, but it will usually work just fine. The 2020 is further limited in that it will not receive 800MHz frequencies, and it is not capable of tracking trunking systems or receiving digital transmissions, but what it does, it still does well. The PRO-2020, by the way, was one of the first keyboard-programmable scanners, and the first used in military intelligence surveillance operations.
Bill B.
Listening in since the 60's
Nov 16, 2010 | Radio Shack Radio Communications
Have a pro 2020 realistic programmable scanner. got working bu after turning off, turning back on will not scan. just shows - - - - - - - - . on screen
The memory on the unit is not retaining the frequencies. Check for a small battery on the circuit board like a button battery you would find on your computer motherboard. Replace the battery and reprogram the unit.
Aug 21, 2010 | Radio Shack Pro-2052 Scanner
Who to use a realistic pro 2020 20 channel scanner police
Wow -- that's an oldie! You can download/print operating instructions for the PRO-2020 here:
http://support.radioshack.com/support_electronics/doc45/45530.htm
If you need more info, I have a PRO-2020 in my collection, and I have the full manual for reference.
For a comprehensive database of active frequencies in your area, and a lot pf other useful scanning info, visit:
www.RadioReference.com
Bill B
May 15, 2010 | Radio Communications
Radio scanner no volume realistic pro- 2021 model #20-113 has loud squelch but voices only whisper what is the problem and how can i fix it. Thank You Lyman
frequency may not be accurate. get the correct frequency your tuning in to. could be off a few digits. then readjust your squelch.
Feb 16, 2010 | Radio Shack Radio Communications
NO SQUELCH
I have a Radio Shack Pro 97 Scanner that I received as a present 1-1/2 years ago. It was working just fine and then suddenly there was no squelch or volume. The keys make noise when pushed, but there is no sound for the squelch or volume. The scanner scans the frequencies but does not stop and play. I went on line and found that other people were having the same problems. I went back to the store that the unit was purchased from and received no help what so ever, they said it’ s off warranty and I was out of luck, nice way to do business??. I think that something that cost as much as this should not be junk after a short period of time. I hope you can help me with this problem I do like radio shack, but I can’t afford to buy items that don’t stand up.
Sincerely
Greg Stevens
e-mail
fooyun@sbcglobal.net
Aug 07, 2008 | Radio Shack Pro-97 Handheld Scanner
UNIDEN BEARCAT UBC 60XLT
The "e" represents Error, which means you made an error in your entry. Unfortunately, your scanner may be confused, meaning the computer is "stuck" on lockout and cannot get unstuck. I have the same scanner with the same problem... now. I had it looked at by Uniden's engineers, it cannot be fixed unless you replace the computer. They told me it would be best to buy a whole new scanner, probably a new model. So I did. I'm sorry I couldn't fix it for you. But Uniden said you'd be better off getting a new one. In my opinion, don't get a Uniden, get a Radio Shack/Realistic scanner, they're ten times better and are easy to use. For the best Realistic scanner, get a Realistic PRO-2006.
That's the one I have now, it's a gapless frequency scanner which means it can scann everything all the way up to the 1300 MHz band.
Sorry about your scanner though.
Best regards,
Gavin93
Jul 28, 2008 | Uniden BC60XLT-1 Handheld Scanner
Radio scanner not receiving
i ha ve realistic 2032 which is doing the same thing and was wondering because everything else including all the functions work fine including hearing white noise and being able to control it with the squelch could this be the end for it or is there stuff yet to do
Feb 28, 2008 | Uniden BC248CLT Base Scanner
Sharp Carousel Convection Oven. Model R-9H54.touch pad
It depends on what you mean by "a problem with the touch pad assembly".
If some or all keys do not respond, you would probably need a new keypad, but the key units for all Sharp R-9H-series models have been unavailable for a few years now.
These units did indeed last a long time.
Sorry I can't bring better news.
Dec 06, 2007 | Sharp R-370E 1000 Watts Microwave Oven
Radio Shack Pro-2052 Scanner Logo
431 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
