1995 Cadillac DeVille Logo
Posted on Dec 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1995 cadillac concours deville with a northstar engine and I replaced my serpentine belt, after I replaced it, it was still loose and I tightened it as tight as I could. The belt was the right size, so I figured it was slipping because I didn't clean the pulleys. So I scrubbed the pulleys,bought a new belt, put the new belt on and it was still loose. Do u think I need to replace my tensioner? Or is there a way I can adjust my tensioner?
Adrian Jaramillo
Level 2:
Sergeant:
  • Expert 308 Answers
  • Posted on Dec 16, 2012
Adrian Jaramillo
Expert
Level 2:
Sergeant:
Answers
308
Questions
Helped
72340
Points
943
No adjustment, proper routing? if so tensioner need replacement.
2 Related Answers
Kravcar
Mark Carrington
  • 192 Answers
  • Posted on Apr 28, 2010
SOURCE: replacement sequence for serpentine belt for a 96 cadillac devill
Assuming you have the Northstar engine
brandon day
  • 173 Answers
  • Posted on Mar 21, 2010
SOURCE: Cadillac 1993 northstar serpentine accessories drive belt.
the pullys with the groves need the ribbed side of the belt. and the pullys with the flat serfice need the back side of the belt. if u try it a few difrent ways u should be able to put it on in a few minuts
Where and how many freeze plugs are on a 96 Cadillac DeVille 4.6L v8
A hunt and count question. core/freezed plug.
NO VIN told no RPO code for engine told.
8th digit of VIN is ENGINE CODE VIN :"Y" below.
or vin=9 (8TH)
well even the service manual does not do the count.
it shows some, block and heads.
what you can learn to do is google it.
here is how to do that
I google new rebuilt raw engine blocks for sale.
watch out engine can evolve and even be swapped a newer GEN engine, 279 cu in (4.6 L)
but I will post for DAY new,1996 only
1996, the Northstar engine
RPO code LD8 or L37
lets to LD8
the DeVille Concours was available with the new 270 hp (201 kW) LD8 Northstar V8, and later, the high-output L37 Northstar generating 300 hp (220 kW).
LD8
first hit shows VIN-=Y shows 4 in the 2 heads 2x2.=4
left and right heads outside ends. and 1 rear and front of head for 6 total,
https://www.npdengines.com/product-page/96-99-cadillac-deville-4-6-northstar-engine-vin-y
found with google
die-cast aluminum block!!! SORRY NOT SAND CAST.
A GOOD TECH FINDS THE ACTUAL LEAK FIRST
SEEMS YOU ARE GUESSING,
THE 1995 BACK IS ALL DIFFERENT.
LOTS OF VIEW HERE, ALL FOUND VIA GOOGLING FOR YOU.
https://www.hpmotors.com/cadillac-northstar-v8.html
FIND THE LEAK FIRST, THEN WORRY CORE PLUGS IF AT ALL.
Replace north star engine belt
I found this picture, it didn't say northstar. The tensioner in picture has a half-inch cut-out. Use a 1/2 rachet or break-over in cut-out, usually the longer the handle, the better. You pull the tensioner one way or the other to get slack in the belt, then remove belt from accessory pulley.
2answers
Serpentine belt routing
There are two belts. One is long and one is really short. See the diagram attached:
Serpentine belt broke, and I am told I need a new compressor. We found one but it is from a seville with a northstar engine. Can I use this? Thank you
Hello: All Cadillac Devilles had a Northstar starting in 1996. It will not make any difference if it is a SLS (275 HP) or a STS (300 HP)
2answers
1995 cadillac deville how to replace serpentine belt
You'll need to locate the tensioner pulley and rotate it toward the center of the engine with either a 3/8 or 1/2 inch ratchet or breaker bar. This will allow you to pull the old belt off and install the new one. There should be a sticker near the radiator that shows the belt routing, if not there will also be a diagram in the owner's manual. This is a fairly easy job so good luck.
1helpful
Where is the starter located on the Deville Concours
Hello: The Concours has the Northstar engine and the starter is UNDER the plastic intake manifold. Remove intake to replace starter.
10helpful
1helpful
3answers
1995 cadillac deville tears up the serpentine belt
usally tearing belts is the ac compressor not turning or poorly. your tension could be going bad also alllowing the belt to flex and contact another object. you will need to block your wheels.open the hood. have a freind rev the engine in cycles for you to watch and see if the belt flexes or the ac commperssor is the cause
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
