Question about 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Remote start on my viper alarm wont stay running
My 05 diesel truck with 6 speed trans mission...the truck will start but about 30 second to a minute later the truck shuts of and goes into start mode again.starts and then shuts off again...
    Problem Solver:
  • 12 Answers
It is getting a shutdown trigger from somewhere. check manual for rem.st. diagnostic trouble code section to find out where from is step one.
Posted on Jan 15, 2009
When i remote start the truck it will run for about 30 sec. then it will turn off and the alarm will go off. if i started up the truck with the key and then push the remote start when i take out the key it...
Ok. You don't tell us what year, make, or model the truck is, but I'm assuming it is a later model. They all come with integrated alarm and immobilizer systems installed. If you did not get an aftermarket adapter to disable the factory alarm system, then if the vehicle is started without the key it will shut off and alarm after 30 seconds. Once you used the key, you satisfied the manufacturers alarm system and then your remote start worked. You need to get a module specifically designed for your vehicle and alarm system to use with the Viper to make it work. They can be a real pain to get working correctly. Good luck!
Aug 16, 2013 | 5204 Responder LE 2-Way Security and...
I have a viper remote start that came with the used i car i bought, the remote start worked great for the first few months of winter, now when i start it up, it runs for 2 seconds then dies, takes up to 6...
Your alarm may have lost the tach signal, that was learned to it, when it was originally installed. That would cause the remote start to try starting the vehicle over and over again, until it finally stays running, because it can't read the engine speed to know it's running.
If you can find the valet push button switch in your vehicle, try this; Start your car with the key and immediately after it starts, press and hold that valet push button switch until the alarm led on the dash stays lit up or the park lights flash. Then, release the valet switch, shut the car off and try remote starting it. That is the procedure to re-learn the tach signal. Hope it works for you.
Feb 10, 2011 | Remote Start System
How do I adjust the sensitivity of my alarm? I can slam the tailgate and it will not go off. Also, I can activate my remote start and it will start and run, BUT, oftentimes when I hit the open door...
To adjust the alarm sensitivity there is a sensor usually on the steering column with a plastic screw that can be turn to adjust the sensitivity. To change the setting you will probably need the manual for the alarm and there is a wire with a small button on that to program settings for alarm sound or remote start start and stop time.
Apr 20, 2017 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper Two-Way Remote
I had the exact same problem. Disconnect your vehicle battery for 30 minutes. That fixed it for me.
Jan 11, 2010 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
'98 Audi A4, Viper 5501. Car auto-starts and runs
You will be best to connect the real tach wire. You will need to programme the alarm to recognise the speed of the engine, this way it will know where the idle position is.
Nov 20, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 5901 Starting issues
i need to adjust the time that it waits to start for my glow plugs in my 2001 ford excursion diesel 7.3. I need it to wait another 10 - 12 sec.
Sep 12, 2009 | Viper Security and Remote Start System...
Viper alarm keypad will beep for 30 seconds every time I arm or disarm
Change the battery, 2-way remotes require 2 slim batteries on top of one another. Regular remotes only require 1.
May 10, 2009 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Viper 160XV Problem
How to programing the remote for viper 160 xv.Thanks.
Jul 02, 2008 | Viper Security and Remote Start System...
5701 VIPER 5701 2-WAY ALARM w/REMOTE START Logo
577 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
