Hello. Do not know the model of your camera, but sounds like system internal error. Try to download the firmware for your model at kodak website listed under support. Be sure to get only the file for your model camera !!!!!
see this causes and proceed . God bless you If the camera won't turn on, check the batteries, or connect the
camera to an AC adapter. If that doesn't work, remove all batteries,
disconnect the AC adapter, wait a minute, reinsert batteries and
reconnect the adapter.
If the flash doesn't work, the camera won't take pictures, or the screen keeps turning off, check that the batteries are strong.
Hi As you say the camera is only a month old it should be under warranty, better advised to take it to the authorized service center. By the way if the smudge is on the LCD then I feel that the LCD is damaged due to pressure or force at that particular spot. Regards. Javeed
Does your camera also have an optical viewfinder? If so, chances are that you accidentally pressed the button that turns the screen off to save battery power. You would then use the optical viewfinder in its place. For your model camera, read the user manual to find out where this button is. On Canon cameras, it's usually a little button labeled DISP or DISPLAY. Just press it oonce to turn the screen back on again.
But if the above doesn't help, have you tried downloading photos taken when the screen is black? Are these photos also black? If so, chances are in this case that you are experiencing a stuck shutter. This is also very easy to remedy (see this).
