Question about Linksys Wireless-G Broadband Router
My DSL was installed. I am trying to hook up my linksys wireless router, when I do the internet does not work. What am I doing wrong?
  • Mark Egan May 11, 2010
    Was this a new Linksys router, or a used one?
    Have you ever connected to the router before? If so, was it wireless, or wired?
    If you have connected before, and can not connect now, has the router been reset?
    The router should connect to your computer, regardless of the internet. If it does, then doing as YvTech suggested is a start. Next step would be, type ipconfig /release, and wait until you see a command prompt again.
    Then type ipconfig /renew . After a few seconds, you should see you ISP listed, as well as some other information such as Gateway, etc, etc.
    Reply back your findings, and we can help you more.
  • YvTech
    YvTech May 11, 2010
    Plug the wan port on the Linksys to your dsl modem.
    Also is the your computer connecting to the wireless router? Can you ping it?
    Open a command prompt and type ipconfig /all
    Post the results.
  • 1,879 Answers
Modem type ? make sure it is on modem-only mode if it is a home-gateway type.
connect modem ethernet to router internet port (located next to the power port).
press & hold for 10 secs. the routers reset switch (until all lights blink).
launch the internet connection wizard & select "computer is connected to a gateway / internet connection is always ON"
Posted on Jan 26, 2009
Trying to hook-up a wirless router (Linksys WRT54G) to a SpeedStream 5100 for PS3 gaming on-line.
Before we configure router with PS3, we need first to make sure router is already configure to work with DSL modem. In Setting-Up a Linksys Router Using DSL Internet Service just click this link for reference.
And for PS3 configuration to connect wirelessly to a wireless router, just access the link below
Dec 22, 2010 | Linksys Wireless-G WRT54G Router
No internet access with wireless
First of all check the DSL cable must be in WAN port of the linksys router. if it is done then do the following.
Actually DSL modem and Linksys router are conflicting with their IP class. Means DSL and Linksys routers are using the same IP class of or
You must change one's IP class because both are routers and if they having same class they cant communicate. Unplug the WAN cable of the linksys. open browser and put ip or any one which works for u in the address bar. Username and password hopefully be admin admin or just admin and password blank field.
when you access the linksys router configuration page then come to LAN configuration. If there IP is then change it to and if it is then change it to Save configuration and reboot your laptop and plug dsl cable to linksys WAN port.
Hope now this will work.
Dec 30, 2009 | HP Pavilion dv6000z Notebook
AT&T just gave me a new Motorola DSL box and I can't get my router to even find the internet which is active. I can only get the router install portion to go just to where it can't find the...
First of all using the Router Install Portion try to do a 'factory reset' or a 'reset to default'  - wait for a reboot to see if any change occur.
Next try to use the cable between your Moto Box and your LinkSys Box in a different port on the link sys. It may sound silly, but it can work very well sometimes.
Sep 03, 2009 | Linksys Wireless-G WRT54G Router
After changing our att dsl service the main computer can access the internet but will not work with linksys router no wireless. How do I reconnect the router?
turn off the modem turn off the router hook the internet on the modem to the router install cd and restart before restarting plug the router and the modem to the out let and restart pc
Aug 05, 2009 | Linksys Wireless-G Broadband Router
Trying to get my verizon dsl to link with my linksys WRT54G route
The ethernet cable needs to be run from the dsl modem to the plug marked "internet" on the back of the router.
Apr 05, 2009 | Linksys Wireless-G WRT54G Router
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Linksys wireless router problems
Power down all the units. Power up the DSL first. After it is up, power up the router. After that is up, Power up the laptops one at a time. Let me know if this helps or not, there are other things to try after this...
Aug 17, 2008 | Linksys Wireless-G WRT54G Router
Linksys router
unplug your DSL modem. Wait 30 seconds and plug it back in.
Make sure the router is connected to a DSL modem. Lately I have seen DSL modems connected to offices that are really routers. If thats the case it may not be talking because the DSL is address the gateway with the same address as the router.
The best way to test this is to see what happens when you disconnect your linksys router and type in
in internet explorer.
If the DSL modem screen appears, it's configured as a router.
Then you will have to take the linksys router and turn it into a switch with a wireless access point. I
Jul 14, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
