Question about Kenmore 22422 Top Load Washer
Kenmore washer 110.24722300 no agitate
The washer fills and stops- no sound, no noise from the motor or timer. But I am unable to get into this washer as the top is screwed to the sides of the washer in all 4 corners. Can't get to the screws. How do I get into the washer, the top does not pop off like most washers... Model number is 110.24722300
    Problem Solver:
  • 10 Answers
Pop offf your end caps on the right and left thers a screw under them
Posted on Jun 10, 2009
    Sergeant:
  • 363 Answers
This model doesn't pop like most washers. You need to remove the two screws on the corner of the head, raise the head, then pull the two clips on the corners. Look how they go in beforehand so you know how to put them back in :) This releases the cabinet from the base, pull forward to release it, tip in back on it's front. to reassemble, place the front lip under the base, the ease it back onto that as well. Make sure the holes in the bottom of the cabinet align with the li'l nubs stickin up on the base. Squeeze the cabinet as you set it back on so they align. Replace clips, rescrew head back on.
Most likely you have a bad motor. You may be able to find one from a used appliance dealer in your area or a machine someone is discarding :)
Posted on Aug 26, 2009
11 year old Kenmore washer fills then stops.
in the machine under the front control panel will be a module that controls the wash agitation. Have it checked out as they fail . There is no connection between the timer and this unit as it comes in to play when the water reaches a set level. The timer just keeps working through the cycles believing the washer is agitating.
Jun 26, 2013 | Kenmore 24032\24036 Top Load Washer
Series 70 fills wit water stops then makes a slight buzzing sound
The electric motor my have failed or a part called a capacitor could be the problem? The capacitor is part of the starting circuit of the electric motor, if this fails the motor will not start therefore the washing machine won't spin or agitate.
Jun 16, 2009 | Kenmore Washing Machines
Kenmore washing machine fills with water then stops
turn the motor to see if it moves it sound like the motor
May 02, 2009 | Kenmore 24032\24036 Top Load Washer
Not sure if manifold is leaking
Leaks water...check the pump first. The fill valve and hoses may be the next step. See how to take apart info. With the use of plastic drain hoses on many machines today, this has become a common leak trouble maker. The drain hose can rub the wall or a pipe and this will rub a hole in the drain hose.
  1. Agitation problems and agitator dog repair aid info
  2. Automatic dispenser information
  3. Common problems with Inglis, Whirlpool, Kenmore direct drive style of washers
  4. Diagnostic Direct Drive washer chart from American appliance
  5. How a washer works, good to read this first
  6. Help for storing an appliance
  7. How does the agitator come off my washer ??
  8. How to prevent socks from getting into your pump
  9. Ohm test a common direct drive motor
  10. How to by-pass a lid switch for testing the washer
  11. Basic information: Inglis, Whirlpool, Kenmore Direct drive washers
  12. Inglis, Whirlpool, Kenmore Direct drive washers - How to take apart - Cabinet off, cabinet on, checking or replacing a lid switch, replace the pump, replace motor coupling or motor.
  13. Inglis, Whirlpool and Kenmore direct drive washer- useful parts breakdowns
  14. Important disclaimer
  15. My direct drive washer will fill ok, agitates ok but when it comes to the spin and drain cycle the washer comes to a screeching halt...no spin, no draining and the timer stops, what's up?
  16. My clothes have a whiting on them that looks like lint.
  17. My washer has a funky odor
  18. Noises
  19. Ohm meter testing a motor capacitor
  20. Slow water fills
  21. The wash tubs on my direct drive washer are leaning to the right...why?
  22. Timer stalls or missing cycles
  23. Timer will not advance
  24. Tips on changing a common washer fill valve
  25. To learn more about washing machines, click here
  26. Washer Basics: Filling with water
  27. Washer leaks water
  28. Washer moves around to much
  29. Washer will not spin
  30. Washer sample wiring diagrams
  31. Washer spins and agitates at the same time
  32. Washer belts: If your belt on any washer looks like these, replace the belt(s).
  33. Washer runs but wont agitate or spin
  34. Washer won't run, agitate or spin
  35. What is that black power powder or filings under my washer??
Apr 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer fills and agitates at same time
it sounds like the timer is going bad
Oct 22, 2008 | Washing Machines
My kenmore washer fills up but then just stops
it could be several things, something is lodged in pump, so the motor wont run, the motor is bad, or you have a bad transmission.
Start with the pump and see if it has sock or something stuck in it.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 90 Series Washer
Maybe. Sounds like the motor is not agitating in the other direction??? There is a controller on this type of machine which handles the starting...direction of the motor..this is by far the most common for your description.
next would be the timer or transmission.
to check trans..grab top lip of bowl it should be locked in both directions. tilt machine back..you should be able to spin the pulley in both directions it not its the trans
I'm sorry bout the flow of this...not used to doing it like this...think i'm slowly getting better????
Jan 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer won't Agitate
gearbox internal fault, major repair, not really a do it yourself job.
Dec 25, 2007 | Washing Machines
Kenmore 22422 Top Load Washer Logo
262 people viewed this question
Sal De
fordexpert
Robert Rankin
