Question about Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 misaligned colours
My printer is printing all the images 'shifted', almost as if the paper is being moved up and down slighty as it is printing, such that type is going up and down and images looked 'stepped'. This especially seems to happen with the magenta. I've tried cleaning and deep cleaning (which cleared up some of the smudging; now it prints clearly, but shifted...), and I've tried aligning the heads, both auto and manually to no avail. I've tried printing files from different applications (Quark, PSD, PDF) and they are all the same. Would this have anything to do with my refilling cartridges too often? Do I need to get all new, Canon ink refills? Any suggestions?
  • Jeff DeWeerd Jul 05, 2007
    As you'll see from the attached jpeg, I don't think it's a paper feed issue - the mistepped 'bands' are too perfect. The arrow indicates the direction it's coming out of the printer. If you zoom in on the type you can see the magenta is misaligned above on one band and then misaligned below on the next.
    Any other siggestions?
  • 186 Answers
Make sure the guides where the copy paper is loaded, are tight against both sides of the paper.
Posted on Jun 16, 2007
  • john archer Jun 26, 2007
    If the guides are tight against the sides of the feed paper, you can try cleaning the feed rollers that pull the paper through the machine. They are not always easy to get to. If you cant access them you might have to bring it to a tech. You can clean them with a rag and some rubbing alcohol.
SOURCE:
I changed two colour ink cartridges on my Canon iP4200 printer. Now it won't print colour. The pattern check does not print any colour.
You might want to double check to make sure that your printer takes two color cartridges? If I remember correctly, the Pixma takes one black and one color cartridge? If you put a color cartridge in the black ink assembly that would cause it to stop printing.
Double check and make sure that you have one black cartridge in the correct place and one color on the other side.
Apr 22, 2011 | Canon PIXMA iP4200 InkJet Photo Printer
Error number 6A00 for Canon Pixma IP4200 Blinking Power and resume light.
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 02, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma ip4200 willl not print Cyan
I think the problm lies between the ink tank and the printhead. When this passage runs dry, sometimes it takes time for the ink to fill this passage again. Try printing again after a day or two.
Jul 17, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
ALL PRINTING COMES OUT GREEN
this is a diffusion in a printhead. Check your print head
Thanks,
Mar 21, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Pixma ip4200 printer - canon
you mean the label paper for cd's, right?
Apr 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4200 paper won't feed
It won't take the paper. It makes the noise and something moves in there. but it won't feed it through.
Feb 01, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
No printing
If you are sure there is no paper jam,have you tried reseting the printer?
  • unplug the power cord for the printer.
  • press and hold the power button
  • plug the power cord in still holding down the power button
  • the power light should come on when it does release the power button
  • power on the printer like you normally do
hope this helps good luck
Nov 28, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Photo printing
if you have adobe photoshop click on image - selective colour- set the following cyan +15 magenta -5 yellow +10 black-15 this works on the pixma ip8500 so there is every chance it will work on others
Aug 18, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA iP4200 InkJet Photo Printer Logo
192 people viewed this question
Clive
Clive
old marine
old marine
