Question about Craftsman 16" High Garden Tractor Snow and Dozer Blade
What the handlebar adjust (foot pedal) is for on track snowblower
I just bought a small Craftsman snowblower, 4hp, 20'' cut. It has adjustment via a foot pedal for the handlebar adjustment. What exactly is the adjustment for. It appears to alter the track angle somewhat and the angle of the blower. I assume it has a definite purpose due to the multiple adjustments on the foot pedal.
thanks
Jeff
SOURCE: 20 Year Old Craftsman Lawn Tractor Steering Gear Slips
check top of sector gear mounting plate for waer this is the gear that hooks to you steering gear . the plate that it mounts to will ware down causing it to be loos and slip . the only way i know to fix it is to pull the cross member out and take it to a welding shop and have it built back up.if the bolt is as tight as itcan go .
Posted on May 06, 2009
  • 376 Answers
SOURCE: Craftsman 42 inch riding lawn mower is not cutting evenly
The first thing to check is your blades. If one is bent, it will never cut even. It happens a lot hitting roots, antbeds, etc. Mulching blades will bend easier than a straight blade. It's best to take them off and lay one on top of the other to see if they're bent.
Posted on May 25, 2009
  • 376 Answers
SOURCE: Cuts lawn uneven, one side shorter than other
Was it cutting uneven before you changed blades? If so, you may not have gotten the blade on the shaft correctly. There is an adjustment in the center of the deck hanger on each side. You can turn the 9/16 nut up or down on each side to level it out.
Posted on May 28, 2009
  • 376 Answers
SOURCE: need to adjust brake/clutch 14hp craftsman lawn tractor
The brake is on the right side of the transaxle. There are two mounting bolts and one 1/2 nut in the middle that is your adjustment. Tighten it 1/2 turn at a time and hold the brake down and try to roll it until it holds.
Posted on Jun 09, 2009
  • 19 Answers
SOURCE: adjusting brake on Craftsman LT 1000 lawn tractor manual
underneath by the right side tire turn in the adjustment nuts on the brake rod. if brake is bad the disk will have to be replaced see a manual.
Posted on Jul 19, 2010
I am trying to find the manual for a 26" men's Genesis VT2100 bicycle, model GS93688
Manuals for bicycles are generic, not oriented to a particular model, and mostly are comprised of safety warnings and info and very basic adjustment info. What is it you hope to learn from the manual?
May 29, 2016 | Cycling
Forward or reverse will not engage - cluthch problem?
happened to me. found loose drive clutch cable. Adjustment bolt is just under the handlebar, attached to the cable. adjusting lock nut came loose and tension adjusting bolt spun out from vibration. retighten sleeve onto adjustment bolt and see if drive drive will engage. IF NOT.......look to other end of cable......UGH!
Mar 04, 2014 | Tecumseh Snowblower Snow Blower Starter...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
How do i adjust the driver belt. where is the adjustment? i have a 42inches cut 19.5 engine
I have the same mower.
When i changed my belt i just made sure i had it in neutral.
I also made sure the clutch was pushed in to give the belt slack so i could remove it.
When the clutch is released, its springs back and pulls the belt tighter against the front pulley.
There isn't any adjustment for the belt.
But you may be able to adjust your clutch pedal. Its a long threaded bolt with a nuton the end,.
the nut acts as a stop for the pedal, adjust it so it moves further or shorter, to loose and it wont adjust at all.
But if it worked okay before the belt failed, then all you should have to do is remove the old belt and install the new one, no adjustment needed. the clutch pedal is the adjustment.
I was sold the wrong belt one time and it wouldnt work no matter what i adjusted.
it was too long. Check to make sure you have the right belt.
Hope this helps, i know the grass is growing fast.
Big Al
Jul 25, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Why does bike size is important?
It is clear that wearing a shirt two sizes too small would be uncomfortable, and wearing a shirt two sizes too large wouldn't be good either. In the same way, riding a wrong size bike will fit badly and make you uncomfortable, too. There are two main problems, one obvious and one a little more subtle.
The first big problem with a bike that doesn't fit is saddle height. You need the saddle to be just high enough to give your legs the right extension when you pedal. Too low and your legs stay bent too much all the way around; this doesn't use your leg muscles well and you wear out quickly. Too high and you rock back and forth on the saddle as you pedal, very uncomfortable. Either extreme (too high or too low) can also be very hard on your knees.
Saddle height is adjustable, of course, and if the bike frame is at least close to the right size, you'll be able to adjust the saddle to the proper height. If the frame is a lot too small, you can usually overcome this problem by buying a longer seatpost to move the saddle back up to where you want it. (But that causes other problems we'll talk about soon.) If the frame is much too large, you won't be able to drop the seat far enough to be usable, and there is no practical way around that problem.
The saddle on a bike can be adjusted up and down several inches, even as much as a foot if you consider replacing the original seatpost with a longer one. But the handlebars can't be moved nearly as far as saddles can. Most handlebars can be adjusted up and down or forward and back only two inches or so, and even this small change is often a complicated operation of replacing parts, not just loosening a few bolts.
This can lead to all sorts of problems. If the handlebar is too far away from the saddle, you have to bend down further and reach far out to grab the bars. This puts more weight on your back, arms and hands, which is uncomfortable. Having the handlebar too close to the saddle is less of a problem, but in extreme cases it can cause your knees to bump the handlebars when you are standing up to climb a hill. Having the handlebar a lot lower than the saddle is similar to having it too far away-you have to bend far over and reach further to grab the bars, an uncomfortable position. Having the handlebars high up is not a big problem, except that sitting upright slows you down. Your legs aren't as strong when you are sitting up, and that position causes more wind resistance when riding fast or into a wind.
Bike size has a big effect on handlebar position. If the frame is too small, you'll have to push the seat up high to fit your legs. You won't be able to move the handlebar up as much, so it will be a long reach back down to grab the bars, and your back will be quite bent over. If on the other hand the frame is too large, the bars will be up high but might be too far forward (since the frame gets longer as well as taller).
Dec 21, 2010 | Cycling
Brake wont hold going down or up hill. How do you adjust them
Look in the manual if you can find one. If not drop the deck and take a look at the linkage on the brake pedal. You may well find that the pedal connects to shoes which pinch a small disc in the transmission via a long rod which has an adjustment set of threads and a nut. Either replace the little shoes, or adjust the nut and threaded rod.
Aug 05, 2010 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
2010 Craftsman Lt 2000 deck height adjustment?
just bought a new craftsman riding mower. model lt1500. 17.5 hp with 42 inch deck. first time using I had the deck hight handle set on 6 the highest setting and still cuts grass to short, matter of fact it scalped the grass. anyway to set the deck higher. Its only 3 days old and still under warranty but the sears store is 20 miles away and I rented a trailer to go pick it up and hate to go rent another trailer to bring it back if its just a simple adjustment.
Jul 31, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I try to engae the foot pedal and it feels stuck
check springs and linkages under rides linkage may need adjustment
Mar 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Clutch/Brake Pedal Problem
first off your biggest problem is its built by MTD.they build about 90% of the riding lawn mowers you see in the stores that are 20 horse and under,every thing from a yard machine to a craftsman to a cub cadet. you need to get under it and fallow the linkage from your pedal to your rear transaxle. that link is adjustable if it is not , then the arm it attaches to is .you need to adjust it whichever way takes slack out of the belt, if all the adjustment is out then replace the belt and adjust it accordingly
Apr 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Drive chain loose and poped offmy snowblower
Two things you can do. First if you look close you may see a spot where you can adjust the chain tension. Nest your chain should have what is called master link. Look close and you will see a clip that undoes the link. Pull the link out and the chain will come apart. If you are not mechanically inclined take it to any small engine shop and they will take a link out for you and then you will be home free.Hope this helps. donnyb60
Mar 23, 2009 | Craftsman 16" High Garden Tractor Snow and...
Craftsman 16" High Garden Tractor Snow and Dozer Blade Logo
107 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
