Question about Dell Inspiron 1300 Notebook
Headphone jack on Inspiron 1300 intermittent- suspect software
This is weird.
Inspiron 1300 running XP
Internal speakers work all the time.
Plugging external speakers into headphone jack. 90% of the time no signal going to speakers. Occasionally it does work. If speakers are unplugged while working, then plug reinserted, no signal EVERY TIME.
There is no evidence of this being a hardware issue as I cannot make the sound become intermittent through moving the plug in the jack.
  • 1 more comment
  • diemidio Feb 07, 2009
    Having the same problem. Same computer. Does not make sense to me. Sometimes the headphone jack works fine other times it doesn't work at all. I do not believe it is a short, because when it is not working playing around with the wire does not get it to work, and when it is working playing around with the wire will not make it stop working.
  • biglefty1 Apr 16, 2009
    I had the headphone working but,when using Skype, I have to remove the headphone jack and listen via speakers. Is there a solution out there?
  • Lemmo May 25, 2009
    This is a regular annoyance for me. I can only surmise that the headphone jack
    itself isn't worth the 2 cents worth of metal they used to make it
    with. When a plug has been in the jack and I remove it, I have to wait
    at least a minute before inserting another plug, otherwise there is no
    connection. It always eventually works, but the time I have to wait
    varies. Sometimes it's seconds, sometimes minutes. I can only guess why
    this happens, but it does.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
Check mixer on pc to ensure all levels are maxxed. Suspect moreso that plug on side of pc is bad. If this is helpful, please post as such
Posted on Jan 17, 2009
Win 7 drivers for creative sbs a235 speaker
creative a 235 doesnot require any computer driver. Just plug into headphone jack and enjoy. If your headphone is working in the same jack and your speakers must also work. Use a working headphone to check the problem is with laptop or speakers.
Apr 20, 2014 | Creative Labs Audio Players & Recorders
Turn off internal speakers and use usb external speakers
Plug the input cable from the speakers to the headphone jack.
Jan 11, 2013 | Dell Inspiron 1525 Laptop
I have a Latitude D600 laptop. When I plug in my headphones, the sound still plays through the built in speakers. When I twist the plug in the jack I can sometimes get sound in the headphones but it still...
I dont think the JACK is the problem, I suspect a bad headphone wire (intermittent) or an incorrect driver, headphone jacks in laptops are software controlled, (no mechanical switch inside) if you hear sound in both the headphones and the speakes it is a driver issue, try updating the driver, if the headphone wire is erratic it can fool the software that controlls the input and do crazy things also...
May 26, 2011 | Dell Latitude D600 Notebook
No headphone sound, but internal speaker works fine.
It is because that your internal speaker is the default play back device other than your head phone or external speaker.
Need to go to your sound setting.
Depend on your operating system, click Start, then click Control panel, then click Hardware and Sound, click Sound.
Under Playback tab, select your external speaker or head phones as default device.
May 10, 2010 | Toshiba Satellite A135-S4527 Notebook
I cannot get sound from my internal speakers on dell d600 latitude. Headphones work and sound comes out of internal speakers briefly when pulling jack plug out? So I know they work but just cannot get...
This sounds like a defective audio port. In normal operation, plugging in a headphone plug breaks the connection to the speakers. On your laptop, when you pull out the plug it makes a connection, but only briefly. Unfortunately the audio port is built into the system board. I don't think you will find a software fix for this problem. Your best bet is to get a USB sound device for external speakers.
Apr 27, 2010 | Dell Latitude D600 Notebook
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Problem in internal speakers in dell inspiron 1440
Probably just a software setting...many different things in software could cause this.... OS, driver, something... but could be bad speakers.
Try external speakers in the headphone jack.. if they work fine, then probably bad internal speakers.
Software is the most likely culprit.
Sep 08, 2009 | Dell Computers & Internet
My last Reciever, I had wireless speakers that worked by plugging into the headphone jack. When the wireless transmiter was plugged into the headphone jack I still had sound coming out of the main...
Your system is designed to interrupt the signal flow once headphones are attached. It can not be changed without internal modifications. There is no control to do this.
Dan
May 12, 2009 | Yamaha HTR-5730 Receiver
Sound is working but internal speaker is not working
Connecting headphones to the system will disabled the internal speakers until the headphone jack is disconnected, at which such time the internal speakers should function again.
If you disconnect the headphones and the internal speakers are not re-activated, then there may be damaged to the microswitch in the jack. (Try rebooting after the headphones are disconnected too)
Mar 01, 2009 | Dell Latitude D410 Notebook
Headphone jack loose?broken?
You need a new one not worth fixing
how old is it when did it stop working
if you just bought it then
you need to return it and have it exchanged
there obviuosly is a defect.
Feb 12, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 1300 Notebook Logo
295 people viewed this question
Alun Cox
