Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
Loosing gas from freezer
I have tried to remove ince from freezer using a knief. While doing that accidently broken the layer and lost gas. Could you please advise me is it safe to use the fridge and keep the food. Whether or not that would poison the food in the fridge.
  • 1,543 Answers
The gas is not toxic. Food will be OK from exposure to the gas, but refrig. will no longer work. It's time for a new refrigerator. (not economical to repair)
Posted on Jan 14, 2009
How doe I freeze fresh peaches
Blanch them in boiling water 1 minute, then dunk in ice cold water to peel. Cut them up removing the pit, and lay out in a single layer on baking sheets. Place in freezer for a day, then transfer to freezer storage bags and store in the freezer.
Sep 11, 2014 | Home
Kenneth Cole KC1104 wristwatch
You can contact Kenneth Cole in the address below:
Kenneth Cole Geneva Watch Co Inc
47-50 33rd
Long Island City, NY 11101
Phone: (718) 729-8600
Fax: (718) 729-8761
They will direct you to their parts department.
Goodluck..
Apr 05, 2008 | Kenneth Cole KC1104 Wrist Watch
Broken reed valve , need valve ,head gasket
These parts are easy to make. For reed valve, use feeler gauge material or old feeler gauge. This material is easy to cut or grind to size. Gaskets are a bit tricky but material is very cheap and with a little practice, you can make good replacement. If the old gasket was paper, use automotive gasket material sold at all autoparts stores. It is easier to cut thin gasket material so buy thinner than needed and layer. If the gasket is metal, use shim stock or beer / soda can). Good luck with your repair.
Sep 21, 2011 | Clarke Power Products Inc AC2001 2HP 4...
Hi I have a smeg fridge freezer and the I think I have accidently pierced it whilst defrosting, and the gas has leaked out. Am I still going to be able to use the fridge?
no and somewhere in the directions it will say do not use sharp objects to remove ice. call a service man but probally will cost high dollar to fix. best thing to do is get another one unless you are in love with this one.
Apr 17, 2011 | Smeg CR330SE 1 Bottom Freezer Refrigerator
Hi .....my mazda 3 2008 gas pedal not responding
I don't know if your Mazda is all electrically ran, but it sounds like it. It may be as simple as a fuse, but mine ended up being the entire fuse block had to be replaced. Also there may just be a loose connection, especially after an accident.
Mar 04, 2010 | 2005 Mazda 3
RED TEMP WARNING LIGHT ON MOTOR RUNNING
I'm sorry to have to tell you that this sounds like a very expensive fault to fix!
Either your fridge/freezer has degassed (lost the refridgerant gas) through a small leak in the pipe system behind or inside the freezer compartment, OR the compressor (what you called the motor) has started to fail.
Either way, these are very expensive repair jobs. It's possible to replace the compressor within about an hour, but if your model is out of guarantee, there will be around a £50/60 Call-out charge and the compressor will cost between £75 and £150 depending on the model.
Alternatively, if the fridge/freezer has lost gas, the engineer would have to try to find the leak - this could be IMPOSSIBLE if the leak is within the pipework inside the back of the fridge or above/below the freezer compartment.
I'm sorry to say that it's looking like you may have to part with a lot of money - or say goodbye to the fridge/freezer you have!
Nov 17, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Ice is forming on bottom and back wall of freezer can any one help with this
there are two types of freezer, one is upright freezer (same as refrigerator on outside look but inside all the layers are same as the freezer of an ordinaryrefrigerator) the other one is the chest type freezer(basically it looks like a chest cabinet),now about the forming of ice at the bottom and back wall, well should be all side of the freezer should have ice on it,
Just one question to ask? Did you used any sharp object in removing ice(ex. knife, ice pick , etc,)
If you do then there are a possibility that you do some hole on the tubes where the Freon Gas (chemical refrigerant) are passing thru, then in that case you might have leakage. Well that means you really need to call a technician to do the job, because you'll gonna need to fix the hole and re-charge a freon gas.(having not enough refrigerant on the system, your refrigerator might not able to produce ice completly.
The other possible reason is that your motor compressor might be damaged(possible reason: Lost compression) it has something to do with pump compression inside the motor (only technician can solve this problem)
Oct 31, 2009 | Refrigerators
Freezer not defrosting
Your defrost drain line is frozen over.Remove everything from the fridge and turn it off for 24 hours with the doors standing open.
The drain line will thaw and you will return to normal operation.
You could also turn the fridge off, remove the freezer floor panel and back panel. Take a hair dryer and thaw out the drain hole. Takes about 2 hours.
You decide which procedure to use.
Apr 23, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Bottom freezer handle
At both ends and actually inside the ends of the handle, are small metal brackets that are attached to the door face by a single screw.
You access the screws by pulling the plastic plugs, using a very small and thin flat bladed screw driver.
My handle was loose but hadn't come off on it's own. But I couldn't get the handle to fully tighten.
My fix was to wrap each end bracket with a couple layers of electrical tape (not covering the screw hole) and reattached the handle.
It is now very tight, as it should be.
Jul 17, 2008 | Amana ABB2227DE Bottom Freezer...
Refrigerator
You need a qualified technician for the leak repair and recharging of refrigerant. All of the refrigerant in the system are gone, next time do not use sharp object when cleaning your fridge.
Jan 11, 2008 | Refrigerators
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
148 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
